宝岛KCL凯嘉油泵 ...
VPKC-F15-A1-02-1 VPKC-F15-A2-02-1 VPKC-F15-A3-02-1
VPKC-F15-A4-02-1 VPKC-F15-A202-1 VPKC-F15-A202
VPKC-F20-A1-02-1 VPKC-F20-A2-02-1 VPKC-F20-A2-03-1
VPKC-F20-A4-02-1 VPKC-F20-A4-01-1 VPKC-F20-A202-1
VPKC-F30-A4-1... VPKC-F40-A4-1
双联变量泵:
VPKCCF12.12 A1(2/3/4)A1(2/3/4)
VPKCCF15.15 A1(2/3/4)A1(2/3/4)
VPKCCF20.20 A1(2/3/4)A1(2/3/4)
VPKCCF23.23A1(2/3/4)A1(2/3/4)
VPKCCF26.26 A1(2/3/4)A1(2/3/4)
VPKCCF30.30 A1(2/3/4)A1(2/3/4)
VPKCF40.40 A1(2/3/4)A1(2/3/4)
DVQ20-6-F-RAA-01 DVQ20-8-F-RAA-01
DVQ20-11-F-RAA-01 DVQ20-14-L-RAB-01
DVQ20-17-F-RAB-01 DVQ20-19-F-RAA-01
DVQ20-23-L-RAA-01 DVQ20-26-F-RAA-01
DVQ20-32-F-RBB-01 DVQ20-34-F-RAA-01
DVQ20-38-F-RAA-01
DVQ25-18-F-RAB-01 DVQ25-22-F-RAA-01
DVQ25-26-F-RAA-01 DVQ25-32-L-LAA-01
DVQ25-38-F-LAA-01 DVQ25-43-F-LAA-01
DVQ25-47-F-LAA-01 DVQ25-52-F-RBB-01
DVQ25-60-F-RAA-01 DVQ25-65-F-LAA-01
DVQ25-75-F-RAA-01 VQ15-6-F-RAA-0
DVQ15-8-F-RAA-01
低压定量叶片泵:
50T-07(12,14,17,19,21,23,26,30,36,40)
150T-48(61,75,94,116,125)。
详细型号:
50T-07-F-R-01 50T-12-F-R-01 50T-14-F-R-01
50T-17-F-R-01 50T-19-F-R-01 50T-21-F-R-01
50T-23-F-R-01 50T-26-F-R-01 50T-30-F-R-01
50T-36-F-R-01 50T-40-F-R-01 50T-07-F-R-02
50T-12-F-R-02 50T-14-F-R-02 50T-17-F-R-02
50T-19-F-R-02 50T-21-F-R-02 50T-23-F-R-02
50T-26-F-R-02 50T-30-F-R-02 50T-36-F-R-02
50T-40-F-R-02 150T-48-F-R-01 150T-61-F-R-01
150T-75-F-R-01 150T-94-F-R-01 150T-116-F-R-01
150T-125-F-R-01
VPKCC-F1212A4A4-01,VPKCC-F1212A3A3-01
VPKCC-F1212A2A2-01,VPKCC-F1212A1A1-01
VPKCC-F151高等4A4-01,VPKCC-F151高等3A3-01
VPKCC-F151高等2A2-01,VPKCC-F151高等1A1-01
VPKCC-F2020A4A4-01,VPKCC-F2020A3A3-01
VPKCC-F2020A2A2-01,VPKCC-F2020A1A1-01
VPKCC-F2323A4A4-01,VPKCC-F2323A3A3-01
VPKCC-F2323A2A2-01,VPKCC-F2323A1A1-01
VPKCC-F2626A4A4-01,VPKCC-F2626A3A3-01
VPKCC-F2626A2A2-01,VPKCC-F2626A1A1-01
VPKCC-F3030A4A4-01,VPKCC-F3030A3A3-01
VPKCC-F3030A2A2-01,VPKCC-F3030A1A1-01
HVQ20-4-F-RAA-01
HVQ20-6-F-RAB-01
HVQ20-8-F-RBA-01
HVQ20-11-F-RAA-01
HVQ20-14-L-RAA-01
HVQ20-17-F-RAB-01
HVQ20-19-F-RAA-01
HVQ20-23-F-RAB-01
HVQ20-4-L-RAB-01
HVQ20-6-L-RAA-01
HVQ20-8-L-RAB-01
HVQ20-11-L-RAB-01
HVQ20-14-F-RAB-01
HVQ20-17-L-RAA-01
HVQ20-19-L-RAB-01
HVQ20-24-L-RAB-01
造成叶片泵噪音大有哪些原因?
主要造成叶片泵噪音的原因有以下几点:
1,滤油器被堵塞住,无法吸油。
解决方法:清洗
2,泵端密封被磨损。
解决方法:在轴端油封处涂少许黄油,若噪声变小应立即更换油封。
3,吸入端漏气
解决方法:在吸油管接头处涂上黄油,出现噪声减少应紧固接头。或者可以直接观察回油口处是否出现气泡。
4,泵盖螺钉由于机器的振动而松动
解决方法:方法同上,在螺钉连接处涂上黄油,噪声若减小应更换油封。
5,泵与电动机轴不同心
解决方法:调整到同心即可排除问题。
6,转子的叶片槽两侧与其两点面不垂直
解决方法:更换转子即可
7,配油盘卸荷三角槽过短
解决方法:使用什锦锉适当进行修改,达到前一叶片过卸荷槽时后一叶片脱离吸油腔。
8,花键槽轴端有烫手现象
解决方法:过紧,适当进行调整即可。
9,泵的转速过高
解决方法:调整到规定转速即可。
10,液压油污染严重
解决方法:拆下滤油器查看是否有破损或固体吸附物,后更换滤油器及液压油。
除去以上十点以外,泵芯总压阀芯的磨损情况和油液高度不足导致吸油不足也都会导致叶片泵出现噪音现象。在使用过程中,定期进行检修和维护是必不可少的,问题及时发现及时解决,否则等到问题出现已经无法修复,费时费神又费财,不止是噪音问题,宁愿多操作几步,解决小问题,防患于未然
