IC693 CMM321是一款网络接口模块,主要用于GE的工业自动化设备中247。它的主要功能是在系统组件之间实现可靠****的通信5。
在具体的应用中,IC693 CM321被广泛应用于蒸汽/燃气轮机组的管理系统Speedtron系列中8。它的设计主要用于连接(CAPB)控制组件背版,以便与(HB)H桥接口和控制版通信8。此外,IC695 CRU320和IC698 CPE040等其他设备也经常与IC693一起使用8。
IC693的设计坚固可靠,可以在各种环境条件下使用47,并且具有热插拔功能,可以在运行中进行维护和升级8。同时,它还具有以太网通信功能,可以实现****的工业流程控制5。
CINCINNATI MILACRON 4-531-3109A00B USPP 453109A00B
CINCINNATI MILACRON 4-531-31A00D USPP 4531A00D
CINCINNATI MILACRON Circuit Board PCB #3-531-3281A
CINCINNATI MILACRON Circuit Board PCB 3-531-33A 33
CINCINNATI MILACRON 3-531-267 USPP 35367
CINCINNATI MILACRON 3-531-2202-H USPP 353202H1
CINCINNATI MILACRON 3-531-2204-F USPP 353204F1
CINCINNATI MILACRON 4-531-32A00A USPP 4532A00A
CINCINNATI MILACRON 4-531-36A USPP 4536A
CINCINNATI MILACRON 4-531-3176A00A USPP 453176A00A
CINCINNATI MILACRON 4-531-3184A00A USPP 453184A00A
CINCINNATI MILACRON 4-531-3149A00A USPP 453149A00A
CINCINNATI MILACRON 4-531-3156A00A USPP 453156A00A
CINCINNATI MILACRON 4-531-3173A USPP 453173A
CINCINNATI MILACRON 3-531-341 USPP 35341
CINCINNATI MILACRON 3-531-3238A USPP 353238A
CINCINNATI MILACRON 3-531-3480A USPP 353480A
CINCINNATI MILACRON 4-531-33A00A USPP 4533A00A
CINCINNATI MILACRON 3-700-0109A USPP 37000109A
CINCINNATI MILACRON 4-531-3153A00A USPP 453153A00A
CINCINNATI MILACRON 4-531-4018A USPP 45314018A
CINCINNATI MILACRON 3-531-385 USPP 35385
Cincinnati Milacron 3-531-3284A PC Board
Cincinnati Milacron 3-531-3291A Control Card
Cincinnati Milacron 4-531-4007A00E SRVE Board
CINCINNATI MILACRON 3531 PC BOARD
CINCINNATI MILACRON 3-424-1879A
Cincinnati Milacron 3-531-3409A PCB Board
Cincinnati Milacron 3-531-3951P Programming Panel from Cinturn 8C Turning Center
CINCINNATI MILACRON 3-531-3283A MODULE 353283A
CINCINNATI MILACRON 3-531-3664A MODULE 353664A
Cincinnati Milacron, Acramatic 950, A950, SXDR, 3-542-01A, Vickers, Siemens
CINCINNATI MILACRON 3-533-0432G *NEW NO BOX*
Cincinnati Milacron SIMOREG TRANSISTOR PWM DRIVE D165
Cincinnati Milacron 3 531 40 a Power Board
Cincinnati Milacron 3-533-0180G Module Board
Siemens/Cincinnati Milacron Operation Panel 3-525-0942A
Cincinnati milacron EC3control Acrasize-II gauge measuring control grind to size
CINCINNATI MILACRON VMU Board 3-531-3697A
Cincinnati Milacron Acraread L 3-425-09A 3-533-09G Rev D 3-531-4150 Rev A
Cincinnati Milacron 4-702-0046 Acraread Tape Reader
Cincinnati Milacron PC Board, # 3 531 42A, 3-531-4238A, WARRANTY
CINCINNATI MILACRON 3-531 353 BOARD
Cincinnati Milacron 1-3-1098001 inch Monitor made by Ball model TV
Cincinnati Directional valve 3310499FBB-RO1
CINCINNATI MILACRON 3 531 33A COMMUNICATION MODULE EXCELLENT CONDITION
CINCINNATI MILACRON 3 531-3280A TIMER MODULE EXCELLENT CONDITION
CINCINNATI MILACRON 3 531-3284A AC INPUT MODULE EXCELLENT CONDITION
Cincinnati Milacron BSK I/O P304 Board (4336)
Cincinnati milacron Logic PCB 3 7 2395G 3795G
Cincinnati Milacron Board VDCI 3-542-1054A Nice Clean working Pullout Guaranteed
Cincinnati Milacron Control Panel CIP/2000 3-525-0551A
Cincinnati Milacron 3-700-0153A Interconnector Module
Cincinnati Milacron 3-531-39A - DC Motor Module
Cincinnati Milacron 3-424-1960A - System Rack
CINCINNATI MILACRON 3-531-4090A. TESTED
Cincinnati Milacron Processor Board 3-531-3632A #14065
Cincinnati Milacron PC Board 3-531-3694A *FREE SHIP*
CINCINNATI MILACRON CMDCI 3-542-94A 354294A CNC B
Saginaw Transmission Lot Sale
SAGINAW MACHINE CO 000W544870 NSFP 000W544870
Saginaw N50-1A Novamat 2 Axis CNC Chucker 79097-06/91
SAGINAW AV-486506 NSPP AV486506
SAGINAW MACHINE CO 000W544817 NSPP 000W544817
SAGINAW D-56059 NSFP D56059
MUNCIE M-22 ROCK CER CLOSE RATIO 4-SPD TRANSMISSION CAMARO 64-74 CHEVELLE SS
CHEVELLE SS,CAMARO,MALIBU,ELCAMINO,IMPALA,BELAIR,RATROD
Muncie 4 speed transmission 1968 69 70 71 72 chevelle camaro close ratio M-21
M22 MUNCIE 4SPEED TRANS Chevy,Olds M21,M20 SAGINAW
Holden Chev Saginaw 4 speed Gearbox Reconditioned Monaro etc
Single Crypt in Oakwood Memorial Mausoleum, Saginaw Mi
Baer SS4 - inch Rotor - Rear 1982 - 1992 GM F-Body Saginaw Disc 4302388B
Baer SS4 - inch Rotor - Rear 1982 - 1992 GM F-Body Saginaw Disc 4302388R
Baer SS4 - inch Rotor - Rear 1982 - 1992 GM F-Body Saginaw Disc 4302388S
Baer SS4 - inch Rotor - Rear 1982 - 1992 GM F-Body Saginaw Drum 4302389B
Baer SS4 - inch Rotor - Rear 1982 - 1992 GM F-Body Saginaw Drum 4302389R
Baer SS4 - inch Rotor - Rear 1982 - 1992 GM F-Body Saginaw Drum 4302389S
SAGINAW 4 SPEED transmission camaro nova chevelle el-camino
MR RACING TRANSMISSION LIGHT WEIGHT DROP-OUT SAGINAW 4-SPEED FULLY ROLLERIZED
SAGINAW CEA3-203610SSWFLP NSFP CEA3203610SSWFLP
Saginaw SCE SCE-20EL2008LP Control Panel Enclosure w/Accessories
SAGINAW PAINT DECORATED BUBBLE GLASS CHINA CABINET WITH DESK
McLEOD RXT TWIN DISC CLUTCH 1000-HP SAGINAW MUNCIE 4-SPEED 10-SPLINE LG FLYWHEEL
McLEOD RXT TWIN DISC CLUTCH 1000-HP SAGINAW MUNCIE 4-SPEED 10-SPLINE SM FLYWHEEL
THOMSON SAGINAW 7825372 NSFP 7825372
SAGINAW 3.50 3 GROOVE 4 SPEED TRANSMISSION CAMARO NOVA MALIBU SS W/ SHIFTERS
SCE Saginaw Control & Eng. SCE-90XM7824 Type Heavy Duty Double Door Enclosure
SAGINAW MACHINE CO 664.20-3 NSPP 664203
SAGINAW MACHINE CO 665.20-3 NSPP 665203
NOS Vintage Hurst Chevrolet 3 Speed Shifter Saginaw Muncie Syncro loc Chevy
McLEOD RST TWIN DISC CLUTCH 800-HP SAGINAW MUNCIE 4-SPEED 10-SPLINE LG FLYWHEEL
