厦门海通华业科技有限公司
已认证
主营:PLC,模块,主板,触摸屏,DCS,变频器,CPU,驱动器
铝道网  >  铝设备 >  铝加工分析检测设备  > 分析检测设备  > 161460-005四川
161460-005四川
1 元/个
  • 所在地:
  • 供货总量: 1
  • 发布时间:2024-12-10
洪健强 :18020768701
主营产品:Schneider ,Foxboro,Ovatin,Allen-Bradley,Siemens等各类工控产品,
欢迎来电咨询!
SVG 117741-001 BOARD GAS U ALARM SINGLE STEP
SVG 118870-001 PCB
SVG 120391 PIN 12.5
SVG 121-047 ASSEMBLY SONALERT
SVG 121-115 HEATER ELEMENT
SVG 121-180 PCB ASSY, THERMAL LOGIC TEMP CONT
SVG 121-188 BOARD STAGE TERMINAL
SVG 121-189 BATH-COOLING WATER
SVG 121-198 RTD, 3WIRE, 1/8SHEATH,1/2NP
SVG 121-336 CO****OL TEMPERATURE V1-6
SVG 121-56415-01 SERVO, SPIN CO****OLLER
SVG 122630-007 BOARD OVERTEMP "R" OFEN 16B
SVG 124421 VESTIBULE BLOCK
SVG 124422-001 GASKET
SVG 130-067 FLAT PANEL DISPLAY
SVG 130-130 AMP, ROTARY, YOKOGAWA, PARKER DM-SDDR-SR SERIES
SVG 130-131 REAV PLUS AMP, DRIVER, 300W
SVG 130-132 AMP DRIVER 800W
SVG 132-009 POWER SUPPLY-150 WATT
SVG 1322-058 VALVE, 2" BALL
SVG 138656-001 CHASSIS ASSY #2 BURN-OFF
SVG 14-0137-97 CABLE 1, TRACK CABLE
SVG 14-0138-97 CABLE 2, TRACK CABLE
SVG 141500-001 PCB CVD AUTOLOAD DOOR SENSOR
SVG 1420-091 PUMP, PERISTALTIC
SVG 146430-002 PCB, DCI, BOATLOADER
SVG 146558-001 POWER SUPPLY
SVG 146661-001 POWER SUPPLY
SVG 1495-0013 PANEL, LCD, COVER
SVG 154972-001 ASSY CONCE****IC SPIDER
SVG 157071-001 DRIVE ASSY
SVG 160342-001 GASLINE
SVG 16046 CHUCK 4.5 45 DEG V1-1
SVG 161403-016 PCB GAS INTERFACE MOTHERBOARD
SVG 161450-005 PCB GAS INTERFACE DAUGHTER
SVG 161460-005 DAUGHTER, PCB
SVG 161480-001 RELAY INTERLOCK BOARD
SVG 162075-001 GASLINE, INLET EXTENSION
SVG 162751-001 LINE, GAS INLET, H2 OXID SYSTEM
SVG 163246-002 GAS LINE
SVG 163952-001 BAFFLE SVG SIC BAFFLE
SVG 165539-001 CABLE,ASSY
SVG 166150-002 GAS LINE, UPPR-7RA
SVG 167029-002 LINE H20 SVG FLANGE H20
SVG 168050-001 PCB, C/B/B MOTION CO****OL
SVG 168309-002 MANIFOLD SVG OUTER MANIFOLD 1-4B
SVG 168352-001 HARNESS
SVG 168352-002 HARNESS
SVG 168352-003 HARNESS
SVG 168352-004 HARNESS
SVG 168352-005 HARNESS
SVG 168352-006 HARNESS
SVG 168482-001 BRACKET, MANIFOLD MTG
SVG 17-16938-01 KIT FLOW SENSOR/ CO****OL
SVG 17-16948-09 KIT,COATER PARTS
SVG 17-43336-01 KIT, RETRO INDXR
SVG 17-48133-01 STANDOFF M/F 4-40X2 1/4
SVG 17-62589-01 KIT, UPPER SHOCK ABSORBER, LH
SVG 17012-04 GLASS WAFER  150MM
SVG 170660-001 HARNESS
SVG 17215-02 CATCHCUP, TOP PIVOT
SVG 174722-001 POWER SUPPLY /-15DC
SVG 200-542 SLIDE 16 IN X 17 IN  TRAVEL STL
SVG 200-69867-02 AIRSLIDE TABLE, SMC P/N MXS12L-75-F9N
SVG 201-001 BRG 1/8" IDX5/16" OD SST
SVG 201-005 BEARING
SVG 201-007 BALL BUSHING SEAL 3/8"
SVG 201-017 BEARING,1/4 X 5/8
SVG 201-029 BUSHING .251X .374X .375D
SVG 201-032 BUSHING  BRASS  BRUSH STA
SVG 201-040 BEARING
SVG 201-144 BEARING, SHIELDED SPINDLE
SVG 202-010 BELT
SVG 202-023 O-RING
SVG 202-065 O-RING .103 X 1.674 ID VITON
SVG 202-286 BELT TIMING, 1/5P X 1/4 W 4
SVG 203-013 CLEVIS ASSEMBLY SPIN STA
SVG 203-019 CYLINDER POSITION
SVG 203-082 CYLINDER-AIR VP LID DRIVE
SVG 203-096 CYLINDER-AIR 1 1/16BORE X 1 STROKE
SVG 203-122 CYLINDER-AIR 3/4 BORE X 2.0 STROKE HUSKY
SVG 203-123 CYLINDER-AIR 1 1/8 BORE X 5/8 STROKE
SVG 203-148 CYLINDER,AIR,MWBI
SVG 20397-01 CHUCK-WAFER HPO/VP MODULES
SVG 204-020 BELT, CHAIN 103 PICTH
SVG 205-004 RING, RETAINING 1/4" SHAF
SVG 205-005 WASHER INPUT ****
SVG 205-062 SNAP RING INPUT ****
SVG 205-069 SNAP RING
SVG 205-412 TUBE COLLAR
SVG 206-983 UNION T 182 PFA
SVG 20881-01 CUP-CATCH BOTTOM
SVG 20884-01 CUP-CATCH-SHIELD
SVG 20885-04 SHIELD, 200MM
SVG 209-132 REG,100SISST
SVG 209-166 FLOWMETER,5-50GPH,316SST
SVG 210-015 GASKET WASHER
SVG 210-062 SEAL V-RING 3 1/8ID
SVG 2100-0005-0 PCB I/O MODULE MNTG RACK
SVG 213-167 FLOWMETER-BERB
SVG 213-218 VALVE  BALL 3/4FNPT PVC
SVG 213-237 VALVE,AIR,OPP,BELOWS,3/8
SVG 213-270 VALVE,DEV,W/SUCKBACK
SVG 213-309 VALVE,DEV,SUCKBACK
SVG 213-357 VALVE, SUCK BACK AMDS SERIES, CKD P/N AMDSZ0-X0387 2Z02, CLASS 2
SVG 213-362 VALVE, AIR SUCK BACK, M5
SVG 214-002 SPACER,1/8 X 3/16 X 1/8, SST
SVG 214-018 SPACER .250X .375X .375
SVG 214-024 SPACER
SVG 214-035 SPACER 1/4X3/8X3/32S
SVG 214-044 SPACER .125 IDX.187
SVG 214-065 SPACER
SVG 215-021 SHAFT, COUPLING, 1/4, TOR
SVG 215-033 ROLLPIN, BRU
SVG 216-073 CLAMP
SVG 217-224 MEMBRANE, 2.5 X 8.03 MICRONS, SUPERFOBIC CELGRAD, GROUP TYPE G60
SVG 217-56304-01 FILTER, 16 STK 0.1 MICRON, KALREZ
SVG 218131 PCB-CPU W EPROM DUV SYS 90
SVG 220-002 PULLEY MOTOR
SVG 220-005 PULLEY
SVG 220076 QUICK EXHAUST VALVE
SVG 224-039 FLOWMETER-0-10CC TEFLON DEV
SVG 224-052 FLOWMETER-SOLVENT
SVG 237500-114 MOTOR ASSY
SVG 245886-001 MEMORY PCB
SVG 2504-0020 FIBER GASKET
SVG 25087-60 CABLE   RS422  60
SVG 2522-0470 SLIP SLEEVE HOSE CLAMP
SVG 28-43013-02 MODULE,STACKED,VAPOR,PRIME
SVG 28-69749-01 ASSEMBLY, KIT 300MM FORKS, 1 SET W/ LEFT & RIGHT
SVG 2A551 CO****OL, LIQUID LEVEL SWITCH
SVG 300362-001 VALVE O-RING
SVG 301-006 VENTED SCREW W TUBE
SVG 31-69383-16 ROBOT MODULE
SVG 31-69878-01 ASSEMBLY, ROTORY MOTOR & RESOLVER
SVG 310-003 IDI CO****OLLER KEYPAD
SVG 311-101 SWITCH PRES/DIAP, DIFF/NO
SVG 311-135 POWER SUPPLY, 120V AC, 24V DC, 0.7A
SVG 311-208 CO****OLLER, WATLOW
SVG 313-035 VALVE, STOP SUCK BACK, MILLIPORE P/N INGENSP14
SVG 313-037 KIT, SPEED VALVE, MILLIPORE P/N INGN2SP49
SVG 38/2-989:1 MOTOR (PLESSY-KOPF)
SVG 38463-01 SPIN CHUCK, COATER 90 SER 200 MM
SVG 38465-01 SPIN CHUCK, DEV, 90 SER 200 MM
SVG 38525-01 TUBE-DRAIN
SVG 38530-01 RING-PRE-DISPENSE
SVG 4022.502.35174 RETICLE SENSOR
SVG 405460-001 MOTOR DC BRUSHLESS
SVG 4080 BASE
SVG 4120-0045 VMDOT START UP KIT
SVG 412725-001 ARM ASSY
SVG 412725-2080 PCB Z AXIS PIGGYBACK
SVG 42266-01 LEADSCREW END**** INDEXER
SVG 42639-01 NUT-LEAD HPO/VP
SVG 5300-0000 CALIBRATION PROBE M.DOT
SVG 5300-0010 CABLE
SVG 59120087 CRT 9" RETRO KIT
SVG 59283-02 CHUCK, SPIN, PEEK
SVG 600043-01 PCB ASSY SENSOR
SVG 600050-04 PROCESSOR PCB
SVG 600051-01 PCB ASSY ANALOG INPUT
SVG 600052-01 PCB
SVG 600053-01 PCB ASSY ANALOG OUTPUT
SVG 600054-01 DIGITAL INPUT PCB
SVG 600055-01 DIGITAL OUTPUT PCB
SVG 600056-01 PCB ASSY
SVG 600057-01 PCB ASSY
SVG 600057-02 PCB ASSY
SVG 600061-01 TERMINAL MOTHER BOARD
SVG 600064-01 PCB MCV-EC
SVG 600074-01 PCB STEP SIGNAL
SVG 600205-02 PCB
SVG 600211-01 CPU BOARD
SVG 600216-01 SENSOR, THETA EDGE IR, 5V, 40MA, HRNS ASSY
SVG 600252-01 CABLE, CASSETTE HARNESS
SVG 600263-01 ASSY ELEV DOOR
SVG 600345-02 OPTICAL SENSOR INTF PCB
SVG 600381-01 PCB
SVG 600391-01 ASSY MOTOR DRIVE
SVG 600391-01W WIRLIST MOTOR ELEVATOR
SVG 600400-01 PCB, ACE INTERFACE
SVG 600401-01 ASSY,ACE MOTHERBOARD
SVG 600402-01 ACE CONNECTOR INTERFACE
SVG 600404-01 PCB ASSY
SVG 600405-01 PCB,ASSY,FRONT,PANEL,DISPLAY
SVG 600463-01 BOAT LOADER
SVG 600463-02 BOAT LOADER
SVG 600495-01 PCB
SVG 600709-02 ASSY BEV SIDE ACCESS-200MM
SVG 600779-03 ASSY,HRNS,T/C SENSOR K TYPE
SVG 600967-01 PCB, ASSY, CASSETTE STATUS PNL
SVG 601259-01 GAS STATUS PCB
SVG 601259-02 PCB ASSY GAS STATUS PANEL II
SVG 601314-01 ASSY LIMIT SWITCH
SVG 601504-03 BOARD GIF 2 METAL ANNL 3-3C
SVG 601504-99 BOARD GIF 2 METAL ANNL 3-3C
SVG 602114-02 SWITCH,DOOR,BHU,N/LL
SVG 602668-04 CAROUSEL ASSY, DRIVE
SVG 602937-02U PCB VME, ANALOG I/O
SVG 602938-01 PCB 3 AXIS VME BUS (DMC530)
SVG 602947-01 SWITCH,PNEUMATIC PRESSURE
SVG 602993-01 ASSY,DOOR PLATE 200MM POLY
SVG 603098-01 SWITCH,WATER FLOW,S15Y
SVG 603702-01 LIGHT,REMOTE,IN-USE
SVG 603765-03 CABLE,VME/PROC,ASSY
SVG 603789-01 CABLE HT TORCH,R-TYPE
SVG 604122-09 PCB ASSY,VALVE OUTPUT
SVG 610262-01 PCB CONFIG, LCA BOARD
SVG 61420-02 DRAIN DEVELOPER 200MM, LEFT TRAYS PLASTIC, CUSTOM
SVG 61880-01 NOZZLE, TRIPLE DISPENSE 200
SVG 62322-01 KIT, PNEUMATIC VALVE
SVG 63460-01 200MM TONGUE CES
SVG 6480-0067 PHOS, CAU PCB
SVG 681-0181-009 SWITCH, MOD, TRANSDUCER
SVG 682 0176 011 REGULATOR, 0-125PSI, R364-02CK
SVG 682-0051-017 FLEXURE-GAUGE HEAD SVG 682-0051-017
SVG 68881-01 ARM, ID SUPPORT SST
SVG 690 8585 006 PCB-ASSY ELEVATOR A701 A702
SVG 690-0726-009 PCB ANALOG MULTIPLEXER
SVG 690-0730-R06 PCB A226 SVG 690-0730-R06
SVG 690-0744-004 SWITCH PANEL BRIGHT FIELD SVG A104
SVG 690-0745-004 PCB, SWITCH A105
SVG 690-2107-003 PAD, BRAKE, REAR WAFER
SVG 690-3333-001 AC POWER LAMP CO****OLLER
SVG 690-8044-002 PCB CARRIAGE DRIVE LOGIC A
SVG 690-8045-006 PCB CARRIAGE DRIVE LOGIC B
SVG 690-8055-003 PCB ACT TEST JUNCTION BD
SVG 690-8076-001 VALVE, SOLENOID, 3WAY
SVG 690-8256-002 PCB LVDT SIGNAL
SVG 690-9956-001 BRAKE CUP ASSY, MASK/WAFER STAGE
SVG 690-9979-001 FLEXURE-WAFER Y2-AXIS SVG 690-9979-001
SVG 69753-02 NOZZLE TRIPLE DISPENSER ROUNDMETER
SVG 701973-001 CYLINDER,AIR,COMPACT,BIMBA-FDR040.375-3F
SVG 739936-001 TIMING BELT
SVG 739960-001 PUSHBUTTON,MUSH,RED,SWITCH,EMO,KEY,RELEASE
SVG 7400-0060-01 WAFER TRAY
SVG 7400-0063-07 5" NEWSTYLE M-TRAY
SVG 752034-002 SLIDE, 210MM
SVG 763130-001 TEMP CO****OLLER
SVG 778006-001 MOTOR GEARHEAD ENCODER
SVG 794678-001 O-RING
SVG 8000-0245 PCB, FILTER OPTION BOARD
SVG 8000-1245 BEAM STOP ASSY
SVG 8000-1274 BEAMSTOP, CJ, HYT, M70
SVG 8000-1317 ASSY, KF40 BULKHEAD SWITCH
SVG 8000-1319 ASSY, KF40 SWITCH
SVG 8000-1320 ASSY, KF25, SWITCH
SVG 8000-1344 26 PIN BNC INNERLOCK
SVG 8000-1346 ASSY MODEL, 70 INTLK ADAPT
SVG 8000-1481 ASSY,MODEL 70E MAIN PREAMP
SVG 8000-1488 ASSY, 70E, STD LASER SOURCE
SVG 8000-1502 ASSY, PICKUP, CE, 80/100
SVG 80039D-08 PCB, INDEXER, INTERFACE
SVG 80054A PCB, TRANSISTOR BOARD
SVG 80054A-06 PCB TRANSISTOR BOARD
SVG 80089A PCB, INTERRUPTER SENSOR
SVG 80089A2-06 PCB, FLAT FINDER
SVG 80103D2-30 PCB, CPU 8800 CTR
SVG 80157F-01 PCB, ATS CO****OLLER
SVG 80164BB1-01H PCB, EXH, FLOW CO****OL
SVG 80166F-01 PCB, ****, CPU
SVG 80166F3-01 PCB, **** CO****OLLER
SVG 80184C PCB, VACUUM SENSOR BOARD
SVG 80184C2-02 PCB, VACUUM SENSOR
SVG 80214B PCB, TEMP SENSOR
SVG 80266B1-01 PCB, ****, CPU
SVG 80266B2-01 PCB, ****, CPU
SVG 80266B3-01 PCB, ****, CPU
SVG 80266BE-01 PCB, ****, CPU
SVG 815003-354 TUBE, TEFLON, PHASE, 1X26
SVG 815009-813 ANALYZER,OZONE, CELL
SVG 8210-0201-3 P.C. BOARD
SVG 851-8042-002 PCB,STOP/OVERLIM
SVG 851-8226-007 PCB, 4 AXIS COUNTER
SVG 851-8226-008 PCB, 4 AXIS COUNTER
SVG 851-8300-005 PCB, STD-44
SVG 851-8440-008 PCB, A5101
SVG 851-8440-009 PCB, A5101
SVG 851-8514-007 WAFER HANDLER INTERRUPT BOARD
SVG 851-8518-005 PCB
SVG 851-8541-004 PCB, A1303 STABLIZER
SVG 851-9547-009 RETICLE CASSETTE
SVG 851-9551-003 ASSY COARSE RET ANLR
SVG 851-9947-004 PCB, DMC BOOSTER AMPLIFIER
SVG 854-0168-001 OPTICAL ASSY
SVG 854-0185-002 SYMETRICAL CHARACTER RECOGNITION, CAMERAS, FIBER OPTIC LIGHT GUI
SVG 854-0194-001 OPTICAL ASSY
SVG 854-0346-001 OPTICAL ASSY
SVG 854-8306-003 PCB, AFA PREAMP/ADC 16 BIT
SVG 854-8306-007 PCB, AFA PREAMP/ADC 16 BIT
SVG 854-8306-008 PCB, AFA PREAMP/ADC 16 BIT
SVG 854-8307-001 PCB ASSY
SVG 854-9519-001 CASSETTE, RE
SVG 854-9532-002 CASSETTE, RE
SVG 854-9534-002 OPTICAL ASSEMBLY
SVG 858-4751-001 STG MOTOR PS-AMP RT-CF
SVG 858-8020-003 INTERFACE
SVG 858-8093-001 PCB
SVG 858-8140-003 PCB,FLOW,TRANSMITTER
SVG 858-8148-006 PCB
SVG 858-8148-007 PC BOARD
SVG 858-8150-001 FRAMELESS RETICLE HANDLER OPTICAL INTERRUPT
SVG 858-8163-003 PCB, R.H. PRO-LOGIC
SVG 859-0481-006 MODULE,SCREEN,MS2
SVG 859-0741-005 PCB, DSP MOTHERBOARD
SVG 859-0830-005 PMT CO****OL BOARD
SVG 859-0832-006 ROBITECH INTERFACE BOARD
SVG 859-0832-007 PCB
SVG 859-0871-002 PUMP
SVG 859-0928-006 PCB POWER AMP
SVG 859-0928-007 PCB, POWER AMP
SVG 859-0928-008 PCB POWER AMP
SVG 859-0942-004 PCB
SVG 859-3790-004 SENSOR, MODE/UL, POS, ASSY
SVG 859-5257-002 CO****OL PANEL
SVG 859-8027-004 PCB, DELIM, LOWER
SVG 859-8132-002 VIEWING POWER SELECT PANEL
SVG 859-8134-003 COIL
SVG 859-8218-002 PCB, ADC/ELPS INTERFACE
SVG 859-8278-004 P/C CARD CAGE ASSY, A1200
SVG 859-8341-004 EXPOSURE LAMP POWER SUPPLY
SVG 859-8364-001 PCB ASSY DC DISTRIBUTOR
SVG 859-8366-003 POWER SUPPLY
SVG 859-8366-004 POWERSUPPLY
SVG 859-8550-001 THRMSTOR,PROBE,ASY,RETSTG
SVG 859-9464-005 UNLOAD ARM ASSY
SVG 859-9512-004 WAFER LIFTER
SVG 8590844004 CABLE ASSY
SVG 864-0093-002 LENS
SVG 865-8010-005 DUAL CHANNEL ACQUISITION VME BOARD
SVG 865-8022-004 PCB
SVG 865-8027-002 PCB, DIFFERENTIAL A/D
SVG 865-8085-001 CONNECTOR BOARD ASSY
SVG 865-8095-002 CONNECTOR BOARD ASSY
SVG 866-8039-002 PCB, PO TUNING CO****OL BOARD
SVG 869-0036-001 CARRIER, TEST MASK, 869-0036-001 SVG
SVG 869-0084-002 CASSETTE-MASK ALUMINUM SVG 869-0084-002
SVG 869-0167-001 SENSOR, WFR OUTPUT, 869-0167-001 SVG
SVG 869-0566-001 COVER, PLSTC WAFER HANDLING, 28-1/2-IN L
SVG 869-0593-002 ARM, TRANSFER INPUT
SVG 869-0613-R01 MICROSCOPE SCAN ASSEMBLY FOR SVG MICRALI
SVG 869-2950-001 FLEXURE-PRALIGNER X-AXIS
SVG 869-8186-R07 PCB PREALIGNER I/O A703 I/O
SVG 869-8189-001 PCB MOTOR PREALIGN X-Y 12V
SVG 869-8223-001 PCB MICROPROCESSOR AND COPROCESSOR
SVG 869-8224-003 PCB COMPUTER BD
SVG 879-0006-001 AUTOAL, E10 W/OAX
SVG 879-0054-001 PROTEUS FLOW INDICATOR W/PCB
SVG 879-0054-002 WATER FLOW SWITCH ASSY, ILLUM
SVG 879-0055-002 PROTEUS FLOW INDICATOR W/PCB
SVG 879-0133-004 CASSETTE, RE
SVG 879-0439-001 PNEUMATIC SENSORS
SVG 879-8113-002 PCB, HARNESS ASSY AUTOCAL
SVG 879-8166-001 PCB,OUT/IN,SENS
SVG 879-8179-002 FLAT MONITOR (PIXELINK)
SVG 879-8210-001 SIGNAL CONDITIONER BOARD
SVG 879-8258-001 WAFER HANDLER INTERRUPT BOARD
SVG 879-8379-001 PCB
SVG 9000-0029 PCB, MATCHING NETWORK
SVG 900028-007 CIRCUITBREAKER  10A 2POL
SVG 900034-001 CIRCUIT BREAKER 1.2A
SVG 900869-030 CIRCUIT BREAKER
SVG 9010-0440B QUARTZ FAB (SCREW)
SVG 9010-0860 WELDEMENT,OPTION
SVG 9010-2031 RING
SVG 901544-003 THERMOSWITCH STUD MOUNT
SVG 9025-0138 WINDOW, SAPHIRE, 1/2" COATED
SVG 903899-004 RECTIFIER, 400V, 60A
SVG 903899-005 RETIFIER,SILC. CO****OLLED
SVG 904027-103 COLLAR DUST 251/277
SVG 904980-001 PCB (RC), BOATLOADER MOTOR DRIVE
SVG 905280-001 PCB (RC) BOATLOADER CLOSED LOOP
SVG 905944-001 SWITCH MICRO TENSIONER
SVG 906393-001 RUBBERGASKET
SVG 906638-001 ASSY, MNFD, TOP CHMBR 3
SVG 906649-001 VALVE, 3-WAY
SVG 907671-001 SEAT 12S VALVE. 063 ORIFICE
SVG 907793-002 HEATER MANOMETER
SVG 907881-001 PCB ASSY
同类产品
铝业通第2
洪健强
手 机:18020768701
电 话:-
传 真:---
