厦门海通华业科技有限公司
已认证
主营:PLC,模块,主板,触摸屏,DCS,变频器,CPU,驱动器
铝道网  >  铝设备 >  铝加工分析检测设备  > 分析检测设备  > 21-00052-01天津
21-00052-01天津
1 元/个
  • 所在地:
  • 供货总量: 1
  • 发布时间:2025-01-02
洪健强 :18020768701
主营产品:Schneider ,Foxboro,Ovatin,Allen-Bradley,Siemens等各类工控产品,
欢迎来电咨询!
NOVELLUS 15-034084-02 SUPPORT, HOIST, UPPER
NOVELLUS 15-034104-00 COOL **** ASSEMBLY
NOVELLUS 15-034532-01 WINDOW, PANEL
NOVELLUS 15-034848-00 HUB LOWER INDEXER
NOVELLUS 15-034849-00 RETAINER, SEAL
NOVELLUS 15-034852-00 SPACER, BUSHING
NOVELLUS 15-034964-00 BEARING BROOKS ROBOT WRIST
NOVELLUS 15-038324-00 SHIELD PESTAL LEAD WIRE
NOVELLUS 15-041085-00 RING,GUARD,200MM,FLATTED
NOVELLUS 15-041335-00 TOOL,ALIGN, 200MM
NOVELLUS 15-042148-00 PLENUM, PURGE, TOP
NOVELLUS 15-042159-00 TUBE, CERAMIC
NOVELLUS 15-042166-00 SPINDLE WHEEL BOTTOM PLATE
NOVELLUS 15-042167-00 SPINDLE WHEEL TOP PLATE
NOVELLUS 15-042256-00 FINGER, FORK, CERAMIC, LOW CONTACT
NOVELLUS 15-042268-00 WINDOW, ETCH RESIST, QUARTZ
NOVELLUS 15-042271-00 PLEXI GUARD
NOVELLUS 15-045534-00 PLUG HOLE RF DIST BOX
NOVELLUS 15-046056-00 BOLT 1/4-20X1.0
NOVELLUS 15-046123-00 CLEVIS, HOIST ACTUATOR
NOVELLUS 15-046857-00 DD GBOX STN0 MFC MNT PLATE
NOVELLUS 15-046858-00 DD GBOX STN0 MFC MNT BRKT
NOVELLUS 15-051711-25 TUBE,INJECTOR,2.500
NOVELLUS 15-052614-00 TONG, RINGLIFT 200MM
NOVELLUS 15-054595-00 SCREW 1/4  28 GUIDE CERAMIC
NOVELLUS 15-055720-00 SPACER BUSHING
NOVELLUS 15-101294-00 SPING, CENTER
NOVELLUS 15-10324-00 BUTTON,PIN (CERAMIC)
NOVELLUS 15-10379-00 BLANKOFF,SENSOR
NOVELLUS 15-10483-00 BRACKET
NOVELLUS 15-10489-00 CLAMP, CHAMBER VIEWPORT
NOVELLUS 15-10524-00 TIC, BLOCK TRANSFER MODULE
NOVELLUS 15-10628-00 RING, EXCLUSION, PLATE
NOVELLUS 15-10667-00 RING, EXCLUSION
NOVELLUS 15-108174-00 CUP, SCREW COVER
NOVELLUS 15-10837-00 COVER, VAT, VIEWPORT
NOVELLUS 15-11030-00 CLAMP,RING,FEEDTHRU
NOVELLUS 15-11031-00 FEEDTHRU,TOP
NOVELLUS 15-110526-00 PIN, POWER RLVD
NOVELLUS 15-11109-00 CLAMP,RING,INNER
NOVELLUS 15-11135-00 SENSOR WINDOW MAP
NOVELLUS 15-11350-00 FLANGE, MESC, INTERFACE, CVD-D
NOVELLUS 15-11616-03 TOOL WAFER C****NG 200MM .38DIA
NOVELLUS 15-11658-00 SHAFT,INSULATED,EXTENDER
NOVELLUS 15-118451-00 AERA MFC BRACKET (CLEAR AODINE)
NOVELLUS 15-119059-00 Bolt 1/4-20 1/4 Nickel
NOVELLUS 15-124538-00 LOUVER SCREEN BRACKET
NOVELLUS 15-132969-00 PIN,.250 x.95,#8-32
NOVELLUS 15-135655-01 END EFFECTOR R L/LK, VCTR
NOVELLUS 15-138402-00 MOER RING 2.75 MM
NOVELLUS 15-154040-00 CU/P.040-.065(PRAXAIR)
NOVELLUS 15-2673 DRIVE,BELT,ROTATOR,ERGO
NOVELLUS 15355-01 ADAPTER-TRANSDUCER QUARTZ IPC
NOVELLUS 15651-01 CABLE, FAN
NOVELLUS 15884-02 PWA EOP DETECTOR
NOVELLUS 16-00089-00 PLATE, GAS DISTRIBUTION, TOP
NOVELLUS 16-00092-00 STRAP HEATER FEEDTHRU
NOVELLUS 16-00197-00 FLOPPY MOUNTING BRACKET
NOVELLUS 16-00198-00 FLOPPY MOUNTING BRACKET
NOVELLUS 16-024771-00 FLANGE EXHAUST
NOVELLUS 16-029844-00 DISTRIBUTOR ASSY ALSO w/ 16-029846-00 & 16-029845-00
NOVELLUS 16-029846-00 DISTRIBUTOR BOTTOM
NOVELLUS 16-033105-00 PLATE, SEAL PEDESTAL
NOVELLUS 16-034002-00 HONEYCOMB DISK
NOVELLUS 16-034459-00 SHELF IOC SUPPORT
NOVELLUS 16-041993-00 SPACER 4 VACUUM
NOVELLUS 16-046933-00 BRKT,STN
NOVELLUS 16-049511-00 SHOWERHEAD
NOVELLUS 16-049525-00 SHOWERHEAD
NOVELLUS 16-10253-00 SHOWERHEAD
NOVELLUS 16-139965-00 WELDMENT,DIFFUSER,200mm (HIGH ACID)
NOVELLUS 16-148547-00 CHUCK,PEM,EBR,200MM
NOVELLUS 16-159097-00 CHUCK,PEM,200MM,HRU
NOVELLUS 16-167627-00 FILTER
NOVELLUS 16065-01 HARNESS ASSY, LIFT SENSOR
NOVELLUS 162-41-012A ARM BLOCK
NOVELLUS 16531-01 ROD DIFFUSER,QTZ LAMP
NOVELLUS 16875-01 CABLE,ASSY J4 EXH INTLK
NOVELLUS 16877-01 CABLE,ASSY SIG-REM DISPLAY
NOVELLUS 17-00091-00 RETAINER BRACKET
NOVELLUS 17-00094-00 STRAP RF
NOVELLUS 17-00106-00 COVER LIFT MOTOR
NOVELLUS 17-00194-00 BRACKETS
NOVELLUS 17-00286-00 FLAT CABLE
NOVELLUS 17-00316-00 CABLE, BRACKET
NOVELLUS 17-024406-00 BRKT.SWITCH PLATFORM
NOVELLUS 17-034429-01 PANEL, SIDE
NOVELLUS 17-034430-01 PANEL, SIDE
NOVELLUS 17-045011-00 FLAG,CASSETTE
NOVELLUS 17-050152-00 BOX
NOVELLUS 17-103642-00 Heater Isolation Box
NOVELLUS 17-10450-00 BRACKET SWITCH PANEL INTERLOCK
NOVELLUS 17-10480-00 FLAG,CASS
NOVELLUS 17-10515-00 STRAP,SHUNT,CAPACITOR
NOVELLUS 17-112594-00 RTNR KEYBOARD TRAY DLCM-S
NOVELLUS 17-112873-00 CU,CONTACT, CONE UP, FLAT
NOVELLUS 17-11496-01 COVER
NOVELLUS 17-118866-00 SCREEN RF SHIELD ETCHED OEP
NOVELLUS 17-145723-00 BRACKET, POWER SUPPLY
NOVELLUS 17-16938-02 CO****OL EXHAUST KIT
NOVELLUS 17-267445-00 MOUNTING BRACKET
NOVELLUS 17-275970-00 BRACKET MOUNTING PWR SUPPLY
NOVELLUS 17-276299-00 24 V DC POWER SUPPLY MOUNT
NOVELLUS 17-53971-01 D.C. SERVO MOTOR
NOVELLUS 17-68876-01 PCB,SECSI/11 ARTIC
NOVELLUS 17559-01 CABLE MAGNETRON HIGH VOLTAGE
NOVELLUS 17818-02 REFLECTOR TRAY BULB
NOVELLUS 18-010968 FLIPPER,ASSY,INTERGRATED
NOVELLUS 18-0871-07 SCREW,8-32X5/8,LG,SHC,SST (PACK OF 10)
NOVELLUS 19-00017-00 GUIDE BAFFLE
NOVELLUS 19-00034-00 GEAR INNER SHAFT
NOVELLUS 19-00058-00 Pulley, Timing
NOVELLUS 19-00060-00 BEARING
NOVELLUS 19-00071-00 TUBE, FITTING INS FEMALE 1/16
NOVELLUS 19-00111-00 ONE ARM ROBOT LEADSCREW (W/NUT)
NOVELLUS 19-00121-00 CAPACITER, RF DISTRIBUTION
NOVELLUS 19-00127-00 PCB, ANALOG OUT W/JUMPER
NOVELLUS 19-00150-00 HEATER TRANSPORT FOOT
NOVELLUS 19-00243-00 SCREW C.DOOR SHOULDER V4-1
NOVELLUS 19-00260-05 VALVE, 5 WAY SOLENOID
NOVELLUS 19-00273-00 WASHER, SPRING, MOD
NOVELLUS 19-00307-00 BELLOWS, LIFT PIN
NOVELLUS 19-00361-00 14FLAT SCREEN MONO
NOVELLUS 19-00503-00 PADDLE, WRIST
NOVELLUS 19-024227-01 BLOCK - HEATER
NOVELLUS 19-034573-00 BEARING
NOVELLUS 19-034573-01 SCREW LIFT IND.
NOVELLUS 19-034573-09 BEARING, 2.62 OD
NOVELLUS 19-116632-00 ATC CAP, 100 PF, 1000 V, MOD
NOVELLUS 19-126021-00 EPROM, IOC, 10MHZ, V4, 1
NOVELLUS 19-229899-00 PIN,QUICK REL.(3290 LL RAM PLT.PIN)
NOVELLUS 19-273862-00 TUBE, SAPPHIRE, 10MMOD, 8MMID
NOVELLUS 20-00057-00 Nuts
NOVELLUS 20-00064-00 7/8" X 0.36" COMPRESSION SPREING
NOVELLUS 20-00070-00 RINGS, PINS
NOVELLUS 20-00074-00 Ring, Retaining, Ext. 3/16 (20 pack)
NOVELLUS 20-00126-00 BELT TIMING .4WX2.25OD 20-00126-00
NOVELLUS 20-00146-00 GASKET NYLON #10
NOVELLUS 20-00200-20 SWITCH 20-00200-20
NOVELLUS 20-00208-00 WASHER 5/16 X 5/8
NOVELLUS 20-00210-00 SCREW 8 X 90 BLK OX
NOVELLUS 20-00212-00 NUT 8-32 UNC-2B ALUM (PACK OF 10)
NOVELLUS 20-00222-00 WASHER FLAT ALUMINUM 1/4
NOVELLUS 20-00249-00 SCREW, SHOULDER 4-40 5/32"
NOVELLUS 20-00259-00 Washer, Spring
NOVELLUS 20-00289-00 PULLY MOTOR
NOVELLUS 20-00300 STANDARD, SONOGUAGE, CALI
NOVELLUS 20-00304-00 DRIVE - ROBOT ROTATION
NOVELLUS 20-00461-00 SPACER, SHA
NOVELLUS 20-10125-00 BEARING, 2.0OD
NOVELLUS 20-1283 FITTING,ADAPTOR B-4-HC-1-2 SWAGELOK
NOVELLUS 20-142586-00 BELT,SABRE CMS ELCTORDE MOTOR
NOVELLUS 21-00040-00 SCREW 4-40"X1/4
NOVELLUS 21-00052-01 LOADLOCK SCREW 10-32X1"
NOVELLUS 21-00056-00 SCREW SKHD 1/4-20X1" SS
NOVELLUS 21-00064-00 WASHER, FLAT #10 S/S
NOVELLUS 21-00151-00 WASHER, LOCK #10, SS
NOVELLUS 21-00244-00 FLATHEAD SCREW CAP 4-40 3/8"
NOVELLUS 21-00339-00 NUT,10-32 S/S
NOVELLUS 21-00354-00 WASHER
NOVELLUS 21-0075-002 CABLE POWER 3/5" ADAPTOR
NOVELLUS 21-041267-12 SCRW,SKT,HEX,8-32x.75,SS, (PACK OF 10)
NOVELLUS 21-041269-12 SOCKET HEAD SCREW 10-32 X 3/4
NOVELLUS 21-041269-16 SCRW,SKT,HEX,10-32x1,SS, (PACK OF 10)
NOVELLUS 21-041269-20 SCRW,SKT,HEX,10-32x1.25,SS, (PACK OF 10)
NOVELLUS 21-042023-07 WASHER,FLAT,#8,SS, (PACK OF 10)
NOVELLUS 21-042023-08 WASHER, FLAT #10, SS (PACK OF 10)
NOVELLUS 21-042024-06 WASHER,LOCK,#8,SS, (PACK OF 10)
NOVELLUS 21-042024-07 WASHER,LOCK,#10,SS, (PACK OF 10)
NOVELLUS 21-04505-00 SHAFT, 1/4X3, SST
NOVELLUS 21-051116-12 SCREW, SCHS 10-32X.75 SILVER  (PACK of 10)
NOVELLUS 21-109605-00 BEARING
NOVELLUS 22-00005-04 MASS FLOW CO****OLLER UFC-1100A N2 10
NOVELLUS 22-00053-00 O-RING
NOVELLUS 22-00065-00 CHAIN SPROCKET .24W X 4.6 = 51ID
NOVELLUS 22-00091-00 FTG, 1/4 VCR(M)-1/4 S
NOVELLUS 22-00096-00 FTG, 1/4" NPT - 1/4" SWAGE
NOVELLUS 22-00121-00 RING, CLAMPING COLLAR
NOVELLUS 22-00146-00 FTG,UNION,TEE
NOVELLUS 22-00176-00 O-RING, BUNA
NOVELLUS 22-00226-00 SEAL 3/32
NOVELLUS 22-00227-00 O-RINGS
NOVELLUS 22-00239-00 O-RING, 5.984X.139
NOVELLUS 22-00256-00 O-RING
NOVELLUS 22-00262-00 SEAL 1.00" FLANGE
NOVELLUS 22-00277-00 FTG VALCO MALE NVT (PACK OF 10)
NOVELLUS 22-00293-00 FITTING
NOVELLUS 22-00300-00 FTG,CAP,1/4VCR
NOVELLUS 22-00304-00 BRG,1.50OD
NOVELLUS 22-00306-00 BEARING, 2.62OD
NOVELLUS 22-00321-00 FITTING, 10-32, NIPPLE (CLIPPARD)
NOVELLUS 22-00322-00 FITTING, 10-32, SWIVEL (CLIPPARD)
NOVELLUS 22-00337-00 VALVE, 3-WAY AIR-OP
NOVELLUS 22-00345-00 O-RING, 0.364 x .070 ID
NOVELLUS 22-00361-00 O-RING VITON(SOR31.12ID,0.275CS)
NOVELLUS 22-00364-00 V/V LIQ.BLEED MAN
NOVELLUS 22-00375-00 NUT SWAGELOCK 1/16"S
NOVELLUS 22-00391-00 O-RING,J 0.864" X 0.070"
NOVELLUS 22-00427-00 1/4" TUBE ULTRA-TORR NUT
NOVELLUS 22-00603-00 O-RING,2-224,VITON V747-75 (PACK OF 10)
NOVELLUS 22-00612-01 VALVE,NC,DIA,1/4FVCR,AIR, SWAGELOK P/N 6LV-DAFR4-P-C
NOVELLUS 22-00614-00 FILTER, .5u HIGH PRESSURE
NOVELLUS 22-00638-00 BEARINGS
NOVELLUS 22-00648-00 T/C O-RING 0.114 X 0.070 (12 PER PACKAGE)
NOVELLUS 22-00649-00 WASHER, QUICK SEAL, 1/8 TUBE
NOVELLUS 22-00655-00 VALVE, DIAPHRAM, NUPRO
NOVELLUS 22-00660-00 TEOS LFC 5.0 L
NOVELLUS 22-00683-00 SEAL
NOVELLUS 22-00702-00 VALVE, PNEUMATIC LOGIC GATE
NOVELLUS 22-00716-00 O-RING (AS568AK#231)COMPOUND:4079
NOVELLUS 22-00728-00 O-RING
NOVELLUS 22-00736-00 FILTER,WAFERGUARD UPPER MANIFOLD B
NOVELLUS 22-00782-00 LFC, 0.2ML, TEOS
NOVELLUS 22-00796-00 VALVE,TOGGLE,
NOVELLUS 22-026085-00 VALVE,BLOCK,MONO
NOVELLUS 22-026373-01 FILTER
NOVELLUS 22-028789-00 VALVE, MANUAL, TOGGLE
NOVELLUS 22-029968-00 CONT,PRESS,3SLM, INVERT MTG
NOVELLUS 22-032893-00 FITTING UNION 6-4-37 DEG
NOVELLUS 22-033574-00 O RING, 2-351 VITON V75
NOVELLUS 22-033883-00 FITTING, 90 DEGREE STREET FLOW
NOVELLUS 22-033884-00 FITTING, NIPPLE, LONG NPT
NOVELLUS 22-033885-00 FITTING, COUPLING, 1/8 NPT
NOVELLUS 22-033979-00 COUPLING, CLOSE, 1/4, VCR
NOVELLUS 22-045559-00 FITTING, ELBOW 3/8 AN X 1/4 M PT
NOVELLUS 22-045597-00 FLOW REST, 5140-1/4SS-500
NOVELLUS 22-046278-00 SPRING CLEVIS
NOVELLUS 22-047587-00 FITTING, BULKHEAD ELBOW, 3/8 AN X 3/8 AN
NOVELLUS 22-047613-00 CONNECTOR 3/8-37 DEGREE TO 1/4 MNPT SST
NOVELLUS 22-052164-00 VERIFLOW VALVE, 43900647 (7000WSI)
NOVELLUS 22-055667-00 DN100 4" MECHANISM
NOVELLUS 22-100215-00 GAUGE, PRESS 0-60 1/8MNPT REAR
NOVELLUS 22-10029-00 O-RING VITON
NOVELLUS 22-10057-00 BUSHING, 3" OPEN BALL
NOVELLUS 22-10058-00 RESTRICTOR, FLOW, .043" VCR GASKET
NOVELLUS 22-10062-00 O-RING, VIEWPORT
NOVELLUS 22-10095-00 O-Ring Sensor Cover Plate 3.109x0.139 Viton
NOVELLUS 22-10117-00 O-Ring Vavle Seat 7.234x0.139 Viton
NOVELLUS 22-10143-00 BULKHEAD FITTING
NOVELLUS 22-10149-00 SEAL, LIP FLA
NOVELLUS 22-10235-00 PLUG BRASS 1/8"NPT
NOVELLUS 22-10278-00 BELT, TIMING
NOVELLUS 22-10294-00 O-Ring Sense Mount 2.734x0.139
NOVELLUS 22-10323-00 O-RING, DOOR WINDOW 9.484 X 0.139 VITON
NOVELLUS 22-10349-00 O-Ring VAT Valve Stem 1.114x0.070 Viton
NOVELLUS 22-10365-00 GASKET SHIELDING FOLDOVER
NOVELLUS 22-10371-00 O-Ring Z Sensor 2.239x0.070 Viton
NOVELLUS 22-10379-00 O-Ring Window Wafer ARCS 6.225x0.210 Viton
NOVELLUS 22-10380-00 O-RING, 1.487X0.103, VITON, VIEWPORT
NOVELLUS 22-10388-00 O-Ring Sensor Window 0.801x0.070 Viton
NOVELLUS 22-10391-00 O-Ring Plate Wafer ARCS 12.44x0.210 Viton
NOVELLUS 22-10409-00 O-Ring Hatch Window 12.27x0.21 Viton
NOVELLUS 22-104100-00 O-RING,2-210,VITON V75 (PACK OF 10)
NOVELLUS 22-115764-00 FILTER, CER M/F
NOVELLUS 22-128529-21 O-RING, 2-263, CHEMRAZ E38, RECTANGULAR
NOVELLUS 22-2667 BELLOWS KF50.3.94L
NOVELLUS 22-315804-00 O-RING
NOVELLUS 22-678311-00 RING EXTERNAL SNAP
NOVELLUS 2200-700755 VALVE, AIR TOP-OPEN
NOVELLUS 2200700111 VALVE, CHECK PP 1/4 PT
NOVELLUS 2210-700351 VALVE AIR 4-WAY
NOVELLUS 2250-717036 ADAPTOR, BULKHEAD
NOVELLUS 23-0096 MFC N2,200SCCM,23-0096
NOVELLUS 23-12139-01 CABLE ANALOG CHAN B
NOVELLUS 23-2580 REED SWITCH,PRL-11
NOVELLUS 23-2802 MFC H2 2SLPM HOS 1/4VCR FAST UNIT8
NOVELLUS 23-2809 MFC O2 3SLPM 1/4 VCR HORIBA SEC 73
NOVELLUS 23-619960-00 PLUGBUTTON-7/8
NOVELLUS 23712-01 PCB ASSY ELEVATOR TRAY SENSOR
NOVELLUS 24-23609-00 NEEDLE BEARING
NOVELLUS 26-81088-00 RETAINER, LEFT
NOVELLUS 26-81089-00 RETAINER, RIGHT
NOVELLUS 26-83602-00 ROLLER CAGE, LOWER HOIST
NOVELLUS 260206 PLATE, ISOLATION KEY
NOVELLUS 27-00066-00 POWER SUPPLY, 24-28 VDC, 8A
NOVELLUS 27-00079-00 TC, TYJ 1/16 DIA
NOVELLUS 27-00135-00 CO****OLLER-TEMP EUROTHERM
NOVELLUS 27-00160-00 CO****OLLER, PIEZO VALVE
NOVELLUS 27-00163-00 CHERRY KEYBOARD, G81-1800
NOVELLUS 27-00165-00 CABLE ASM
NOVELLUS 27-00171-00 TOUCH BAZEL
NOVELLUS 27-00184-00 SINGLE ENDPOINT HEAD
NOVELLUS 27-0040-00 CHEM CAB TOUCH SCREEN
NOVELLUS 27-010325-00 SOLENOID, 3 WAY
NOVELLUS 27-027151-00 Power Conditioner, 12A, 1440VA
NOVELLUS 27-028036-00 PCB VIDEO CARD
NOVELLUS 27-029507-00 PCB DUAL ENDPOINT
NOVELLUS 27-029508-00 DETECTOR, OPTICAL EMISSION
NOVELLUS 27-042113-00 POWER SUPPLY, 24V/10A
NOVELLUS 27-052779-00 ASSY, LAMP, 5 BULB, RIGHT
NOVELLUS 27-100054-00 PWRSPLY,24@5
NOVELLUS 27-10006-00 CARD, MULTILAB I/O
同类产品
洪健强
留言咨询
