厦门海通华业科技有限公司
已认证
主营:PLC,模块,主板,触摸屏,DCS,变频器,CPU,驱动器
铝道网  >  铝设备 >  铝加工分析检测设备  > 分析检测设备  > SS-4CA-VT-50苏州
SS-4CA-VT-50苏州
1 元/个
  • 所在地:
  • 供货总量: 1
  • 发布时间:2025-01-03
洪健强 :18020768701
主营产品:Schneider ,Foxboro,Ovatin,Allen-Bradley,Siemens等各类工控产品,
欢迎来电咨询!
NOVELLUS 951477 CABLE, MOTOR POWER
NOVELLUS 951544 ASSY,SNR,PAD,COND
NOVELLUS 951631 Assy, Cable, ARM 5-VAC Transdu
NOVELLUS 951696 TRANSDUCER,I/P 0-30PSI 0-10V
NOVELLUS 96-0324 ASSY,CABLE,PLASMA SENSOR
NOVELLUS 96-2898 CABLE ASSY, EUROTHERM TO PLATEN RTD SENSOR
NOVELLUS 96-2994 CABLE PLASMA DETECT #96-2994 REV.D
NOVELLUS 96-3199 ASSEMBLY CABLE PLASMA SENSOR
NOVELLUS 96-4047 CABLE ASSY
NOVELLUS 965403 INSERT,MAIN TABLE
NOVELLUS 99-000411-00 ELECTRON TUBE
NOVELLUS 99-80266-01 ASSY,PCB,****C****LR
NOVELLUS A01-076-01 DOOR CHAMBER
NOVELLUS A01-081-01 BEARING, BLOCK, TRAVELER
NOVELLUS A01-171-01 PIN
NOVELLUS A01-187-01 FLAG, DOOR, SENSOR
NOVELLUS A01-219-01 COVER,LOAD,LOCK,8IN
NOVELLUS A01-328-01 COVER,TOP,PROCESSS,CHAMBER
NOVELLUS A01-349-01 COVER TERMINAL
NOVELLUS A01-358-01 SHAFT, MAIN
NOVELLUS A01-442-01 GEAR,ACTUATOR
NOVELLUS A17-079-01 BEARING BALL .750ID
NOVELLUS A17-319-01 SHAFT ROTARY FEEDTHROUGH 3/4 DIA
NOVELLUS A20-038-01 BELLOW, NW16
NOVELLUS A3010 PHOTOHELIC
NOVELLUS A35-302-01 SCR, DUAL, POWER, MOD
NOVELLUS A3GJ-S2C52-24EG LIGHTED PUSHBUTTON SWITCH
NOVELLUS A54-005-01 CO****OLLER EUROTHERM TEMPERATURE
NOVELLUS A57-011-01 CYLINDER,DACTING,11/4x2
NOVELLUS A57-014-01 BLOWER,235CFM,115VAC 50/60
NOVELLUS A90-013-01 PCB,LED AND
NOVELLUS A90-029-03 PCB LL LIFT LOGIC 8",CU
NOVELLUS A90-031-03 PCB,PLASMA,DETECT
NOVELLUS A94-042-01 ASSY,PNEUMATIC, PANEL
NOVELLUS A94-059-01 ASSY,LL,LOCATOR
NOVELLUS A94-062-01 ARM II,ASSY,W/PCA
NOVELLUS A95-053-02 LAMP,TRAY
NOVELLUS A95-054-02 ASSY WAVER GUIDE 200MM
NOVELLUS A95-108-02 ASSY, DISPLAY, PANEL, FRONT
NOVELLUS A95-122-01 LOAD, LOCK, DOOR, EXTERNAL
NOVELLUS A96-018-05 KIT, HV, WIRE 8"
NOVELLUS A96-032-02 HARNESS ASSY, RELAY
NOVELLUS A96-064-01 CABLE,CPU,J5
NOVELLUS A96-071-01 CABLE,CPU,J2
NOVELLUS A96-071-02 CBLE,ASSY,J6/P6
NOVELLUS A96-093-01 CABLE,LOAD,ARM
NOVELLUS A96-094-01 ASSY,CABLE,LL,CPU
NOVELLUS A96-110-01 INDICATOR, LIGHT
NOVELLUS A9GT-70PSC PROTECT SHEET
NOVELLUS AC2068A1 MODULE, MOTER CO****OL SERVO
NOVELLUS AC2069A1 MODULE, MOTOR CO****OLLER, STEPPER
NOVELLUS AC2105A1 BEARING, TAPERED ROLLER
NOVELLUS AC2113A1 BELLOW, ARM
NOVELLUS AC2202A1 XDCR, I/P, 0-60PSI
NOVELLUS AC2258A1 INFAROTTHERMOMETER PAD (IRCON)
NOVELLUS AC2475A1 UNION,ROTATING DUAL FLOW,IN
NOVELLUS AC2628A1 TRANSFER PADDLE CYLINDER
NOVELLUS AC2724A1 MODULE, FILTER, /- 5VDC
NOVELLUS AC2749A1 PAD CONDITION LOAD CELL
NOVELLUS AC2759A1 SEAL, SPRING LOADED, TFE
NOVELLUS AC2767A1 SENSOR, REFLECTIVE, WP
NOVELLUS AC2774A1-R MOTOR,STEPPER
NOVELLUS AC2775A1 GEARHEAD,PLANETARY, 10:1
NOVELLUS AC2785A1 REGULATOR,PRECISION,4-1
NOVELLUS AC2855A1 VALVE MANIFOLD, 5P 2POS 24VDC
NOVELLUS AC2857A1 END PLATE KIT,NUGGET 50
NOVELLUS AC2944A1 POWER SUPPLY,310VDC
NOVELLUS AC3038A1 PAPER, MEDIA LEAK DETECTION
NOVELLUS AC3100A1 GAUGE, 0-60
NOVELLUS AC3102A1 REGULATOR
NOVELLUS AC3120A1 REGULATOR,BACKPRESSURE,PVDF
NOVELLUS AC3121A1 GAUGE GUARD, FLUID CABINET
NOVELLUS AC3702 CYLINDER TRANSFER PADDLE UNLOAD
NOVELLUS ACR-28S02 CO****OLLER PRESSURE SYSTEM
NOVELLUS AD2463A1 BALL SPLINE,MODIFIED
NOVELLUS AD2608A1 SUPPORT,PART POS-MAIN LINER
NOVELLUS B-38258 SHOWER HEAD (NO COATING)
NOVELLUS BB-103010-85 SHIELD (CLEANED)
NOVELLUS BB10-355497 GUIDE, WAFER CLAMP
NOVELLUS BB10-355498 SHIELD (PACK OF 10)
NOVELLUS BB10157306 SHIELD, CYLINDER (MB2-830)
NOVELLUS BB10157492 DARK, SPACE, SHIELD (DSS)
NOVELLUS BB10157641 CLAMP, RING, LOWER, CDS, SST
NOVELLUS BB10157664 SHIELD, CHAMBER ,BOTTON, W/GAS
NOVELLUS BB10157827 LAMP,HEAT REFLECT
NOVELLUS BB10301019 N-JIG A
NOVELLUS BB10301021 N-JIG C
NOVELLUS BB10301789 JIG 8 TABLE
NOVELLUS BB10302596 JIG F 8 CENTER
NOVELLUS BB10303994 JIG TABLE CENTER
NOVELLUS BB10400393 JIG BELT (50PB)
NOVELLUS BB10400804 PINA ALIGNMENT TOOL USE
NOVELLUS BB10400805 PINB, ALIGNMENT TOOL USE
NOVELLUS BB10402195 JIG ARM PLATE
NOVELLUS BB10457458 SPACER  30MM  MV-28346 (PACK OF 3)
NOVELLUS C04-00098 ENGAGE DRAIN PUMP VALVE
NOVELLUS EL0001920009 CO****OLLER FOR GAS CABINET
NOVELLUS EL0001965110 CABLE
NOVELLUS FC-2930MOEP MFC N2 100 SCCM
NOVELLUS FC780C-2SLM NH3 MFC
NOVELLUS FR51 GAUGE
NOVELLUS FUDDFL-71-6.35-2-31660 1/4" VALVE
NOVELLUS G17-01020 WELDMENT GAS TUBE
NOVELLUS G17-10233-00 COVER
NOVELLUS GDP:X-1288 QUARTZ GAMMA GDP
NOVELLUS HA010079 SPRAY NOZZLE
NOVELLUS HE430065 VALVE,SOL,4WY,24V,NEUMATIC
NOVELLUS HE430090 SOLENOID,LOAD,SHUTTLE
NOVELLUS HE820034 VALVE 2 WAY INPT PFA
NOVELLUS HG140030 FILTER W ELEMENT 140 MICRON
NOVELLUS JP-E-SS SWITCH, PRESSURE
NOVELLUS M6-CV-103 FLANGE SPINDLE FOR NOVELLUS
NOVELLUS M6-CV-104 SPIBDLE LINK FOR NOVELLUS
NOVELLUS P-200-L WATER FLOWMETER 0-5 LPM
NOVELLUS PM041-440-X CABLE TURBO CO****OL
NOVELLUS Q34340301 KQ 16-AR, NW25, CLAMP
NOVELLUS R27-053123-00 BAY VOLTEX HEAT EXCHANGER
NOVELLUS RIM-OAC24 RELAY, AC OUTPUT MOD. 24V
NOVELLUS RIM-ODC24 RELAY, DC, OUTPUT MOD. 24V
NOVELLUS SIGMA 6 SIGMA 6 CABINETS, CABLES, TEOS BATTLESHIPS
NOVELLUS SS-4BK-V51-1O AIR VALVE
NOVELLUS SS-4C-1/3 VALVE, CHECK 1/4"
NOVELLUS VZ110-5M-M5 VALVE, 3 WAY SOLENOID
NOW TECH ND-EP-4-T CONNECTOR NOW PACK 4L EXTEN
NP TEST INC 298590014 MANIPULATOR POWER SUPPLY
NP TEST INC 298590015 LINEAR ACTUATOR X, Y
NP TEST INC 740000621 DCSS PMU LOGIC FX GX
NP TEST INC 740001672 DCSS,DC,MON,FXGX,NEED2251
NP TEST INC 77911177 BUS,EXP,GPIB,CONT,GX
NP TEST INC 77911646 EXPANSION MODULE (EXP-1 & EXP-2)
NP TEST INC 96924122 PCB,PEC5,IX
NP TEST INC 97911002 HS, CLOCK, BUFFER, FX
NP TEST INC 97911137 PWRSUP,5.1V,HBAY,GX
NP TEST INC 97911401 HS,APG,ADB,FX,GX
NP TEST INC 97912080 PWRSUP,TH,MP3,GX
NP TEST INC 97913170 DCSS,HCDPS,I/F,FX,GX
NP TEST INC 97913174 PCB,HCDPS,LOAD
NP TEST INC 97914179 CARD,HIGH,SPEED,CLOCK
NSK 115-15054-01 SERVO MOTOR W/ CO****OLLER
NSK 3MOT000742 DRIVER(X)
NSK 6005ZZAV2S BEARING,DRYER,6005ZZ
NSK 6200ZZCMAV2S BEARING
NSK 6202-2ZR-C3 BEARING SEALED .59 I X 1.38 OD 903888-001
NSK 6202ZZCMNS7S BEARINGS RADIAL
NSK 6203LU BEARING .665IDX 1.57OD
NSK 6204.2ZR BEARING DOUBLE SHIELDED FACILITIES
NSK 6204ZZ BEARING
NSK 6814-602 BEARING
NSK 688HZ BEARING
NSK 6940MAZZS BEARINGS
NSK 7000ADB BEARING
NSK 7002A BEARINGS
NSK 7002AP5 BEARING
NSK 7002CTDULP4V BEARING (RHP)
NSK 7007CTYSULP4 BEARING
NSK 7202AP5 BEARING
NSK 7202DF BEARING
NSK AS0404FN526 4" MEGA TORQUE MOTOR
NSK EE0408C59-25 CO****OLLER, MOTOR
NSK EM0404AF1-05 4 MEGA TORQUE MOTOR CO****OLLER
NSK EM0810AF1-05 CO****OLLER, MEGA TORQUE MOTOR
NSK EM2210AF-05 POWER SUPPLY BOX
NSK EMB014CF1-03 CO****OLLER, MOTOR
NSK EMB014CF1-04 CO****OLLER
NSK EMB014CF1-05 CO****OLLER, MOTOR
NSK EMLZ10CF1-01 DRIVER
NSK EMLZ10CF1-04 DRIVER, MEGATORQUE MOTOR
NSK EMLZ10CF1-05 CO****OLLER
NSK F688AZZ1MC3 BEARING
NSK F696ZZ1MC3 BEARING
NSK M-EP1410A15-05 AMPLIFIER, FINAL TABLE CO****OL EP DRIVER
NSK M-JS2014FN001AA13 MOTOR SEMIX TORQUE
NSK M-JSB015FN504 MOTOR
NSK M-RW1410FN005PA15CR MOTOR
NSK MC002SS26 CABLE NSK ROBOT (RL1)
NSK MCM08040H10K-A03085A ACTUATOR, VERTICAL
NSK NU206W BEARING
NSK RS0810FN523 MEGA TORQUE MOTOR
NSK RW1410FN523 MOTOR NSK SECOND TABLE B2-2A
NSK SRW166ZZ BEARING
NSK WBK-12-01 BALL SCREW SUPPPORT UNIT
NUMATICS 030SS441B041Y SOLENOID VALVE
NUMATICS 031SS400B VALVE
NUMATICS 236-102B SOLENOID
NUMATICS HS03L7F00B VALVE, 3-WAY SOLENOID
NUMATICS M10SS400M SOLENOID VALVE
NUMATICS M10SS500M SOLENOID VALVE
NUMATICS M11SA411M SOLENOID VALVE
NUPRO 032-0403 VALVE PG.I. (91S)
NUPRO 032-0411 VALVE
NUPRO 032-0487 CHANGE OVER VALVE
NUPRO 032-0576 91S PGR VALVE
NUPRO 3UA50-00-1J OVERLOAD RELAY
NUPRO 4015709 VALVEBELLAIR-OPERATEDBN
NUPRO 451-0071 GAUGE (SPAN)
NUPRO 451-0072 30-0-30 GAUGE (FUJITSU)
NUPRO 451-0353 SPAN GAUGE 100PSI (SPAN)
NUPRO 451-0750 VALVE (NAPRO)
NUPRO 6L-3AK-DS-KF KIT, STEM REPLACEMENT
NUPRO 6L-CW4T4A-EPZD NC-50, VALVE
NUPRO 6L-E4HC-FR4-VR4 VALVE
NUPRO 6L-E4LB-FR4-VR4 VALVE
NUPRO 6L-E4LC-FR4-VR4 VALVE
NUPRO 6L-E4LD-FR4-VR4 VALVE
NUPRO 6L-ELD8-11XX VALVE, MANUAL
NUPRO 6L-FV4A-FR4-VR4 VALVE
NUPRO 6L-FV4C-FR4-VR4 FLOW SWITCH
NUPRO 6L-M4V-222P-J1 NUPRO VALVE
NUPRO 6L-M4V-22P-J1 NUPRO VALVE
NUPRO 6L-MV2858-11 VALVE
NUPRO 6LFV4FR4VR47132 VALVE
NUPRO 6LV-BN5043PX-C BELLOWS VALVE
NUPRO 6LV-BNBW4-C VALVE-NUPRO
NUPRO 6LV-BNT8BW6 VALVE
NUPRO 6LV-D1V222P-WS VALVE
NUPRO 6LV-D4D111P-RR VALVE
NUPRO 6LV-DAFR4-PX-C VALVE
NUPRO 6LV-DLBW4 VALVE ASSEMBLY
NUPRO 6LV-HDLFR4-P-GR DIAPHRAGM VALVE SC-01 CLEAN
NUPRO 6LV-M5042PX MANIFOLD VLV SC-01
NUPRO 6LV-M5072PX-111 MANIFOLD VALVE
NUPRO 6LV-M5073PX-11 MANIFOLD VALVE
NUPRO 6LV-R1V222P-AA VALVE
NUPRO 6LV-RDS4 VALVE
NUPRO 6LVDAFR4PBL DIAPHRAHM
NUPRO 6LVHBB41014P7-C VALVE 2 PORT
NUPRO A-5K-E4-L SWITCH
NUPRO B-10C-1 CHECK VALVE
NUPRO B-6JN VALVE
NUPRO B-8TF2-440 FILTER 440 MICRON
NUPRO EFV-375-B VALVE, EXCESS FLOW
NUPRO ESVP-1502-NWB VALVE PNEU 1-1/2
NUPRO ESVP-1502-NWB-A VALVE ANGLE,NW40
NUPRO KZ75-4C-K4 O-RING
NUPRO MS-SOL-1K SOLENOID KIT (DC24V)
NUPRO N60035-6LV-DAFR4VR4P VALVE
NUPRO NVF3430-5EZ-02T SOLENOID
NUPRO SS-12BK-MM-1C VALVE
NUPRO SS-12C-1 VALVE
NUPRO SS-1MV2800DJ-11 NC-55, VALVE
NUPRO SS-3200-1-32 FITTING 2" NPT CONNECTOR MALE
NUPRO SS-3DK-DS KIT, DIAPHRAM SEAL
NUPRO SS-45VCR8 VALVE
NUPRO SS-4B-VP-K5 TIP, VESPEL SMALL
NUPRO SS-4BG0-K5-T GASKET, HI-TEMP METAL
NUPRO SS-4BK VALVE
NUPRO SS-4BK VALVE
NUPRO SS-4BK-1C-319 VALVE, 4BK-1C 1/4 VCR
NUPRO SS-4BK-1C9ABAA VALVE AIR OP NC 3 WAY
NUPRO SS-4BK-1C9ACAA VALVE
NUPRO SS-4BK-1C9AGAA VALVE
NUPRO SS-4BK-K1 BELLOW KIT
NUPRO SS-4BK-K5 ADAPTER (PACK OF 2)
NUPRO SS-4BK-TW-1C VALVE BELLOWS
NUPRO SS-4BK-V51 VALVE,MANUAL 4BK
NUPRO SS-4BK-V51-10 VALVE
NUPRO SS-4BK-VCR-1C VALVE
NUPRO SS-4BKT VALVE TOGGLE
NUPRO SS-4BKT-319 VALVE,TOGGLE
NUPRO SS-4BKT-V13 VALVE TOGGLE 1/4" W/FEMALE VCR
NUPRO SS-4BKT-V51 VALVE BELLOWS TOGGLE
NUPRO SS-4BKT-V71 VALVE
NUPRO SS-4BKTW-10 VALVE
NUPRO SS-4BKVCR-1C VALVE
NUPRO SS-4BMG-TW VALVE
NUPRO SS-4BMG-VCR VALVE, METERING
NUPRO SS-4BMRG-K10 BELLOWS VALVE
NUPRO SS-4BY-V68 VALVE
NUPRO SS-4C-10 CHECK VALVE
NUPRO SS-4C-VCR-1/3 VALVE
NUPRO SS-4C4-1 CHECK VALVE
NUPRO SS-4CA-50 VALVE RELIEF, 50 PSI
NUPRO SS-4CA-VT-50 VALVE CONNECT
NUPRO SS-4F-VCR-05 FILTER INLINE VCR CLEAN TONC-11
NUPRO SS-4FW-VCR-15 VALVE
NUPRO SS-4H-V13 VALVE
NUPRO SS-4MA-MH VALVE METERING 1/4 IN
NUPRO SS-4MA-TFE VALVE NEEDLE
NUPRO SS-4MG VALVE, METERING
NUPRO SS-4MG-TF VALVE, METERING, SS-4MG-TF, 1/4C
NUPRO SS-4R3A-667 RELIEF VALVE
NUPRO SS-4R3A1 VALVE
NUPRO SS-4TF-2-910 FILTER, NC-11 (PACK OF 6)
NUPRO SS-4TF-90 VALVE
NUPRO SS-4TF-VCR-40 VALVE
NUPRO SS-4UW-TW-TF-4C NUPRO SPECIAL
NUPRO SS-6/8F-VI-60 VALVE
NUPRO SS-6BK-10 VALVE
同类产品
洪健强
留言咨询
