厦门海通华业科技有限公司
已认证
主营:PLC,模块,主板,触摸屏,DCS,变频器,CPU,驱动器
铝道网  >  铝设备 >  铝加工分析检测设备  > 分析检测设备  > 15-00511-00北京
15-00511-00北京
1 元/个
  • 所在地:
  • 供货总量: 1
  • 发布时间:2025-01-02
洪健强 :18020768701
主营产品:Schneider ,Foxboro,Ovatin,Allen-Bradley,Siemens等各类工控产品,
欢迎来电咨询!
NOVELLUS 04-714054-01 SHIELD,DARK SIDE
NOVELLUS 04-716099-01 ISO VLV 1X10 VAT
NOVELLUS 04-716197-01 COLLIMATOR 1 X 1 5/8 INCH
NOVELLUS 04-716386-01 ASSEMBLY POU FILTER/GASKET
NOVELLUS 04-716610-01 SHIELD UPPER COLLIMATOR
NOVELLUS 04-716630-04 DEPOSITION SHIELD
NOVELLUS 04-716733-01 SPRING L/L RAM SHIELD
NOVELLUS 04-716948-04 SHIELD HEATER 8INCH CLAMPLESS
NOVELLUS 04-717507-01 WEIGHTED CLAMP (CLEANED)
NOVELLUS 04-717508-02 PIN PRECISION AL203 CERAMIC
NOVELLUS 04-717921-03 RING
NOVELLUS 04-718616-02 AY FLEX TUBING
NOVELLUS 04-719408-03 SWITCH BRASS PROTEUS FLOW .25GPM
NOVELLUS 04-719408-04 SWITCH FLOW PROTEUS 2.56 GPM
NOVELLUS 04-720173-01 C****LR,V250 W/O CBL
NOVELLUS 04-720587-01 SHIELD CERAMIC TABLE
NOVELLUS 04-720751-01 CARTRIDGE H20 FILTER
NOVELLUS 04-720954-01 KIT, SEAL
NOVELLUS 04-720954-11 GATE
NOVELLUS 04-722260-03 CONCE****ATOR
NOVELLUS 04-722417-01 RING
NOVELLUS 04-722842-01 KIT UPGRADE AIR CYL
NOVELLUS 04-730718-01-3 SHIELD
NOVELLUS 04-731601-02 SHIELD (CLEANED)
NOVELLUS 04-731602-02 SHIELD (CLEANED)
NOVELLUS 04-732004-01 TUBE,INSULATOR
NOVELLUS 04-732026-02 CABLE ASSY
NOVELLUS 04-733008-01 ARM, HOLDER
NOVELLUS 04-8120205-00 KIT,OEPD,DUAL,STD ALTUS
NOVELLUS 05-00007-00 PM,KIT,REACTOR CHAMBER
NOVELLUS 05-00009-00 KIT PM POU/SI FILLTER
NOVELLUS 05-00011-00 PM KIT GAS FEED-THRU
NOVELLUS 05-00023-00 PM KIT SEMI ANNUAL
NOVELLUS 05-00066-00 KIT PM REACT 200MM
NOVELLUS 05-00077-00 KIT PM ROBOT SEALS
NOVELLUS 05-00108-00 PM KIT, LOAD LOCK FILTERS C1-W
NOVELLUS 05-00110-00 PM KIT TEE SEALS C1W
NOVELLUS 05-05028-05 DC-DC CONVERTOR CYMER
NOVELLUS 05-10347-00 KIT PM N2FILTER1
NOVELLUS 05-10348-00 KIT, PM T-SEAL
NOVELLUS 05-124534-00 KIT O-RING SPEED CHAMBER
NOVELLUS 05-126872-00 KIT, CPEC, 200MM NOTCHED
NOVELLUS 05-14-067-00 V-BELT (POSITIONING)
NOVELLUS 05-3332 EXTENDER TOP COVER SAPPHIRE PL
NOVELLUS 05-50002-00 KIT, FILTER, 0.05 MICRON
NOVELLUS 05-50014-00 WATER FLOW S/W
NOVELLUS 05-50020-00 VACUUM BOX KIT
NOVELLUS 05-50033-00 KIT, CASSETTE HOOKS/SENSORS
NOVELLUS 05-50045-00 KIT ROTATION DRIVE
NOVELLUS 05-50069-00 KIT ROTATION DRIVE
NOVELLUS 06-0150 QTZ PIN
NOVELLUS 06-08140-00 CERAMIC RING
NOVELLUS 06-2605 KEY ISOLATION PLATE AL
NOVELLUS 06-2624 PLATE TOP UPPER
NOVELLUS 06-2625 PLATE BOTTOM
NOVELLUS 06-2640 SPOOL, QUARTZ
NOVELLUS 06-2654 ORIFICE,BOTTOM SAPPHIRE,ASTEX
NOVELLUS 06-2725 SHOWER HEAD,TUBE 1.83ID
NOVELLUS 06-2726 SHOWER HEAD,BOTTOM,SAPPH
NOVELLUS 062-00016-00 FLAG
NOVELLUS 07-20216-01 LEAD NUT ANTI-ROTATION
NOVELLUS 0700-700837 GASKET, PLATE COVER
NOVELLUS 0700-717454 DELRIN RING, .590 THK
NOVELLUS 0700-717577 SEAL, SLINGER SPIN ARM DELRIN
NOVELLUS 0700-727372 SEAL, SLINGER
NOVELLUS 0710-110107 SWITCH SELECTOR CO****OL UNIT(IDEC ABN1ZC1)
NOVELLUS 0710-120033 SWITCH SELECTOR CO****OL UNIT(IDEC TK1557 ASN33ZC6)
NOVELLUS 0710-717547 CLAMP, U BAND UP RING INTG PAD
NOVELLUS 0710-727158 CONNECTOR, SLURRY SHIELD RING
NOVELLUS 0710-738898 SHEET, ABRASIVE CND BLADDERLES
NOVELLUS 0720-111545 RING, CYLINDER WAFER BELL COUP
NOVELLUS 0720-700370 MOUNT, BULKHEAD PANEL
NOVELLUS 0720-717415 MOUNT, WAFER CARRIER
NOVELLUS 0720-718327 RING,STRIP BUMPER
NOVELLUS 0730-700047 BUSHING
NOVELLUS 0750-700181 CYLINDER,ROTATE
NOVELLUS 0750-717491 CYLINDER,AIR,GAARD,ARM
NOVELLUS 0790-738891 BASE, PAD BLADDERLESS COND.
NOVELLUS 08-19891-026 SHIELD UV LARGE CLEAR
NOVELLUS 08-19891-027 WINDOW VIEWPORT QUARTZ T LARGE 5-7/8 X
NOVELLUS 08-21006-030 WINDOW VIEWPORT GLASS ASPR
NOVELLUS 08-21427-006 WINDOW QUARTZ EPD
NOVELLUS 08-22233-010 WINDOW VIEWPORT QUARTZ REAR (MCPAC 150)
NOVELLUS 08-22233-011 WINDOW UV SHIELD REAR MCPAC 150
NOVELLUS 08-22249-001 GATE VALVE
NOVELLUS 08-22434-001 WAFER MANIHOLDE ASSY
NOVELLUS 08-22434-051 COLLIMATOR OXIDE
NOVELLUS 08-22816-006 PLATE ADAPTER
NOVELLUS 08-24258-000 SUBSTRATE FAB FLAT BARE 150MM
NOVELLUS 08-24747-020 BELLOWS LIFTER R I E
NOVELLUS 08-30293-081 CLAMP CAP
NOVELLUS 08-34733-000 SUBSTRATE ASPR-CLL 125MM
NOVELLUS 10-00033-00 BACKFILL FILTER
NOVELLUS 10-00034-00 WELDMENT, GAS TUBE
NOVELLUS 10-00036-00 GAS LINE
NOVELLUS 10-00172-00 LINE TEFLON PIPE SIH4
NOVELLUS 10-00223-00 TUBE ASSY, .007 INJECTOR
NOVELLUS 10-00285-02 TUBE-LONG SHWR COOL
NOVELLUS 10-00346-02 TUBE ASSY
NOVELLUS 10-00360-00 DEGAS BY-PASS TUBE ASSY
NOVELLUS 10-00376-00 ADAPTER, 1/8" VCR MALE TO LFC
NOVELLUS 10-00416-00 TUBE,BOTTOM
NOVELLUS 10-00417-00 TUBE,UPPER
NOVELLUS 10-00418-00 TUBE,LOWER
NOVELLUS 10-00419-00 TUBE,UPPER
NOVELLUS 10-00420-00 TUBE,LOWER
NOVELLUS 10-00421-00 TUBING, PURGE LINE, 1/16"
NOVELLUS 10-027392-00 Tube Divert for 8 channel box
NOVELLUS 10-029376-00 TUBE ASSY D MAN/CRYO BRK
NOVELLUS 10-042661-00 TUBE ASSY,MANIFOLD B&E
NOVELLUS 10-046842-00 C1W H MANI. LOWER
NOVELLUS 10-046843-00 C1W H MANI. UPPER
NOVELLUS 10-046844-00 C1W MOD MANI. UPPER
NOVELLUS 10-046845-00 C1W STO INLET MAN
NOVELLUS 10-046849-00 DD GASBOX STNO FILTER WELD
NOVELLUS 10-046851-00 DD GASBOX STN0 OUTLET WELD
NOVELLUS 10-046853-00 DD GASBOX STNO AR INLET WELD
NOVELLUS 10-046854-00 DD GASBOX STNO GAGE WELD
NOVELLUS 10-051632-00 TUBE ASSY,SHORT SPOOL,NUPRO
NOVELLUS 10-053060-00 TUBE ASSY PRESSURE CO****OL
NOVELLUS 1077642-71 RF GENERATOR CABLE
NOVELLUS 12-8872-054 ASSY,CBL,L&R WAFER SENSE
NOVELLUS 13-332016-00 NUT,WING,3/8-16
NOVELLUS 13-46870-01 CRESENT PIN CARRIAGE
NOVELLUS 13-8082-039 ROLLER, END CAP SUPPORT DUA
NOVELLUS 13-8092-337 SCREW O****AK LEAD W/NUT V3-2
NOVELLUS 13-8872-027 BLOCK,STOPPER,LOCATOR
NOVELLUS 1420-717038 RING,WEAR,PBT
NOVELLUS 1420-717052 RING, TOP CLAMP
NOVELLUS 15-00019-02 FLANGE, BLANKOFF, ALUM
NOVELLUS 15-00068-01 PADDLE ASSY, 150MM
NOVELLUS 15-00126-00 BRACKET
NOVELLUS 15-00311-00 NICKEL CAP NUT
NOVELLUS 15-00341-00 NICKEL HEX HEAD BOLT, 1/4-20 THREAD
NOVELLUS 15-00368-00 GENEVA DRIVE FLANGED SHAFT
NOVELLUS 15-00371-00 NICKEL 1/4-20 HEX NUT
NOVELLUS 15-00391-00 BUSHING, CERAMIC UPPER
NOVELLUS 15-00403-00 WTM UPPER ARM FIXTURE(TWO
NOVELLUS 15-00413-00 SPLINE ASSY THRUST WASHER
NOVELLUS 15-00416-00 SPACER, VACUUM (4IN)
NOVELLUS 15-00480-00 GENEVA DRIVER
NOVELLUS 15-00501-00 COUPLER OAR NUT V4-6
NOVELLUS 15-00511-00 SPACER ROTATION SHAFT
NOVELLUS 15-00539-00 SEAL,COVER
NOVELLUS 15-00554-31 SHIM, HEATER, 0.031" V-TYPE
NOVELLUS 15-00556-01 BRKT,DISCON
NOVELLUS 15-00578-00 SLEEVE, FLANGED, AC FEEDTHRU, CERAMIC
NOVELLUS 15-00600-00 SCREW 15-00600-00
NOVELLUS 15-00641-00 SHAFT, 3/8 ROT. DRIVE
NOVELLUS 15-00655-00 SINDLE ALIGN BLOCK
NOVELLUS 15-00686-00 FEEDTHRU WASHERS
NOVELLUS 15-00688-00 WASHER, FEEDTHRU, 1/2" ID, ALUM
NOVELLUS 15-00702-00 FORK,TOP PLATE
NOVELLUS 15-00774-00 BKT,ADAPTOR-LEMO
NOVELLUS 15-00830-00 FITTING 90 DEGREE 3/8 TUBE
NOVELLUS 15-00835-00 PLATFORM - LIFT PIN WCVD
NOVELLUS 15-00921-00 COLLAR FITTING
NOVELLUS 15-00928-00 CLAMP OUTER RING
NOVELLUS 15-00931-00 PLATE, RING LIFT, EXCLUSION OPTION
NOVELLUS 15-00935-00 SCREW-10-32X.50 LG N
NOVELLUS 15-00943-00 CLAMP, HEEL
NOVELLUS 15-00944-00 CLAMP, TOE
NOVELLUS 15-00975-00 LIFT PIN LOAD ****
NOVELLUS 15-01022-00 PLATE R.F DIST, COPPER
NOVELLUS 15-01036-00 Bracket
NOVELLUS 15-01063-00 BRACKET, PADDLE, 200MM
NOVELLUS 15-01085-02 BRACKET,FRONT,RIGHT
NOVELLUS 15-01101-00 HUB, WAFER INDEXER 8"
NOVELLUS 15-01103-00 SHAFT,RING,LIFT,INNER
NOVELLUS 15-01136-00 BKT,ARM CASSETTE
NOVELLUS 15-01137-00 BLANK OFF, VERITY EP
NOVELLUS 15-01139-00 RING, WINDOW
NOVELLUS 15-01142-00 WINDOW, ROUND
NOVELLUS 15-01160-00 Bracket, WOPS Sensor
NOVELLUS 15-01163-00 BRACKET REAR CASSETTE V4-3
NOVELLUS 15-01167-00 BRACKET ARM/PADDLE V3-6
NOVELLUS 15-01169-00 CLAMP,TUBE-DUAL
NOVELLUS 15-01170-00 BRKT,DUAL
NOVELLUS 15-01175-00 BLADE REAR CASSETTE HOLDER
NOVELLUS 15-024198-00 CERAMIC RING
NOVELLUS 15-024611-00 PADDLE 200MM
NOVELLUS 15-024881-00 FORK END CAP
NOVELLUS 15-024924-01 CERAMIC CLAMP
NOVELLUS 15-024924-02 CERAMIC CLAMP
NOVELLUS 15-027004-00 PLUG, COVER, HEATER, SCREW
NOVELLUS 15-028207-00 NUT, SEAL RETAINER
NOVELLUS 15-029071-00 ADAPTER XRING, LOCATOR
NOVELLUS 15-029506-00 Flange, Verity, Endpoint
NOVELLUS 15-029601-00 BRACKET MTG UPS BROOKS 5866
NOVELLUS 15-029856-00 EVAPORATOR BODY, CVD TIN
NOVELLUS 15-032577-02 PIN,SPEED ESC FR/DC
NOVELLUS 15-033198-00 ROD, CERAMIC, PEDESTAL
NOVELLUS 15-033385-00 RING DOME BASE
NOVELLUS 15-033755-00 TOOL ALIGN INLIGNER PADDLE
同类产品
洪健强
留言咨询
