厦门海通华业科技有限公司
已认证
主营:PLC,模块,主板,触摸屏,DCS,变频器,CPU,驱动器
铝道网  >  铝设备 >  铝加工分析检测设备  > 分析检测设备  > 34-00179-00北京
34-00179-00北京
1 元/个
  • 所在地:
  • 供货总量: 1
  • 发布时间:2025-01-03
洪健强 :18020768701
主营产品:Schneider ,Foxboro,Ovatin,Allen-Bradley,Siemens等各类工控产品,
欢迎来电咨询!
NOVELLUS 27-10026-00 PCB ARCNET INTERFACE
NOVELLUS 27-10052-00 POWER SUPPLY
NOVELLUS 27-10068-00 CONT TEMP 0-500C
NOVELLUS 27-10116-00 CO****OLLER, TEMP N-ANAFAZE
NOVELLUS 27-10157-00 CO****OLLER
NOVELLUS 27-10161-00 TURBO CO****OLLER
NOVELLUS 27-10324-00 VALVE, SOL 4WAY DBL
NOVELLUS 27-111222-01 KEYBOARD MINI 83 KEY, AT
NOVELLUS 27-111237-02 TRACKBALL DESKTOP PS2
NOVELLUS 27-126667-00 VALVE CO****OLLER
NOVELLUS 27-142313-00 POWER SUPPLY 12 VDC @ 2.6A
NOVELLUS 27-160332-00 CU,PUMP,SABRE ECI VMS W/EXT WIRING
NOVELLUS 27-180607-00 SHIELD, THERMOUPLE
NOVELLUS 27-267330-00 POWER SUPPLY
NOVELLUS 27-309503-00 FITTING COUPLING QUICK DISCONNECT MALE & FEMALE SET
NOVELLUS 27-402784-00 O-RING,16.955X.139
NOVELLUS 27-45821-01 SENSOR MOD, NEW EXH FLW CNTL
NOVELLUS 27-999794-00 CYLINDER,AIR,.75STK-2.5
NOVELLUS 27-999998-00 NTWK INTFC TERMINAL
NOVELLUS 2711065500 CLIPS, SAFETY FOR M21
NOVELLUS 28-200267-00 GASKET,RETAINER FTG,VAC,.22ID (PACK OF 10)
NOVELLUS 28-200432-00 FTG VAC FILTER GASKET
NOVELLUS 28-8875-012 PC ASSY,COMM,PRE-PROD
NOVELLUS 2805-738144 BELL, POLISH SST ASSY (RAM)
NOVELLUS 2807-110820HP COMPUTER, C2C
NOVELLUS 2850-739458 ROBOT,REPAIR,676
NOVELLUS 2855-739918 ASSY, E/P COMPUTER W/SOFTWARE
NOVELLUS 30-00003-00 INDUCTOR 2.2UH 435MA
NOVELLUS 30-012197 LIGHT PEN
NOVELLUS 31-004854 MOTOR ASSY
NOVELLUS 31-029848-00 HEATER, EVAPORATOR
NOVELLUS 31-029889-01 MEGAPAK CHASSIS
NOVELLUS 31034-KASO SOFT START THROTTLE
NOVELLUS 32-00005-00 IC 74LS244
NOVELLUS 32-00006-00 IC MCT2E 6 PIN DIP
NOVELLUS 32-00017-00 IC, COMPARITOR LF 311H
NOVELLUS 33-153940-00 MOTOR, ZETA STEPPER, 57-51
NOVELLUS 34-00061-00 RELAY 24 VAC
NOVELLUS 34-00127-00 RELAY, MOTOR OVERLOAD 3-POLE
NOVELLUS 34-00133-00 SEALANT TEFLON
NOVELLUS 34-00179-00 CKT BKR, 20A,1P
NOVELLUS 34-00208-00 RELAY. PCB MOUNTED DPDT
NOVELLUS 34-028026-02 2A CKT, BRKR, 15.606-URT
NOVELLUS 34-028026-06 6A CKT BRKR, 15.612-URT
NOVELLUS 34-029889-12 CARTRIDGE, 12V OAR 8.3 AFL
NOVELLUS 34-029889-51 V1-260-CV UPGRADE CONVERTER TO CONVERTER PAC'S
NOVELLUS 34-053380-00 SWITCH, PRESSURE ATM KF-25 9 PIN
NOVELLUS 34-10095-00 Relay, SSR 240V, 25A
NOVELLUS 34-10118-00 CIRCUIT BREAKER
NOVELLUS 34-10194-00 SENSOR LASER THRU BEAM
NOVELLUS 34-10197-00 AMP FIBER
NOVELLUS 34-125019-00 Ferrite Filter
NOVELLUS 34-125023-00 Ferrite Filter, 250 OHM
NOVELLUS 34-167064-00 SNSR.REF ELECTRODE,POLYMER
NOVELLUS 34-8134454-00 LIQUID LEVEL SWITCH
NOVELLUS 35-128007-00 CABLE
NOVELLUS 36-00012-00 FUSE, 40AMP
NOVELLUS 36-00022-00 FUSE 10A 250V(FNM-10)
NOVELLUS 36-00023-00 FUSE 5 AMP 600V
NOVELLUS 36-00025-00 FUSE 5A(SUB MINI TYPE)
NOVELLUS 372-03901-1 ENCODER,ARM,POSITION
NOVELLUS 372-55136-1 BUTTON,ARM,ALIGNMENT
NOVELLUS 372M-72127-1 ARM,POLISH,MOTOR,MOD
NOVELLUS 372M-72127-2 ARM, POLISH, MOTOR, MOD
NOVELLUS 38-00055-00 CO****OLLER DISPLA
NOVELLUS 38-122213-00 CABLE ION GAUGE
NOVELLUS 38-127756-00 CABLE MKS TV  HICAPMAN
NOVELLUS 38-128003-00 CABLE T VALVE MKS 651D
NOVELLUS 38-129819-00 CABLE ASSY RS 232 Adptr
NOVELLUS 39-00097-00 CONNECTOR, 2 POS. PLUG
NOVELLUS 39-2018 LAMP, ULTRAVIOLET
NOVELLUS 39-3002 PILOT LIGHT,ROUND FLUSH,GREEN IDEC APW199-G-24V
NOVELLUS 3910-700238 FILTER,SLURRY
NOVELLUS 3C0010 VACUUM PUMP FILM
NOVELLUS 41-00024-00 VALVE FESTO
NOVELLUS 42-0010-011 ELECTRO-CRAFT MAX-430 BRUSH SERVO DRIVE
NOVELLUS 49667 CO****OL,BOARD
NOVELLUS 50-000020-00D CONDENSER
NOVELLUS 52-22241-00 SOLENOID 24VDC 3X2 IVS
NOVELLUS 56-010559 PADDLE, 1 IN WIDE, OVER CENTER
NOVELLUS 57-169589-00 FLOW METER, 1-7 LPM
NOVELLUS 57-2058 RF FAN GAMMA 2100
NOVELLUS 5850E14SLM N2 MFC
NOVELLUS 5850E5SLM NH3 MFC
NOVELLUS 5866RT3SLM Ar MFC
NOVELLUS 60-00005-00 VACUUM GAUGE TUBE (TELADYNE DV-6M-KF-25)
NOVELLUS 60-00015-00 CENTERING
NOVELLUS 60-00017-00 BELLOW KF50
NOVELLUS 60-00019-00 STAINLESS CENTERING RINGS W/ VITON O-RING
NOVELLUS 60-00026-00 RING CENTERING
NOVELLUS 60-00028-00 DBL. CLAW CLAMP
NOVELLUS 60-00029-02 CLAMP 1/8" DELRIN
NOVELLUS 60-00039-00 KF-40 CENTERING RING
NOVELLUS 60-00045-00 CENTERING RING NW80
NOVELLUS 60-00052-00 ADPTR FOR ASA TO NW100-ISO MF
NOVELLUS 60-00057-00 GAUGE VACUUM CO****OLLER (USE: # 04-143771-00)
NOVELLUS 60-00066-00 BACK FILL FILTER
NOVELLUS 60-00144-00 SWITCH, DIAPHRAGM PRESSURE
NOVELLUS 60-00147-00 GAUGE PRESSURE TEOS(VER.2)
NOVELLUS 60-00170-00 GAUGE TUBE VACUUM CONVECTRON ANALOG
NOVELLUS 60-00187-00 ACUATOR,PNEUMATIC,ROTARY
NOVELLUS 60-00194 SWITCH DIAPHRAN PRES 20 TORR
NOVELLUS 60-00195-00 VACUUM SWITCH 100 TORR
NOVELLUS 60-00200-00 Regulator, 0 to 100 PSI
NOVELLUS 60-0091 Chamber, Plasma Quartz
NOVELLUS 60-010040-00 CLAMP BULKHEAD NW40 AL
NOVELLUS 60-027139-00 TEE KF-25 ALUM SHORT
NOVELLUS 60-029345-00 OIL, TURBO PUMP OIL
NOVELLUS 60-045554-00 CLAMP, 2-CLAW, NW63-100, AL
NOVELLUS 60-052355-00 SOLENOID, 3WAY, W/ SUBBASE
NOVELLUS 60-10005-00 MANOMETER .1T W/VCR8
NOVELLUS 60-10035-00 100 TORR MANOMETER
NOVELLUS 60-10040-00 CLAMP BULKHEAD NW40 AL
NOVELLUS 60-10059-00 FILTER, CDA
NOVELLUS 60-125751-00 VALVE, THROTTLE
NOVELLUS 60-136938-00 SEAL RING, CHEMRAZ KF40 ASSEMBLY
NOVELLUS 60-175090-00 VACUUM CONNECTS, YASKAWA
NOVELLUS 60-2022 DUAL-LOOP COUPLER,MICR
NOVELLUS 60-24112-00 ACTUATOR WITH BELLOWS ( R 1/8'')
NOVELLUS 60-312139-00 ELECTRIC VALVE,5P,2 POSI,24VDC,W/ADAPTER
NOVELLUS 61-0037-02 PCB 60-0023-01
NOVELLUS 62-20995-00 MOTOR CO****OL PCB
NOVELLUS 65-106645A06 TRANSDUCER MKS 122AA-01000BB 1000TORR V16-8
NOVELLUS 67781501 CLIP CV MASK
NOVELLUS 687127-01 TOOL RETAINER O RING
NOVELLUS 70-00054-00 CASSETTES METAL 125MM
NOVELLUS 71-007119-02-B CABLE
NOVELLUS 71003-19 O-RING, 2-120, .987  ID X .103 W, VITON
NOVELLUS 71004-19 O-RING,VITON 1-5/6 IN PARKER (PACK OF 10)
NOVELLUS 71005-68 O-RING, 2-376, 9.725 ID X .210, VITON V8
NOVELLUS 71805-01 WINDOW QTZ 1.25 DIA S 1/8 IN
NOVELLUS 71966-02 CLAMP
NOVELLUS 71966-06 CLAMP
NOVELLUS 72-00026-00 ONE ARM PADDLE ALIGN TOOL
NOVELLUS 72-00039-00 DIAL, INDR. HLDR. W/FINE ADJ
NOVELLUS 72-033865-00 TOOL, PEDESTAL, VAC, SURFACE, FLAT
NOVELLUS 72-115963-00 RELAY R10-E1-X2-V700 DPDT 24VDC COIL 5A CONTACTS
NOVELLUS 72496-06 CENTERING RING-ASSY L3500
NOVELLUS 73014-02 FLOW CO****OL CYLINDER
NOVELLUS 73016-09 FILTER UV-G25 313UM
NOVELLUS 73209-02 CONTACT  SW-6A
NOVELLUS 73336-01 SENSOR, LAMP SOURCE
NOVELLUS 73336-02 SENSOR,PHOTO DETECTOR
NOVELLUS 73797-01 LAMP INDICATOR (PACK OF 10)
NOVELLUS 73797-04 PWA CO****OL
NOVELLUS 73797-09 TRANSFORMER FILAMENT
NOVELLUS 73840-01 CO****OLLER HEATER CHAMBER(OMEGA CN9121A)
NOVELLUS 73874-06 RELAY CRYDOM H12WD4890
NOVELLUS 78-0124 O-RING, 5-116, .741 ID X .104 W, KALREZ
NOVELLUS 78-0190 CAJON (NI-8-VCR-2-GR-VS) VCR GASKET (PACK OF 10)
NOVELLUS 78-0193 CAJON (NI-4-VCR-2-GR-VS) VCR GASKET (PACK OF 10)
NOVELLUS 78-2551 O-RING , CHEMRAZ GT 4201B16501SS592
NOVELLUS 78-2713 O-RING
NOVELLUS 78-2770 O-RING GT
NOVELLUS 78-2782 GASKET,WINDOW,LAMP TRAY
NOVELLUS 78-501093-00 POWER SUPPLY
NOVELLUS 800-0940 FLANGE STAINLESS STEEL BLANK
NOVELLUS 82-843 CONNECTOR,RF BELL INDUSTRI ES
NOVELLUS 84-82493-00 SCREW, SHOULDER HOIST GUIDE
NOVELLUS 84429-R1 ACTUATOR WITH BELLOWS (OUTDATED)
NOVELLUS 90-0020-01 UV PEN RAY MERCURY LAMP 23046050
NOVELLUS 90-1036-01 PCB,MFC,INTERFACE,8"
NOVELLUS 90-2588 PCB,DSCR,KIT,REV E
NOVELLUS 90-2627 CO****OLLER, INTERLOCK, PCB
NOVELLUS 90-2735 PCB ASSY
NOVELLUS 93-0079 CYLINDER FEEDTHRU LINEAR MODIFICATION
NOVELLUS 93-2657 LAMP,HG-OZONE FREE,2.125 IN, WITH 12 IN
NOVELLUS 93-2688 LITTLE GIANT NO WAGOS,PCB
NOVELLUS 94-1119 LIFT,PROCESS,CHAMBER,24V
NOVELLUS 94-1153 SCREEN TOUCH
NOVELLUS 94-1160 LITTLE GIANT CPU BD,101-047
NOVELLUS 94-1171 PANEL,RIGHT,FRONT,CO****OL
NOVELLUS 94-1172 ROTATOR RECEIVE
NOVELLUS 94-1173 ROTATOR, SEND
NOVELLUS 94-1176 HARNESS,ASSY
NOVELLUS 94-2618 MICROWAVE PWR
NOVELLUS 94-3441 ASSY LOAD LOCK, EXTERNAL DOOR
NOVELLUS 95-0253-01 ASSY,LIFT SENSOR,L3500/1
NOVELLUS 95-0320 HARD DISK DRIVE
NOVELLUS 95-0547 MICROWAVE GEN. CO****OLLER
NOVELLUS 95-2700 REACTOR CENTER DOOR
NOVELLUS 95-2736 AC POWER CO****OL PROCESS ASSY
NOVELLUS 95-3436 EPROM,VERISON,4.0
NOVELLUS 95-3798 MINI CO****OLLER, MISC
NOVELLUS 95-3847 LED, PCA/INTERFACE
NOVELLUS 950230 PULLY, TIMING UPPER FLIPPER
NOVELLUS 950591 ASSY,ENDEFFECTOR
NOVELLUS 950609 MOTOR, AC 2700 RPM SERVO
NOVELLUS 950615 MOTOR,AC SERVO 8.0 IN-LB
NOVELLUS 950776 LOAD CELL,INTEGRAL AMP
NOVELLUS 950972 MODULE,INPUT(C****)MIO-IDC-32-300
NOVELLUS 951456 CLAMP UP/DOWN SENSOR
同类产品
洪健强
留言咨询
