合金牌号:
6061
状态:
T6
Tianjin Jinxin Copper New Material Technology Co. , Ltd.
主营:无缝铝管,合金铝管,铝板,铝棒,铝排,六角铝棒,角铝,铝方管
合金牌号:
6061
状态:
T6
| 3*20 | 8*10 | 10*65 | 12*140 | 16*40 | 20*75 | 25*80 | 35*45 | 40*170 | 50*200 | 70*85 | 铝方 |
| 3*30 | 8*12 | 10*70 | 12*150 | 16*45 | 20*80 | 25*85 | 35*50 | 40*180 | 55*60 | 70*90 | 8*8 |
| 3*40 | 6*8 | 10*75 | 12*160 | 16*50 | 20*85 | 25*90 | 35*55 | 40*200 | 55*65 | 70*100 | 10*10 |
| 4*20 | 8*15 | 10*80 | 12*170 | 16*55 | 20*90 | 25*95 | 35*60 | 45*50 | 55*70 | 70*110 | 12*12 |
| 4*30 | 8*20 | 10*85 | 12*180 | 16*60 | 20*95 | 25*100 | 35*65 | 45*55 | 55*75 | 70*120 | 14*14 |
| 4*40 | 8*25 | 10*90 | 12*200 | 16*65 | 20*100 | 25*110 | 35*70 | 45*60 | 55*80 | 75*80 | 15*15 |
| 4*50 | 8*30 | 10*95 | 14*100 | 16*70 | 20*110 | 25*120 | 35*75 | 45*65 | 55*85 | 75*85 | 16*16 |
| 4*59 | 8*35 | 10*100 | 14*170 | 16*80 | 20*120 | 25*130 | 35*80 | 45*70 | 55*90 | 75*90 | 18*18 |
| 5*20 | 8*40 | 10*110 | 15*20 | 16*90 | 20*130 | 25*140 | 35*85 | 45*75 | 55*100 | 75*95 | 20*20 |
| 5*25 | 8*45 | 10*120 | 15*25 | 16*100 | 20*140 | 25*150 | 35*90 | 45*80 | 55*110 | 80*90 | 22*22 |
| 5*30 | 8*50 | 10*130 | 15*30 | 16*110 | 20*150 | 25*160 | 35*95 | 45*85 | 55*120 | 80*100 | 25*25 |
| 5*35 | 8*55 | 10*140 | 15*35 | 16*120 | 20*160 | 25*170 | 35*100 | 45*90 | 55*130 | 80*110 | 28*28 |
| 5*40 | 8*60 | 10*150 | 15*40 | 16*140 | 20*170 | 25*180 | 35*110 | 45*95 | 55*140 | 80*120 | 30*30 |
| 5*45 | 8*65 | 10*160 | 15*45 | 16*150 | 20*180 | 25*190 | 35*120 | 45*100 | 55*150 | 80*150 | 32*32 |
| 5*50 | 8*70 | 10*180 | 15*50 | 16*160 | 20*200 | 25*200 | 35*130 | 45*110 | 60*65 | 80*180 | 35*35 |
| 5*55 | 8*75 | 10*200 | 15*55 | 16*180 | 20*250 | 30*35 | 35*140 | 45*120 | 60*70 | 90*100 | 40*40 |
| 5*60 | 8*80 | 10*250 | 15*60 | 16*200 | 22*40 | 30*40 | 35*150 | 45*130 | 60*75 | 45*45 | |
| 5*70 | 8*85 | 12*15 | 15*65 | 18*30 | 22*50 | 30*45 | 35*160 | 45*140 | 60*80 | 50*50 | |
| 5*75 | 8*90 | 12*20 | 15*70 | 18*40 | 22*55 | 30*50 | 35*170 | 45*150 | 60*85 | 55*55 | |
| 5*80 | 8*95 | 12*25 | 15*75 | 18*50 | 22*60 | 30*55 | 35*180 | 45*160 | 60*90 | 60*60 | |
| 5*102 | 8*100 | 12*30 | 15*80 | 18*60 | 22*66 | 30*60 | 35*200 | 45*170 | 60*95 | 65*65 | |
| 6*10 | 8*110 | 12*32 | 15*85 | 18*70 | 22*75 | 30*65 | 40*45 | 45*180 | 60*100 | 70*70 | |
| 6*12 | 8*120 | 12*35 | 15*90 | 18*80 | 22*80 | 30*70 | 40*50 | 45*200 | 60*110 | 75*75 | |
| 6*15 | 8*130 | 12*40 | 15*95 | 18*90 | 22*90 | 30*75 | 40*55 | 50*55 | 60*120 | 80*80 | |
| 6*20 | 8*140 | 12*45 | 15*100 | 18*100 | 22*100 | 30*80 | 40*60 | 50*60 | 60*130 | 85*85 | |
| 6*25 | 8*150 | 12*50 | 15*110 | 18*110 | 22*110 | 30*85 | 40*65 | 50*65 | 60*140 | 90*90 | |
| 6*30 | 8*160 | 12*55 | 15*120 | 18*120 | 22*120 | 30*90 | 40*70 | 50*70 | 60*150 | 95*95 | |
| 6*35 | 8*200 | 12*60 | 15*130 | 18*130 | 22*130 | 30*95 | 40*75 | 50*75 | 65*70 | 100*100 | |
| 6*40 | 8.5*25 | 12*65 | 15*140 | 18*152.3 | 22*147.5 | 30*100 | 40*80 | 50*80 | 65*75 | 105*105 | |
| 6*50 | 10*15 | 12*70 | 15*150 | 20*25 | 25*30 | 30*110 | 40*85 | 50*85 | 65*80 | 110*110 | |
| 6*60 | 10*20 | 12*75 | 15*160 | 20*30 | 25*35 | 30*120 | 40*90 | 50*90 | 65*85 | 115*115 | |
| 6*70 | 10*25 | 12*80 | 15*180 | 20*35 | 25*40 | 30*130 | 40*95 | 50*95 | 65*90 | 120*120 | |
| 6*80 | 10*30 | 12*85 | 15*200 | 20*40 | 25*45 | 30*140 | 40*100 | 50*100 | 65*100 | 125*125 | |
| 6*90 | 10*35 | 12*90 | 15*250 | 20*45 | 25*50 | 30*150 | 40*110 | 50*110 | 65*110 | 130*130 | |
| 6*100 | 10*40 | 12*95 | 16*20 | 20*50 | 25*55 | 30*160 | 40*120 | 50*120 | 65*120 | 135*135 | |
| 6*110 | 10*45 | 12*100 | 16*25 | 20*55 | 25*60 | 30*180 | 40*130 | 50*130 | 65*130 | 140*140 | |
| 6*120 | 10*50 | 12*110 | 16*30 | 20*60 | 25*65 | 30*200 | 40*140 | 50*140 | 65*150 | 145*145 | |
| 6*150 | 10*55 | 12*120 | 16*32 | 20*65 | 25*70 | 32*65 | 40*150 | 50*150 | 70*75 | 150*150 | |
| 6*160 | 10*60 | 12*130 | 20*70 | 25*75 | 35*40 | 40*160 | 50*160 | 70*80 | 160*160 |
我广告李时珍称它为“男人宝”,男人生猛干劲足,老婆竖起大拇指!
由铝质材料制作的称为铝排,在电路中起输送电流和连接电气设备的作用。
一、铜铝排载流量快速查询
▲点击查看大图
二、估算法:
单条铜母排载流量= 宽度(mm) X 厚度系数
双母排载流量= 宽度(mm) X 厚度系数 X 1.5(经验系数)
铜排和铝排也可以按平方数来,通常铜应该按5-8A/平方,
铝应该按3-高等/平方
三、常用铜排的载流量计算方法:
40℃时铜排载流量=排宽*厚度系数
排宽(mm);厚度系数为:
母排12厚时为20;10厚时为18;
依次为:[12-20,10-18,8-16,6-14,5-13,4-12].
双层铜排[40℃]=1.56-1.58单层铜排[40℃](根据截面大小定) 3层铜排[40℃]=2单层铜排[40℃]
4层铜排[40℃]=单层铜排[40℃]*2.45(不推荐此类选择,较好用异形母排替代)
铜排[40℃]= 铜排[25℃]*0.85
铝排[40℃]= 铜排[40℃]/1.3
例如求TMY100*10载流量为:
单层:100*18=1800(A)[查手册为1860A];
双层:2(TMY100*10)的载流量为:1860*1.58=2940(A);[查手册为2942A];
三层:3(TMY100*10)的载流量为:1860*2=3720(A)[查手册为3780A]
以上所有计算均较好到与手册数据相当接近。
另外,铜排载流量也有一个非常简明的计算公式:
单根矩形铜排载流量= 排宽 * (排厚 8.5)A
例如:15*3的40℃时载流量=15*11.5=172.高等
100*8的40℃时载流量=100*16.5=1650A
双层载流量=1.5倍单层载流量
三层载流量=2.0倍单层载流量
广告天天喝白酒的男人,身体较后都怎样了?
四、铝铜排载流量的计算
口诀
铝排电流要算快,排宽系数乘起来;
厚三排宽乘十个,后四排宽乘十二;
加一依次往上添,铜排再乘一点三。
母线排的载流量与其截面大小有关。故可通过母线排的厚度和宽度尺寸,直接算出载流量。
口诀指出,对一定厚度的铝排,它的载流量为排宽乘个系数即可。
厚3毫米的铝排,载流量为排宽×10,厚4毫米的铝排载流量为宽×12。
“加一依次往上添”说的是,厚度增加一毫米,宽度所乘的系数跟着加一,匆毫米厚的铝排开始,依次排列如下表:
厚度(毫米) 3 4 5 6 8 10
载流量(安) 宽×10 宽×12 宽×13 宽×14 宽×16 宽×18
注:铝排厚度没有7mm和9mm两个规格。
例:求40×4母铝排载流量是多少?
解:根据口诀,厚4载流量为×12 故 40×12=480安
例:求60×6铝母排载流量是多少?
解:60×14=840安
“铜排再乘一点三”说的是铜排的载流量比同规格铝排要大三成。
故求铜排载流量时,先视为铝排,按以上方法算出后,再乘1.3即可。
例:求50×13×1.3=845安
母排的载流量还与环境温度、多条母排并列、母排平放、竖放等因素有关。
当一般环境温度经常高于250C或者做直流母线并列时,可按九折处理。
交流2、3、4条母排并列使用时,可分别打8、7、6折。
