厦门海通华业科技有限公司
已认证
主营:PLC,模块,主板,触摸屏,DCS,变频器,CPU,驱动器
铝道网  >  铝设备 >  铝加工分析检测设备  > 分析检测设备  > GM9413C316湖南
GM9413C316湖南
1 元/个
  • 所在地:
  • 供货总量: 1
  • 发布时间:2025-01-08
洪健强 :18020768701
主营产品:Schneider ,Foxboro,Ovatin,Allen-Bradley,Siemens等各类工控产品,
欢迎来电咨询!
PERKIN ELMER 644-0954-008 PCB A208
PERKIN ELMER 677-0279-003 PCB A211
PERKIN ELMER 677-0282-003 WAFER ALIGNER SENSOR
PERKIN ELMER 677-9505-004 A7 PC BOARD
PERKIN ELMER 677-9505-006 PC BOARD
PERKIN ELMER 680-0146-029 POWER SUPPLY
PERKIN ELMER 682-0184-006 ACTUATOR, AIRPOT
PERKIN ELMER 682-0184-035 AIRPOT, ACTINIC, FILTER
PERKIN ELMER 690-0735-008 PCB, SOLENOID MANIFOLD
PERKIN ELMER 690-0743-003 PCB, A103 SWITCHBOARD A
PERKIN ELMER 690-0746-002 PCB, A106 SWITCH #D
PERKIN ELMER 690-0831-003 PCB, A401
PERKIN ELMER 690-0842-005 PCBD A-228, AC POWER & LAMP CO****OL
PERKIN ELMER 690-1155-001 FILTER, ACTINIC, GLASS
PERKIN ELMER 690-1156-003 FILTER, HEAT
PERKIN ELMER 690-4466-002 PANEL,RELAY FRONT
PERKIN ELMER 690-4560-002 SCREW, SLIT, DRIVE
PERKIN ELMER 690-8035-003 PCB, RIGHT-HAND MANIFOLD A875
PERKIN ELMER 690-8051-001 PCBD A650 24 CHANNEL VPC
PERKIN ELMER 690-8055-003 PCB
PERKIN ELMER 690-8121-002 LINEAR ARRAY CAMERA
PERKIN ELMER 690-8121-005 CAMERA, AFA
PERKIN ELMER 690-8229-001 VALVE, SOLENOID, A800
PERKIN ELMER 690-8271-001 PCB, A303
PERKIN ELMER 690-8361-001 A.C. POWER & LAMP CO****OL ASSY
PERKIN ELMER 690-8364-002 LINE VOLTAGE REGULATOR
PERKIN ELMER 690-8565-001 PCB, A16 HIGH THROUGHPUT UNIFORMITY TESTER
PERKIN ELMER 690-8585-004 PCB ASSY
PERKIN ELMER 690-9783-002 FLEXURE, WAFER, STAGE, X
PERKIN ELMER 690-9790-002 FLEXURE, WAFER, STAGE, Y1/Y2
PERKIN ELMER 690-9792-003 FLEXURE, X, MASK STAGE
PERKIN ELMER 690-9997-001 Y1 FLEXURE ASSY
PERKIN ELMER 690-9997-002 Y1 FLEXURE ASSY
PERKIN ELMER 730-0131-1 DRM PUMP ASSEMBLY
PERKIN ELMER 851-7220-007 PCB
PERKIN ELMER 851-8041-002 PCB
PERKIN ELMER 851-8124-004G PCB
PERKIN ELMER 851-8124-005A PCB
PERKIN ELMER 851-8220-010 PCB
PERKIN ELMER 851-8233-003 PCB
PERKIN ELMER 851-8233-004 PCB
PERKIN ELMER 851-8242-006 PCB, A5102
PERKIN ELMER 851-8514-006 WAFER HANDLER INTERRUPT
PERKIN ELMER 851-8518-004 A/D CONV. POS. REG.
PERKIN ELMER 851-8520-003 PCB, STEPPER MOTOR DRIVER
PERKIN ELMER 851-8552-003 PCB
PERKIN ELMER 851-8552-004 PCB, A5104
PERKIN ELMER 851-8618-004 PCB
PERKIN ELMER 851-8630-001D PCB
PERKIN ELMER 851-8938-004 PCB
PERKIN ELMER 851-8956-001E PCB, W/INTERLOCK
PERKIN ELMER 851-9953-002 PCB
PERKIN ELMER 851-9953-003 PCB ASSEMBLY
PERKIN ELMER 851-9993-002 PCB
PERKIN ELMER 859-0535-001 CO****OLLER
PERKIN ELMER 869-0287-001 CAROUSEL ARM ASSY
PERKIN ELMER 869-0717-001 TRANSFER ARM ASSY
PERKIN ELMER 869-2785-001 FILTER, WG345, 2MM
PERKIN ELMER 869-8000-001 HARNESS, MASK, TRANSPORT
PERKIN ELMER 879-0099-001 CO****OLLER
PERKIN ELMER 879-8076-002 PCB
PERKIN ELMER 879-8077-002 PCB, A5110
PERSYS TECHNOLOGY EX.3.255 LAMP SOCKET
PFEIFFER VACUUM PVM40061 TOOL, COVER, REMOVAL
PILLAR PA-20H ACCUMULATOR(PILLAR) DAMPER
PILLAR S-U-W1B FITTING
PITTMAN 14202C870 MOTOR
PITTMAN 14203C340 MOTOR
PITTMAN 8314E791-R2 MOTOR
PITTMAN 9434K350 MOTOR
PITTMAN 9434L151 MOTOR ASSY,GRIPPER TILT
PITTMAN GM8712B671 MOTOR, GEAR 24VDC
PITTMAN GM8712E826 MOTOR EXHAUST V1-2
PITTMAN GM8712F725-R1 COARSE MOTOR ALT ASSY
PITTMAN GM8714D610 MOTOR
PITTMAN GM9413C293 MOTOR
PITTMAN GM9413C316 MOTOR ASSY
PITTMAN GM9413C506 STEPPER MOTOR, 24VDC
PITTMAN GM9413H435 MOTOR, STEPPER 24V
PITTMAN GM9413J820 DC MOTOR
PITTMAN GM9413J821 MOTOR
PITTMAN GM9434G973-R1 SCRUBBER MOTOR
PITTMAN LL-52258 MOTOR
PLASTOMATIC LC125L-01 LOW RANGE SPRING FOR RVDTO75
PLASTOMATIC PR025V-PF REGULATOR
PLASTOMATIC PR075B-PV REGULATOR 3/4"
POLYFLOW 11817 KNOB THUMBSCREW
POLYFLOW 12555 PCB ASSY, PROGRAMMING SWITCH BOARD
POLYFLOW 47321 PCB CIRCUIT CARD IDE HD FLOPPY CO****O.2 SERIAL PORTS 1 PARALLE
POLYFLOW 48000 O-RING 2.75 DIA
POLYFLOW 48001 O-RING 1.00 X 1.1125
POLYFLOW 64390 THETA CORRECTION
POLYFLOW A0-086 1/4" NEEDLE VALVE
POLYFLOW A0-101 VALVE, PVC, CHECK
POLYFLOW A0-205 VALVE, TEFLON
POLYFLOW A0-218 GUN, NITROGEN, 90 DEGREE, 1/4 FPT
POLYFLOW A0-313 VALVE, SOLENOID, 3-WAY
POLYFLOW AO-251 VALVE, SOLENOID, 3-WAY
POLYFLOW BA-075 RELAY, SOLID STATE
POLYFLOW BA-080 RELAY SOLID STATE 25A 240V
POLYFLOW BB-007 CIRCUITBREAKER, 15A
POLYFLOW BF-005 POWER SUPPLY 24V 1.2A
POLYFLOW BF-012 POWERSUPPLY
POLYFLOW BG-001 SWITCH  EMO  PUSH BUTTON  RED  ALLEN BRADLEY  POLYFLOW
POLYFLOW BH-014 THERMISTOR, ASSEMBLY C/W
POLYFLOW EA-005 BOARD, CO****OLLER AUTOFL
POLYFLOW EA-019 PCB, AUTO FLOW 2 MICRO CO****OLLER
POLYFLOW EA-021 UNIT DISPLAY
POLYFLOW EA-023 PCB ASSY
POLYFLOW EA-024 PCB, CO****OLLER, OVERTEMP
POLYFLOW EA-114 DISPLAY UNIT
POLYFLOW EA-124 PCB
POLYFLOW EB-018 PARALLEL DISPLAY BOARD
POLYFLOW EB-019 PCB, ASSY CO****OLLER, AUTOFLOW, 2
POLYFLOW EB-025 RELAY BOARD (EA-021)
POLYFLOW EB-030 PARALLEL DISPLAY BOARD
POLYFLOW ERZZZ-00003 MOTOR STARTER W/RESET
POLYFLOW PF.11600 VALVE, 12IN, PVDF, NEEDLE
POLYFLOW PF1042 PMT-PEDESTAL
POLYFLOW PF11698 VALVE SOLENOID 3-WAY
POLYFLOW PF11944 POWER SUP DC 1-OUTPT
POLYFLOW PF11946 POWER SUP DC 3-OUTPT
POLYFLOW PF11985 SWITCH LIMIT TOP PLU
POLYFLOW PF11996 SWITCH FLOAT
POLYFLOW PF22144 TRANSDUCER PRESSURE POLYFLOW SINK
POLYFLOW PF26918 VALVE N.O. 1/2" FPT
POLYFLOW PF31972 RELAY GFI 10MA/160MA
POLYFLOW PF50811 GUN D.I. WATER
POLYFLOW PF56931 MOTOR GEAR 5RPM 115V
POLYFLOW PF61014 PUMP ASSY 60HZ 1.5HP
POLYFLOW PF78347 SWITCH D.I. ANTI-SIPHON
POLYFLOW RK003 KIT TO REBUILD VERSA VALVE 90 DEGREE ELBOW PVC FITTING
POLYTRACE SYSTEMS AL0014 LEAK DETECTOR CABLE
POLYTRACE SYSTEMS AL0018 LEAK DETECTOR CABLE
POLYTRACE SYSTEMS DTR-1A PCB, LEAK DETECTOR
POTTER & BRUMFIELD 27E487 CIRCUIT BREAKER
POTTER & BRUMFIELD CB-1013F-70 RELAY TIME DELAY 1.8-180 SEC ON DELAY
POTTER & BRUMFIELD CUA-41-70003 RELAY TIME DELAY FOR E-BEAM
POTTER & BRUMFIELD KUP-11D15-24V RELAY
POTTER & BRUMFIELD PRD-11DY0-110 RELAY, HEATER (D.C. COIL)
POTTER & BRUMFIELD S89R11AAC1-120 RELAY, OPOT 120VAC 75MA
POWER ONE 600190-01 PCB POWER FAIL
POWER ONE CP291A POWERSUP 5 12,VOLT
POWER ONE HA5-1.2/OVP POWER SUPPLY 5V
POWER ONE HAA512-A POWER SUPPLY
POWER ONE HAD15-0.4-A INTERNATIONAL SERIES D.C. POWER SUPPLIES
POWER ONE HB12-1.7-A POWER SUPPLY, 12 VDC AT 1.7AMPS
POWER ONE HB24-1 POWER SUPPLY
POWER ONE HB24-1.2-A POWER SUPPLY, 24VDC
POWER ONE HB5-3/OVP-A POWER SUPPLY, 5VDC, 3AMPS W/OVP
POWER ONE HC24-2.4-A POWER SUPPLY, 24V
POWER ONE HCAA-60W-A POWER SUPPLY, 5VDC 6A
POWER ONE HCBB-75W-A POWER SUPPLY, INTERNATIONAL SERIES
POWER ONE HCC15-3-A POWER SUPPLY
POWER ONE HD24-4.8 POWER SUPPLY 24VCD 4.8AMPS
POWER ONE HD5-12OVP-A AUX,5VDC POWER SUPPLY
POWER ONE HDBB-105W-A AMP
POWER ONE HDD15-5-A POWER SUPPLY
POWER ONE HE15-9-A POWER SUPPLY 15V 9A INTERNATIONAL SERIES
POWER ONE HE24-7.2-A POWER SUPPLY, 24V, 8"
POWER ONE HN24-3.6-A POWER SUPPLY (CONDOR)
POWER ONE HPM5J2J2K POWER SUPPLY
POWER ONE HTAA-16W-A POWER SUPPLY
POWER ONE IHTAA-16W AC PWR SUPPLY, OPN FRM SERIES 5VDC
POWER ONE MAP130-1005C POWER SUPPLY
POWER ONE MAP130-1024 POWER SUPPLY
POWER ONE MAP130-1024C POWER SUPPLY
POWER ONE MAP130-4000 DC POWER SUPPLY
POWER ONE MAP80-4000 POWER SUPPLY MULTIPLE OUTLET
POWER ONE MAP80-4001 POWER SUPPLY /- 12 24 5 VOLTS
POWER ONE PFC375-1024FS143 DC POWER SUPPLY
POWER ONE PFM-1 POWER MODULE
POWER ONE RD5-15/OPV POWER SUPPLY
POWER ONE RD5-15/OVP POWER SUPPLY, /-5VDC, PSI
POWER ONE RD5-15OVP PWRSUP, /-5VDC, PSI
POWER ONE RPM555D5D5M6S456 PWRSPPLY, SW, 3PH, 24V/132A
POWER ONE RPM5A1KF7A1S597 POWER SUPPLY
POWER ONE RPM5A2H7DAS488 POWER SUPPLY
POWER ONE SP554 POWER SUPPLY EPI CRT620-0005-21
POWER ONE SPF4E2KE1S314 PWRSUP,1000W,28V,36A
POWER ONE SPL2500-1024 POWER SUPPLY BOARD
POWER ONE SPL50-3200 POWER SUPPLY BOARD
POWER ONE SPM3G2KC POWER SUPPLY, 48V DC
POWER ONE SPM3W1W1V6 POWER SUPPLY, DC, SWITCHING
POWER ONE SPM5A8C1C1A1D1 SWITCHING POWER SUPPLY
PRI AUTOMATION ATM-105-1-S CU,200MM ROBOT
PRI AUTOMATION BM02350 TOOL IDLER ROTATR ASSY
PRI AUTOMATION BM05461RE PCB
PRI AUTOMATION BM0574 PCB,SENSOR,ENCODER
PRI AUTOMATION BM19467 POSITIONER,CE****ALIZER
PRI AUTOMATION BM23475L12 PCB, I/O SYSTEM I/F
同类产品
洪健强
留言咨询
