厦门海通华业科技有限公司
已认证
主营:PLC,模块,主板,触摸屏,DCS,变频器,CPU,驱动器
铝道网  >  铝设备 >  铝加工分析检测设备  > 分析检测设备  > 789-168-4B 云南
789-168-4B 云南
1 元/个
  • 所在地:
  • 供货总量: 1
  • 发布时间:2025-01-09
洪健强 :18020768701
主营产品:Schneider ,Foxboro,Ovatin,Allen-Bradley,Siemens等各类工控产品,
欢迎来电咨询!
SCP 327029-1B CO****OLLER,HUC1
SCP 3270351A BOARD, EXP, I/O, MCS-E
SCP 3270452A-00 CO****OLLER, MEM MOD ASSY
SCP 335000088 HEATER, C3-56A
SCP 3413274 SCISSORS, MARANGONI
SCP 3470334A-00 LIFT ACTUATOR ASSY PH MODULES
SCP 3471512A PISTON,LID,VENT,9400
SCP 400-00283 FLOPPY/HARD DRIVE STORAGE MODULE
SCP 400138A LID PHOS AWB
SCP 4003-03 SWITCH,INDUCTIVE LIMIT
SCP 406-001-1A FLOW SWITCH FOR REFLUXER COOLING LINES 4
SCP 4090291A MONITOR VAPOR DETECT
SCP 4090861A ACTUATOR, CO2 BOTTLE SC
SCP 410-004-1C QUARTZ, COLLAR, PHOS MOD
SCP 410-080-4AX BRACKETS
SCP 412787 VALVE, NIRO 615/12/D 1375-2 PT
SCP 4180711AS GAUGE 24V 0-.25 MONITOR 4-5D
SCP 4270304A GRIPPER, FINGERS, 8IN, NEWPR
SCP 453-211-1AX HEATER BLOCK BASE
SCP 4530441A EXCHANGER, HEAT BEN
SCP 4532421A-00 TANK, QTZ 280V PLT-QTZ 6-IN DBL PH QZ-A1
SCP 4532541D-00 HEATER,BLOCK BASE,208V/1800W
SCP 4533161A-00 HEATER,PRS,9400
SCP 4641264C-00 MODULE POWER UNIT
SCP 47008-00 FLOAT, STEAG HOOD
SCP 47401-00 SWITCH, PRESSURE IN
SCP 49057-00 SWITCH, END POSITION
SCP 4950484C GRIPPER ASSY
SCP 4964864A SUB-ASSY AUTO XFER MECH-UN DC MOT 496388
SCP 4964988A-00 ELECT,ASSY,TANK-LIQ,LVL
SCP 506-020-1A COVER 3107A PROCESS TIMER DISP FOR DC POWERED TIMERS
SCP 51616-00 GUIDE, RIGHT WAFER
SCP 583-013-1B COVER 3150 CO****OLLER DISPLAY ADHESIVE
SCP 611208 RELAY, 24V 0-60 MIN TIMING
SCP 612472 BREAKER, 63A 4PL 230/480V - EARTH LEAKAG
SCP 613486 AMPLIFIER, KHD2-SS/
SCP 613744 E-MODULE
SCP 6240141A PULLEY,IDLER,16MM,HLE100
SCP 64-007-0317 CROSS ROLLER BEARING
SCP 640-405-2E ROTOR DISC, W/ SPACE SPROCKET(640-486-2C)
SCP 640-447-2A LINKAGE FOLLOWER BRACKET FOR DUMP RINSER
SCP 640-862-2BS WAFER HOLDER, WETMODS 640862-2B
SCP 642-295-2AS PLATFORM, NITRIDE CARRIER
SCP 6422952A-00 CARRIER, WFR BOAT DBL H3P04 TANKS
SCP 6530721A-00 PIN,TAPER GUIDE
SCP 6780071 PLATFORM,STAINLESS,8INCH
SCP 6840951B CO****OL SWITCH GEAR PCC-100
SCP 6840951B-00 PCC-100, SWITCHGEAR CO****OL MODULE
SCP 688-556-1BS SUB-ASSY RECIRC UNIT 1400A 688-522-1A
SCP 697-083-2AS PUMP HEAD
SCP 697-136-2A PUMP HEAD ASSY, CE****IFUG, W/CER SHAFT
SCP 6970832A PUMP HEAD, 1/5HP
SCP 6971284A-00 PUMP,MOTOR,1/5HP
SCP 713255 SCREW, BALL LONG
SCP 713948 GUIDE, WAFER PVDF LEFT
SCP 746-056-1AX PCB, SOLENOID DRIVER
SCP 746-086-1C CABLE POWER AXIS 45FT.
SCP 746-089-1CR CABLE,2GA,ROBOT,BAM,PWR
SCP 746-096-1B CABLE, SIGNAL, Y-AXIS, 45FT
SCP 746-217-1AS BOARD LITE CURTAIN DR V6-2
SCP 746-234-1D INTERCONNECT, Y AXIS
SCP 746-234-1DS Y-AXIS, INTERCONNECT
SCP 746-288-1A ROBOT, ARM, MOTOR, CABLE
SCP 7460091B-00 CO****OLLER BAN 432 TURBO
SCP 7460101A MODULE,STEPPER,MOTOR,8IN
SCP 7460131AS DC3 POWER SUPPLY, PARKER
SCP 7460561A-00 PCB, SOLENOID, DRIVER
SCP 7460861C CABLE,POWER,YAXIS,45FT
SCP 7460911D CABLE,2GAUGE,BAM,45FT
SCP 7460961B CABLE,SIGNAL,YAXIS,45FT
SCP 7461064B CABLE,ASSY
SCP 7462171A PCB, WING SENSOR DRIVE
SCP 7462301C PCB, INTERFACE, I/O
SCP 7462308C-00 PCB,INTERFACE,I/O,9200A
SCP 7462328C-00 SENSOR,INTERFACE,9200A
SCP 7462341D INTERCONNECT,Y-AXIS,9200A
SCP 7462651A LED, Y-ALERT
SCP 7463174A-00 ROBOT,UPPER,ARM,9200A
SCP 7471374A-01 ROBOT ARM
SCP 7480851A PCB, SOLENOID, DRIVER
SCP 748171-1AX PRI BOARD #3
SCP 7481921B HEAD PITCH
SCP 7482301A ROLLER,CARRIAGE,12WHEEL
SCP 772-274-1B SEAL, LID
SCP 789-031-4AS SWITCH, REED, PLUS BR KT, PHOS ARM
SCP 789-168-4B SENSOR, CHEMICAL, LH, 20
SCP 789-1684B SENSOR, CHEMICAL, LH, 20
SCP 789-172-4BX SENSOR REAR DOOR KIT
SCP 7890114C PROBE, RTD, W/ CONNECTOR
SCP 7890114C-00 SENSOR TEMP,PROBE,U-SHAPED
SCP 7890211C SENSOR, 4WIRE, ETCH, #1, 8"
SCP 7890221B PROBE, TEMPERATURE NITRIDE
SCP 7890221B-00 TEMP PROBE #2 BOIL DETECT
SCP 7891251A-00 PROBE,RTD,QUARTZ,6IN
SCP 7891551A SENSOR, 12-24 VDC, LIQ, LVL, 8
SCP 7891551AS SENSOR, PHOTOELECTRIC LIQUID LEVEL
SCP 7891851AS PROBE RTD N2 HEAT DRYER TC
SCP 7892731C-00 DETECTOR,FLAME
SCP 793-015-1AX SHAFT AGITATOR 1/2" O.D. X 9.218"LG
SCP 8020-0100-07 ZYGO ZMI 100A MEASUREMENT BOARD 81003
SCP 844-661 PANEL
SCP 8800-00002-02 POWER CO****OL CENTER, SWITCH GEAR CO****OL MODULE
SCP 8800-00003-02 POWER CO****OL CENTER, AC DISTRIBUTION MODULE
SCP 891-174-1AX SWITCH, 125VAC, 28VDC, 200MM
SCP 8910751A SENSOR, PRESSURE .07-.15W
SCP 8911321A SENSOR, PRESSURE
SCP 8954564A-00 TANK ASSY, NITRIDE ETCH, QRTZ
SCP 942-022-1A VALVE TIMER RICHDEL
SCP 9430201A TRANSDUCER, W/TRANSF, STQD
SCP 9651574A TUBE ASSY
SCP 973-160-1A VALVE BALL TV NPP 3/4-IN F NPT MBV075VT-
SCP 973-409-1AS VALVE PNEUMATIC 3-WAY
SCP 9730271A VALVE, AIR, 1.5" NPP, N/C
SCP 9731301-A ACTUATOR,DRAIN,VALVE,PRS
SCP 9733841A VALVE N/C PNEUMATIC VALVE
SCP 9734311A VALVE,MANUAL,1/2VCR,200MM
SCP 9734421A VALVE, BLEEDBY, NC 3/4,8"
SCP 9735121A VALVE, POPPET, 2-WAY, NC
SCP 9735212D VALVE, CHECK 1/8FPX1/8FPX1/4FP
SCP 98-000-1499 ACCUBATH, AQZ-C2002-50
SCP BM26380 BOARD#7,KEYBOARD,CO****OLER
SCP CCM-00 SPDT SWITCH, FLOW SPDT PVC 10-150SCCM CCAA-OO
SCP LC4A00010 SUB-ASSY, AMP MOT C****L ATS
SCP LC4AO1010 SUB-ASSY, AMP MOT C****L ATS
SCP LC4AO10100 SUB-ASSY, AMP MOT C****L ATS
SCP LC4AO10102 SUB-ASSY, AMP MOT C****L ATS
SCP M105165 PULLEY RIGHT Z48
SCP M5405130 ULTRASONIC-SENSOR
SCP M55001200 FORK LIGHT BARRIER GLS1-5V-450
SCP MR1F00125EH1 FILTER,.1U,SHORT,HOUSING
SCP USA2-13-20 MULTI-AXIS UNIVERSAL SERVO AMP
SCREEN 0-07-A4364-5 SPIN CHUCK,0D45MM
SCREEN 0-39-00487 NOISE FILTER
SCREEN 0-39-03874 SPEED CO****OLLER
SCREEN 0-39-04012 TIMING BELT
SCREEN 0-39-05198 TIMER
SCREEN 0-39-05244 RELAY SOCKET, PYF14A
SCREEN 0-39-08906 O-RING
SCREEN 0-39-10305 O-RING
SCREEN 0-39-12447 BALL BEARING
SCREEN 0-39-12481 BALL BEARING
SCREEN 017-A5293-5 PACKING,TANK CAP
SCREEN 13150-010 SYNCHRO BELT
SCREEN 2-1H-40012 CENTERING WAFER
SCREEN 2-1H-40016 CENTERING WAFER
SCREEN 2-39-00071 COUNTER
SCREEN 2-39-00142 SUCK-BACK UNIT
SCREEN 2-39-00319 WAFERGARD,IN-LINE GAS FILTER
SCREEN 2-39-03219 SOLENOID VALVE
SCREEN 2-39-03230 SOLENOID VALVE
SCREEN 2-39-03489 SENSOR CYLINDER
SCREEN 2-39-04013 SYNCHRO BELT
SCREEN 2-39-04018 TIMMING BELT 200XL031-U
SCREEN 2-39-05605 FLOW METER DEV. P-115-V 1.0 L/MIN
SCREEN 2-39-05606 GAUGE
SCREEN 2-39-05912 PRESSURE REGULATOR
SCREEN 2-39-05923 PRESSURE REGULATOR
SCREEN 2-39-06109 PRESSURE GAUGE
SCREEN 2-39-07656 PNEUMATIC VALVE
SCREEN 2-39-07733 ADAPTER
SCREEN 2-39-07828 SLIDE BEARING/LM 10 COATER/DEV
SCREEN 2-39-11315 O-RING
SCREEN 2-39-11795 PNEUMATIC VALVE
SCREEN 2-39-12193 PRESSURE GAUGE
SCREEN 2-39-12468 BEARING
SCREEN 2-39-12537 O-RING
SCREEN 2-39-20121 VACUUM GAUGE
SCREEN 2-39-20255 MINIATURE BEARING
SCREEN 2-39-20268 THUMB SCREW
SCREEN 2-39-20379 FILTER ELEMENT
SCREEN 2-39-20439 FLOAT SWITCH
SCREEN 2-39-20857 PRESSURE GAUGE, U/P
SCREEN 2-39-20893 O-RING
SCREEN 2-39-20900 GUIDE BUSH
SCREEN 2-39-20903 GASKET
SCREEN 2-39-20904 PACKING
SCREEN 2-39-20919 O-RING
SCREEN 2-39-20920 O-RING
SCREEN 2-39-20921 O-RING
SCREEN 2-39-20940 MAGNETIC CONTACTOR
SCREEN 2-39-20941 MAGNETIC CONTACTOR
SCREEN 2-39-20942 MAGNETIC CONTACTOR
SCREEN 2-39-20969 VALVE CHECK SPRING
SCREEN 2-39-20970 VALVE SPRING
SCREEN 2-39-20984 O-RING
SCREEN 2-39-22256 PNEUMATIC CYLINDER
SCREEN 2-39-22443 STAINLESS TANK
SCREEN 2-39-22643 NOZZLE ADAPTER
SCREEN 2-39-23252 FEP TUBING
SCREEN 2-39-24211 BALL PLUNGER
SCREEN 2-39-24238 WAFER DETECT SENSOR (DS-L24H)
SCREEN 2-39-24289 SNAP RING
SCREEN 2-39-26369 PRESSURE REGULATOR
SCREEN 2-39-30040 SPRING
SCREEN 2-39-31458 MAGNETIC BRAKE
SCREEN 2-39-31529 PHOTO MICRO SENSOR
SCREEN 2-39-31609 PHOTO SENSOR
SCREEN 2-39-32028 COUPLING
SCREEN 2-39-32039 VALVE
SCREEN 2-39-33150 T-SHAPED FILTER
SCREEN 2-39-33791 MICROMETER HEAD
SCREEN 2-39-33848 BEARING
SCREEN 2-39-33863 O-RING
SCREEN 2-39-34404 PRESSURE SENSOR
SCREEN 2-39-36275 STEPPING MOTOR
SCREEN 2-39-37148 MOTOR DRIVE FOR CH
SCREEN 2-39-37773 STEPPING MOTOR
SCREEN 2-39-38604 PHOTO MICROSENSOR
SCREEN 2-39-38940 PNEUMATIC CYLINDER
SCREEN 2-39-39200 VALVE,SINGLE 4 WAY
SCREEN 2-39-39223 UNIT, SUCK BACK
SCREEN 2-39-39605 SOLENOID VALVE KOGANEI 111E1-PLL
SCREEN 2-39-39645 STEPPING MOTOR
SCREEN 2-39-40262 SYNCHRO BELT
SCREEN 2-39-41969 COUPLING
SCREEN 2-39-42482 RELAY
SCREEN 2-39-43123 MOTOR DRIVER W/ DC MOTOR
SCREEN 2-39-43769 PNEUMATIC CYLINDER
SCREEN 2-39-45733 VALVE, AMD13-X8US-6 (CKD)
SCREEN 2-39-46121 PNEUMATIC VALVE
SCREEN 2-39-47471 PRESSURE GAUGE,HU
SCREEN 2-39-51293 VALVE DI WATER AMG00-X0178
SCREEN 2-39-51784 CO****OLLER, HUMIDITY
SCREEN 2-39-52314 MODULE UNI-WIRE MAS-16-IN
SCREEN 2-39-52315 MODULE UNIWIRE MAP 16 OUT
SCREEN 2-39-59682 TUBE BELLOWS TYPE EXHAUST
SCREEN 2-39-68906 O-RING
SCREEN 2-A9-60188 CUP
SCREEN 2-AJ-60117 CUP, UPPER
SCREEN 2-AJ-80058-1 SPIN CUP, UPPER
SCREEN 2-AJ-80668 PVA BRUSH (WET PACK)
SCREEN 2-AJ-90565 ARM, UPPER/LOWER SET
SCREEN 2-F1-31286 SPIN COVER,SSW-R
SCREEN 2-F2-41101 SPIN CUP, LOWER
SCREEN 2-F2-90141 BLOCK
SCREEN 2-F2-D0113 SHOWERHEAD
SCREEN 2-F3-30565 SPIN CHUCK
SCREEN 2-F3-30606 SHAFT
SCREEN 2-F3-30781 BRACKET,JET NOZZLE
SCREEN 2-F3-32571 IH WORK GUIDE
SCREEN 2-F3-34939 WASHING POT
SCREEN 2-F3-37640 GUIDE LINEAR FOR DNS COATER/DEVELOPER INDEXER
SCREEN 2-F3-38538 IH ARM (IND.160)
SCREEN 2-F3-44526 NOZZLE
SCREEN 2-F3-45577 NOZZLE RINSE POT
SCREEN 2-F3-80523 SPLASH GUARD, BRUSH JET, 200MM, 80A
SCREEN 2-F3-82700 SPIN CHUCK RETAINER
SCREEN 2-F3-82885 EXHAUST HOSE
SCREEN 2-F3-84809 IH ARM, TEFLON-COATED ID-C-143
SCREEN 2-F3-87963 SPIN CUP 150 MM
SCREEN 2-F3-92003 ARM LOWER 150MM D.I.A. WAFER
SCREEN 2-F3-D0311 ARM UPPER 200MM
SCREEN 2-F3-D0312 ARM LOWER 200MM
SCREEN 2-F4-30505 BLOCK
SCREEN 2-F4-30506 PLATE
SCREEN 2-F4-31158 BRACKET
SCREEN 2-F4-31257 SEAL RING
SCREEN 2-F4-31288 WASHER
SCREEN 2-F4-32259 CASSETTE DETECTOR
SCREEN 2-F4-38625 TUBE
SCREEN 2-F4-39386 SPRING
SCREEN 2-F4-40398 STOPPER PIN
SCREEN 2-F4-45834 PIN,FOR MOTOR SHAFT
SCREEN 2-F4-47177 SPACER
SCREEN 2-F4-47178 PIN
SCREEN 2-F4-80772 BLOCK
SCREEN 2-F4-81634 NOZZLE
SCREEN 2-F4-82867 CAP
SCREEN 2-F4-85496 SUS COVER
SCREEN 2-F4-89194 BAFFLE DISK
SCREEN 2-F4-90817 PLATE
SCREEN 2-F4-91142 STOPPER
SCREEN 2-F4-91826 PIN TUBE
SCREEN 2-F4-92138 BRACKET
SCREEN 2-F4-92875 CASSETTE BASE
SCREEN 2-F4-95335 BRACKET
SCREEN 2-J3-30682 DRAIN HOSE
SCREEN 2-J3-31817 DRAIN FUNNEL (55411-6112)
SCREEN 2-J3-32833 COVER
SCREEN 2-J3-33094 IH ARM(1)
SCREEN 2-J3-33095 IH ARM
SCREEN 2-J4-35016 CASSETTE INSIDE GUIDE
SCREEN 2-J4-35021 PLATE
SCREEN 2-J4-35022 PLATE
SCREEN 2-J4-35023 PLATE
SCREEN 2-J4-35158 COLLAR
SCREEN 2-J4-35695 PLATE
SCREEN 2-J4-35696 PLATE
SCREEN 2-J4-40138 SHAFT
SCREEN 2-J4-40145 BOLT
SCREEN 2-J4-86724 SPACER
SCREEN 2-J4-87384 COVER DRAIN POT
SCREEN 2-VC-00265 PCB
同类产品
洪健强
留言咨询
