厦门海通华业科技有限公司
已认证
主营:PLC,模块,主板,触摸屏,DCS,变频器,CPU,驱动器
铝道网  >  铝设备 >  铝加工分析检测设备  > 分析检测设备  > 40035V0011江苏
40035V0011江苏
1 元/个
  • 所在地:
  • 供货总量: 1
  • 发布时间:2024-12-26
洪健强 :18020768701
主营产品:Schneider ,Foxboro,Ovatin,Allen-Bradley,Siemens等各类工控产品,
欢迎来电咨询!
LAM 855-010499-241 S/W, PLC FOR WVDS, CLASSIC, 9600 (NEW)
LAM 855-097626-001 HD DR,HPXU90,2 GB,NEXTSTEP  3.3
LAM 856-000080-001 KIT
LAM 856-009321-001 POWER SUPPLY, 15V, 10A
LAM 856-010350-001 KIT, RETO CLAMP PLUNGER EZ WA
LAM 856-010386-001 KIT,BACKSIDE COOL
LAM 856-017012-002 HEARTBEAT PCB RETROFIT KIT
LAM 856-017340-201 RESISTOR BANK RETROFIT
LAM 856-020267-014 MANIFOLD,HYT
LAM 856-090300-001 HARNESS LOADLOCK
LAM 856-093260-001 CASSETTE, LOADER,ERGO
LAM 856-094027-021 LOADER HINE ERGO 6"
LAM 856-210364-001 KIT, RTRFT, CA, MNMTR
LAM 856-347385-001 KIT,RETRO,STRPR PRESS RELIEF
LAM 856-482137-001 CONVECTRON GAUGE UPG
LAM 856-492721-001 KIT,UPG,1T PEN,ALL 4.1
LAM 856-9675-1 LIFTER, BIGFOOT RETRO
LAM 857-010330-001 DIT HOSE FITTING TCU
LAM 857-030904-001 KIT, WINDOW CLAMP
LAM 857-220781-005 KIT, EXHAUST BOTTOM
LAM 857-441449-001 KIT, BLOWOFF, GAS PNL
LAM 857-520115-080 KIT, CA, PM TO LONWORKS GB, 80 FT
LAM 865-0045-001 ALIGNER ASSY FRAMELESS RETICLE W/BPX
LAM 866-360231-012 KIT,RERO,PARX,9400
LAM 867-002936-101 KIT,RTRFT,BLOWS RTNR
LAM 867-017520-400 RETROFIT FOR UPS
LAM 89190-R1 GATE PLATE, VAT VAL
LAM 90-0001-003 WSHR,.26ID X .56OD X .06W
LAM 90-0036-001 SCREW SET
LAM 903003 S/V AIR-ACT 1/4-IN M
LAM 92-0001-008 SPACER, SHAFT, INPUT
LAM 92-0001-026 SPACER 1/4 X 1/2 X .062 THK OUTER R
LAM 920-003689-001 FTG, TUBE, CONN, 5/32TX10-3 (ESC LIFTER
LAM 920-006065-001 CONNECTOR, ML 1/2 TUBE X 3/8 NTP
LAM 920-006142-001 INSERT FITTING
LAM 920-008866-601 HOSE ADAPTOR
LAM 920-008930-001 ELBOW MALE 1/2TX3NPT
LAM 920-023672-001 SLEEVE (PACK OF 10)
LAM 920-060793-007 NUT TUBE FITTINGS
LAM 920-092571-005 TEE,UNION,PLUG-IN,3/8T
LAM 921-008908-001 INSERT, 5/8 TUBE ODX, 1/2 TUBE ID (PACK OF 10)
LAM 921-009488-002 CONNECTION MALE
LAM 921-009613-001 FITTING, CONNECTOR, STEMQUICK
LAM 931258600 COVER,RECEPTACLE BOX
LAM 950-007424-001 SCREW 3/8-10
LAM 955-008403-001 PADS, ARM, RUBBER, ORANGE (PACK OF 10)
LAM 955-009539-001 INSULATION TUBING X 1/2 18' WA
LAM 955-090225-001 PADS, ARMS, RUBBER, GREY (PACK OF 10)
LAM 955-093033-010 TBG,1/4 OD,FLRD W/FTGS,10 IN
LAM 955-L008403-001 PAD RUBBER OD=1/4 SILICONE
LAM 965-002686-001 PAD ARM SILICON ADHESIVE
LAM 986154-001 FILTER, MOD
LAM 990-004255-001 PCB, E/P VALVE, PNEUTRONICS
LAM 990-004321-001 PCB, PNEUMATIC 3&4
LAM 990-004321-002 PCB, CO****OL PNEUMATIC MOD
LAM 990-004357-001 PCB SOLENOID ASSY
LAM 990-004358-001 PCB SOLENOID ASSY
LAM 990-4321-001 PCB PNEUMATIC
LAM 996-S124346-001-00 THERMOSTAT, SET STA
LAM 996-S126228-001-0A NUT, TC
LAM 996-S130015-001-00 CRANK BOLT
LAM A778-010516R001 CHILLER,M&W TCU DUAL OPERATIONAL
LAM A853-00577-001 ASSY PHASE MAG DETECTOR
LAM A853-04109-1RB LIFTER ASSY EXIT
LAM AH-164-SLO11E3 SWITCH
LAM AH-164-TL5W11E3 SWITCH
LAM AS568-264PURFLUORO O-RING, BAFFLE PLATE UPPER
LAM AS568-265PURFLUORO O-RING, BAFFLE PLATE LOWER
LAM C114003 UNGLUE  ROLL
LAM C114105 WAFER STOPPER
LAM C313021 RACK BKT
LAM CCM-02 SEM1FLEX,COM,GAS,CNTL
LAM CDJ216-125-C73 CYLINDER (SMC)
LAM CDQ2B12-10DC CYLINDER
LAM CPR1-108937 VALVE, HELIUM
LAM D-VG VACUUM GAUGE
LAM DL-15-A-66 RING BOTTOM END F.LAM
LAM E021152 HEATER 120V45W 200MM
LAM E0309169 WPD-CPU
LAM EE-SPX-301 PHOTO MICRO SENSOR (M66)
LAM EE-SPY-402 PHOTO MICRO SENSOR (D13)
LAM EP200MMC-HV MONOCHROMATOR DETECTOR
LAM F121013 BALL SCREW
LAM GBZH830321T03 BUSHING ID 4.78 x OD 9.52
LAM GBZH830322T03 BUSHING ID 6.37 x OD 12.68
LAM GBZH830324T03 BUSHING ID 12.73 x OD 19.05
LAM J113062 CUTTER SHAFT CAP
LAM L147-Q664H CATHODE
LAM LC107G-24V-1/100 DC MOTOR
LAM MB-18205 SHOCKLESS STATIC BAR
LAM N122007 TABLE
LAM NAX1023Z BEARING
LAM SFC480CMC-4V4C2 MFC CL2 300 SCCM
LAM T120AR1U1 THERMAL PROTECTOR (E4205)
LAM VT325V-035GS SOLENOID VALVE (SMC)
LAM ZT5510E-C7R5S1V3 PCBA,CPU,200 MHZ,128M RAM
LAMBDA 004731327 IHC ARC POWER SUPPLY EMS 150-7-2-D
LAMBDA 004731339 IHC ARC POWER SUPPLY EMS 40-25-2-D
LAMBDA 02010FM POWER SUPPLY
LAMBDA 77911523 FORCE BOARD
LAMBDA 876-5038 POWER SUPPLY
LAMBDA 906650-001 POWER SUPPLY -5V
LAMBDA 9802R60870 POWER SUPPLY
LAMBDA A9146 POWER SUPPLY
LAMBDA CED106-0089TF INVERTER DUAL ? NVLS TDEAT CANISTER
LAMBDA CEDNOV-0157CY TUBE PROCESS INJ.
LAMBDA CEDNOV-0295TF CABLE ASSY
LAMBDA CEDNOV-0297TF ASSY HARNESS
LAMBDA CEDNOV-356TF SPINDLE MOUNTING ASSY
LAMBDA E60601 POWER SUPPLY (NS-MEL-075)
LAMBDA EC-11-5 POWER SUPPLY
LAMBDA ED-4-1205 POWER SUPPLY
LAMBDA ED-5-0512 POWER SUPPLY
LAMBDA ES-8-5 POWER SUPPLY
LAMBDA ES-9-24 POWER SUPPLY
LAMBDA ES-9-5 POWER SUPPLY
LAMBDA ET-4A POWER SUPPLY
LAMBDA EWS100-24 POWER SUPPLY 24V 4.2 AMP
LAMBDA EWS15-12 POWER SUPPLY
LAMBDA EWS15-24 POWER SUPPLY
LAMBDA EWS15-5 DC POWER SUPPLY
LAMBDA EWS150-28 PWR SUP /-28VDC 5.4A
LAMBDA EWS25-24 POWER SUPPLY DC24V 1.2A (ZONE UNIT)
LAMBDA EWS25-5 POWER SUPPLY DC24V 1.2A
LAMBDA EWS300-24 POWER SUPPLY, 24V-14A
LAMBDA HK-10-24 PC BOARD
LAMBDA HK-7-5 POWER SUPPLY
LAMBDA HK50A-24/A PWR SUPPLY (ALARM)
LAMBDA HR-11 POWER SUPPLY
LAMBDA HR-11C-12 POWER SUPPLY
LAMBDA HR-12-24 POWER SUPPLY
LAMBDA HR-12F-24 POWER SOURCE
LAMBDA HR-12F-5 POWER SUPPLY
LAMBDA HR-9 SWITCHING REGULATOR
LAMBDA LCS-A-120 REGULATED POWER SUPPLY
LAMBDA LDS-X-5-OV REGULATED POWER SUPPLY, 5V
LAMBDA LFS-41-15 REGULATED POWER SUPPLY
LAMBDA LFS-42-24 POWER SUPPLY, LAMBDA, 24V
LAMBDA LFS-42-24-K REGULATED POWER SUPPLY
LAMBDA LFS-43-5 REGULATED POWER SUPPLY
LAMBDA LFS-48-12 POWER SUPPLY
LAMBDA LFS-50-5-43641 REGULATED POWER SUPPLY
LAMBDA LIS-3I-12 REGULATED POWER SUPPLY
LAMBDA LND-W-152 POWER SUPPLY, REGULATED
LAMBDA LNS-P-24-40066-4 REGULATED POWER SUPPLY
LAMBDA LNS-Z-12 POWER SUPPLY /- 12VDC 115/230 INPUT
LAMBDA LRS-50-I5 POWER SUPPLY
LAMBDA LRS-54M-12 REGULATED POWER SUPPLY
LAMBDA LRS-55V-24 REGULATED POWER SUPPLY,REV-H
LAMBDA LRS-55V-5 REGULATED POWER SUPPLY
LAMBDA LRS-56-24 POWER SUPPLY
LAMBDA LS-8A-15 POWER SUPPLY
LAMBDA LSS-36-5 POWER SUPPLY 5VDC, 5A
LAMBDA LSS-37-24 POWER SUPPLY 85-132 VAC 70W
LAMBDA LSS-37-5 REGULATED POWER SUPPLY
LAMBDA LSS-38-12 POWER SUPPLY DC 12VOLT
LAMBDA LSS-38-5 POWERSUP, 5V, 20A
LAMBDA LSS-39-24 POWER SUPPLY, 24V 6.5A
LAMBDA LST-37-144 POWER SUPPLY
LAMBDA LUS-11-12 POWER SUPPLY
LAMBDA LUS-11-5 POWER SUPPLY
LAMBDA LUS-8A-12 POWER SUPPLY
LAMBDA LUS-8A-5 POWER SUPPLY
LAMBDA LUT-6-5152 PWRSUP,SWITCHING,5V,I15VD
LAMBDA LWS-294-5 POWER SUPPLY
LAMBDA LWT50H-522 POWER SUPPLY
LAMBDA NND15-1212 POWER SUPPLY
LAMBDA PFC0300-3AH POWER SUPPLY, LAMBDA, LOGIC
LAMBDA SVQ200-1 POWER SUPPLY,5V,24V, /- 12V
LAMBDA VHA-AA65-270044 POWER SUPPLY
LAMBDA VHR-10 POWER SUPPLY  -12 VOLTS  ADVANTEST
LAMBDA VHR-10-15 POWER SUPPLY
LAMBDA VHR-10-24 POWER SUPPLY, DC, SWITCHING REGULATOR
LAMBDA VHR-11-36 POWER SUPPLY, DC
LAMBDA VHR-9-12 POWER SUPPLY
LAMBDA VHR-9-12/5G POWER SUPPLY
LAMBDA VHR-9-15 POWER SUPPLY
LAMBDA VHR-9-24 POWER SUPPLY
LAMBDA VHR-9-36 POWER SUPPLY
LAMBDA VHR-9-5 POWER SUPPLY
LEICA 020-600.028-005 HALTER HOLDER, ARM REST BRAC
LEICA 1***请点击商铺导航 联系我们***00 POWER SUPPLY, ELECTRIC
LEICA 1***请点击商铺导航 联系我们***00 ZLAM MODULE
LEICA 1***请点击商铺导航 联系我们***00 SOCKET
LEICA 11504070 HOUSING, LAMP 106Z
LEICA 1156511-M054 TWEEZER WIRE
LEICA 1156516-EA01 WAFER ALIGNMENT MOTOR
LEICA 11572071 MECHANICAL STAGE
LEICA 11LEP73000201 POWER SUPPLY, ELECTRIC
LEICA 11LEP73000400 BOARD
LEICA 11LEP73000500 PCB, MOTOR CO****OLLER
LEICA 11LEP73000921 VACUUM WAND, HANDLER
LEICA 11LEP73A00014 CABLE F/VAC, STAGE, OR MACRO
LEICA 11LEP99M012 SERVICE KIT, ROBOT
LEICA 16302311311 PCB, SERVO CO****OL POLY-88
LEICA 16603031354 TRANSFORMER, POLY-88
LEICA 301-305.189 CABLE
LEICA 301-305.202-000 PCB, CPU2
LEICA 301-360.055-000 PCB, MASTER MODULE
LEICA 301-360.151-000 REVOLVER BOARD
LEICA 301-360.180-000 PCB, DIAPHRAM, SENSOR
LEICA 301-360.208-000 MOTOR, DARK CAP
LEICA 301-364.033-000 PREALIGNER SENSORIC 2
LEICA 301-364.076-000 VOLTAGE CO****OLLER
LEICA 301-364.086-000 INTERFACE 8XV24
LEICA 301-364.087-000 PCB, INTERFACE 8XV24
LEICA 301-365.050-000 REGULATOR, P5/P24 LEITZ
LEICA 301-365.052-000 PCB, POWER BOARD 2PM15
LEICA 301-365.054-000 PCB, ELKO BOARD
LEICA 302-050.125-006 TRANSMISSION MOTOR (PA)
LEICA 302-050.129-028 TRANSMISSION MOTOR (PA)
LEICA 302-050.138-001 MOTOR DARK LID
LEICA 5613-EA02 MOTOR
LEICA 56511-EA07 MAIN PURATOR MOTOR (LEICA)
LEICA 56513-EA02 MOTOR (LEICA)
LEICA 56522-EA03 CASSETTE ROTATE MOTOR
LEICA 567016 OBJECTIVE 20X
LEICA 80046 PCB, INTERFACE 8XV24
LEICA 8013356 CO****OLLER, BUTTON
LEICA RW654311201 PCB TELEMATIC 2
LEICA RW654311202 LAMP CO****OL
LEICA RW654311208 POWER SUPPLY
LEICA RW654311209 PCB
LEICA WED8501002 MASTER MODULE
LEICA WED8501003 POWER PACK, 24V
LEICA WED8501006 LINEAR-MODULE
LEICA WED8501011 FRONT-PANEL
LEICA WED8501012 MASTER MODULE (MACROSPEC)
LEITZ 73000 805 PCB, FLNOF FLAT FINDER 73000 805 I-LOADE
LEITZ 73000400 PCB CPU CO****OLLER
LEITZ 73000600 PCB, DAIO 73000 600 I-LOADER
LEITZ BD61F MICROSCOPE LENS
LEYBOLD 017-010-G1 INFICON QUADREX 100 VIDEO CPU CO****OL
LEYBOLD 0730-01040 TURBO CO****OLLER NT340
LEYBOLD 100ISO-K PORT GAUGE
LEYBOLD 10176 FILTER CHEMICAL CFS16-25 FOR BCS25 PUMP
LEYBOLD 11635 DOWEL.188X5.SS
LEYBOLD 16504REV ION SOURCE,REPLACEMENT
LEYBOLD 18972 FILTER ELEMENT
LEYBOLD 19122 PCB OPTIC INTERCONNECT
LEYBOLD 200-09-086 PIN
LEYBOLD 200-30-777 CABLE
LEYBOLD 200-60-465 CABLE
LEYBOLD 200-60-466 CABLE,CONVERTER,MAG
LEYBOLD 228885 ION SOURCE
LEYBOLD 238781 CARD,SIGNAL,TOWER,CTRL
LEYBOLD 239-73-058 GASKET, OIL
LEYBOLD 298-23-B2 VALVE, RIGHT, ANGLE, KF40
LEYBOLD 428-24-002 FLAME ARRESTOR
LEYBOLD 529-049 THERMOTRON TR 111 ROT
LEYBOLD 55110202 FILTER
LEYBOLD 600-1002-P15 CABLE
LEYBOLD 600-1003-P1 CABLE
LEYBOLD 600-1098-P1 TSP POWER CABLE
LEYBOLD 72211001 SIGHT GLASS
LEYBOLD 8080-260K001 ABSORBER KIT
LEYBOLD 850-147-G1 PCB, PIRANI, MODU
LEYBOLD 850-200-G1 IG3 VACUUM GAUGE
LEYBOLD 859-0943-002 GAUGE,CAP,PRB,ASSY,Q25
LEYBOLD 88256 DISC, SEALING, DN
LEYBOLD 88708 SPACER 250DN ISO-K
LEYBOLD 88708-R95 CTR RING-DN25 88708 EATON #3500506
LEYBOLD 896-30-B1 ADAPTOR
LEYBOLD 898507 O RING KIT
LEYBOLD 899218 TURBOTRONIC NT 450
LEYBOLD 900-085-P1 HEATING SLEEVE, 117V, 64W
LEYBOLD 901-200-G3 QUADREX, 200 SCU
LEYBOLD 901-200-G4 POWER SUPPLY INFICON RGA
LEYBOLD 901-200-G5 QUANDREX 100SCU
LEYBOLD 908-140-G1 CIS CO****OLLER (SENSOR HEATER)
LEYBOLD 910-181-605 DISC, SEALING
LEYBOLD 911-040-G15 RS 485 CABLE, W/ Y CABLE
LEYBOLD 911-040-G30 RS 485 CABLE, W/ Y CABLE
LEYBOLD 911-045-G2 PCB INTERFACE CARD
LEYBOLD 911-059-G1 TRANSPECTORWARE, MULTI SENSOR
LEYBOLD 912-403-G2 SENSOR, 100 AMU EM/FC, MODEL# H100M
LEYBOLD CETNO 40035V0011 RF TURBO CO****OLLER
LEYBOLD CFS16-25 CHEMICAL FILTER WITH SAFETY ISOLATION VALVE
LEYBOLD DP-510-LV LEYBOLD VACUUM FILTER
LEYBOLD NT340M TURBO CO****OLLER 340 W/CABLES
LEYBOLD NT450 TURBO VAC
LEYBOLD PPL-18996 5"OIL FILTER
LEYBOLD PPL-18999 FILTER PRECISION 1.6 OIL
LEYBOLD S33-1222-23 COVER,BELLOW,A,REV3
LEYBOLD S33-335 ELCTRD, UPR, SUPER FINE GRAPHITE
LEYBOLD S33-915 SHIELD, DEPO, 85-2, REV 3
LEYBOLD TSPTH100 TRANSPECTOR (NEW)
LKT 900-0173-00 IN POSITION SENSOR
LKT LM0021 AMP, FLL/1/2, DRVR, SPLY,PWR
LKT S202-0052-00 CLAMP (BTM-PCO-100V)
LKT S350-0059-00 HIGH SPEED LINK MASTER CO****OLLER INTERF
LKT S415-0014-00 LKT SUCTION CUP VCAS-B15
LKT S501-8710-01 BALL DEVICE NEST ( 3X7 PRESCOTT-T )N5
LTX 033-9020-97 PCB, DPAG3, 4MEG
LTX 033-9140-07 PCB, PMU
同类产品
洪健强
留言咨询
