CC-TDIL01数字输入模块
CC-TDIL01数字输入模块
CC-TDIL01数字输入模块
6GK7343-2AH11-0XA0 1
A9A26929 2个
A9F79206 2个
A9F89332 2个
A9N61533 2个
FOXBORO
FBM242继电器端子板 Compression Term Assembly F
FBM242预置电缆 FBM2xx Type 4 Term Cable 10 M
1395-B76-D3-P10-X1
4WE6Y6X/EG24N9K4 1
型号:IC670MDL730K; 2
:IC670MDL740K 2
IC670MDL930K 1
PCI1354-1022-38 1
IS220PAICH1A 2
IS220PSVOH1A; 1
IS220PTURH1A; 1
IS220PDOAH1A; 1
IS220PPDAH1A; 1
IS220PTCCH1A; 1
IC670ALG310; 2
IC670MDL241K; 2
:IS215UCVEM06A 1
B144-662REV.G4203; 1
SIOB卡H1A 1
IS200TBTCH1B 1
IS200WROBH1A 3
IS200TVBAH2A 1
HE700GEN200 1
IS215UCVEH2AF 1
6GT2002-0JE20 3个
ABB主接触器型号:AF580-30.线圈电压:AC100-240V 1
7820H085 1
43134-007-50 SQUARE D 2
HPU690/065M4/07 1
3G3JV-A4015 1.5KW 1
1) Encoder POG9D?
? ? 1024 19-30VDC
? ? Req Qty -04 pcs 孟加拉
MVI56E-SIE 无面价 1
SST-PB3-CLX-RLL 无面价 1
1756-OB16I面价11674 1
1756-IF6CIS 面价28167
UMC554000-11
CAF330903BAG01
CMC554104ABG02
CMC552105ACG02
CFD2521315205
HPU690/065M4/07 1
TU810V1 2
REF542Plus,序列号1VCF750090R802 1件
Phosphorous Bronz (PB)Round Bar For P.B Nut.OD-170MM
OD-105MM
OD-200MM
各1 孟加拉
Model: N4ER1
4-12 NPN NO Sensor,
Close Contact,
Supply: 0-40VDC,
IL: 300mA. Dia-12mm,
QTY: 15 PCs 孟加拉 10:56:24
Model: TFP 100
P/N: 906170
TEMP RANGE -40 TO 125 DEG C,
Brand: HYDAC
QTY: 3 PCs 孟加拉
RLM02 1
SACE TMAX T5L400
HD13BX-1000/31 玻板 1
HD13BX-1500/31 玻板 1
HD13BX-1250A/3 5
HD13BX-2500/3 6
HD13BX-400/31玻板 1
SQM50.482A2 1
SKP15.000E2 1
SKP25.003E2 1
SQN30.402A2730 1
3RS2500-1AA30 10
F25CE2G9N9AB010 1
1762-IQ16 2646 1
Inductive sensor Omron E2A3-M12KS06-M1-B1
NSN: 5945-00-910-9957 247070
NSN: 5360-00-900-1364 247096
NSN: 1680-00-688-7957 247069
M85049/118-32W OR M83726/29-3001P
TDH-8070/8071 M83726/29-3001TM OR M83726/29-3001P SO-1048-8308/8518
MS27751-11 3
MS24376-D1 3
MS24186-D1 6
EDS-405A-SS-ST-T 1
1 PCs ve4003s5b1
ve4033s2b1 1 PCs
1 PCs ve4001s2t2b6
ve4026 1 PCs
1 PCs se6501t01 module
ve3005 controller 1 PCs
1 PCs ve4001s5t2b4
BLX150F-FICO-2 1
MDX61B0022-2A3-4-0T 1WEIDMULLER 2
A1000-FIA3024-RE 1
Lenze E32GAC10000C4H0XXX-01S13400000 数量1
Lenze EPM-S701.1B 数量1
Lenze EPM-S202.2A 数量4
Lenze EPM-S309.2A 数量3
Lenze EPM-S302.2A 数量1
Lenze EPM-S206.2A 数量1
Lenze EPM-S305.2A 数量1
CSIBD-AA-128 1
4WRAE10W1-60-2X/G24N9KE31/F1V 1
14.F5.24E.0408 KEB F5 7.5KW数量2套
福克斯波罗:
I/ p传感器? IP26-1000:数量6
压力变送器 IGP10-T22D1E-L1,0-300 PSI,数量1
ADN-50-100-ELV-A-A-A, 2个
SIEF-Q40S-PA-S-2L, 6个
VUVS-L25-M52-MD-G14-FB, 30个
CP6608-1000-0010 5
3615RL-05W-B40 10
VW3A31208 2
RHM005 0MD701 S1G110 0 1
FBM217 2
端子 电缆 1套
15F524E-0419
15F524E-04C9
触摸屏:TPC7072Gi(7寸,输入电压:24VDC) 数量1块
触摸屏:TPC1071Gi(10寸,输入电压:24VDC) 数量1块
Mitsubishi A74MA90ECTR 2 个
Mitsubishi BC186A433G55 1 个
Mitsubishi A50CA55E 3 个
Mitsubishi AL-2-24MR-D 8 个
Mitsubishi A74MA90ECTR 1 个
XT-DTU-V2.0通讯模块 4
GXL-8H 10个
FTL 010H-A10 1
FTU155C 1
FTU150B 2
FTU110B 1
FTU120C 1
FTU260B 2
FTU210B 1
FTU223B 1
FTU344A 1
2301E 1
SPM D11 1
E-ME-AC-01F 5
BC186A730G52 1
150-F480NBD 1 80254
6EP4136-3AB00-0AY0 1
6FX2001-5JE04-1DA0
6FX2001-3JС04-1DB0
6FX2001-3JC04-1DB0
A06B-6063-H222#H510 1
A06B-6058-H224 1
A16B-2200-0150 1
A16B-2200-0160-06B 1
A16B-2200-0529/05A 1
数量1
1SAJ510000R0400 10
UMC22-FBP.0
ABB TB82PH2110110 数量1
TB557J2EBIF20数量1
6SE7023-2ES87-2DA1(20kW) 件2
6SE7038-6EK84-1JC1 块1
6SE7038-6GK84-1GG0 块2
6SE7041-8HK85-1MA0 台1
6SE7038-6GL84-1JA1 台5
6SE7041-8HK85-1HA0 个1
6EP1323-2BA00 1
3HAC025466-001
3HAC024488-001
各1
C79298-A3178-A15 1
6ES7194-2LN10-0AA0 5
6ES7194-2LH50-0AA0 5
6ES7194-2AB00-0AA0 10
700-CF220Z 2 275 有2个库存
IC655CPU500A
IC655PWE500A
IC655MDL512A
IC655MDL556A
数量各1个
6ES7 288-1ST30-0AA1 1
UF C911 B104 CVMI2B 2
PP865 3BSED42236R1 1
6GK5308-2GG10-2AA2 4
CVMI2B 2
4. AC500 TB521-ETH-A0 1SAP312100R0270 2pcs.
7.MC502:AC500 SD memory card 1SAP180100R0001 /(EAN):401677649407 3pcs.
6GK5991-2AD00-8AA0 12
整流柜二极管型号:进口瑞士ABB公司生产的4英寸(带防爆环)整流二极管元件,型号为5SDD5055N0002 120个
整流柜二极管型号:进口瑞士ABB公司生产的4英寸5SDD50N5500 整流管二极管 120个
E1B-1250-D-LSI-WHR-3P-NST 1
E1B-1000-D-LSI-WHR-3P-NST 1
E1B--800-D-LSI-WHR-3P-NST 1
EIB800 D LI FF 3P NST 欠压脱扣器 YU 220-240V ac/ac 1
6SU5062-2AA00 5个
6200P-22WS3A1 面价51652 2个
6181P-19C2MWX1DC 面价67381 8个
320-1TE32-6AA3 1
6ES7215-1AL40-0XB0 1个
6SL3162-2AA00-0AA0 3
6SL3162-0AM00-0AA0 1
6ES7321-1BH10-0AA0 1
6SL3055-0AA00-5EA3 1
6ES7953-8LM32-0AA0 2
6ES7135-6HD00-0BA1 1
6GK1571-0BA00-0AA0 2
6SL3320-1TE32-6AA3 1
6GK7542-5DX00-0XE0 1
6SL3162-2BM00-0AA0 3
6FC5247-0AA18-0AA0 3
6ES7132-6BF01-0BA0 8
6ES7134-6HB00-0CA1 8
6AG1124-0QC02-4AX0
3BUS217403-100 3个
F1A1443GM1 2
3BHE021038R0100 1
3BHB004661R0101 1
ATS480C25Y 1
6AV7885-3AK20-1DA8
SCYC51050 2
SCYC 51050
6ES5482-8MA12 1
643-0BA01-1AX0 1
REF543KM127BAAA 4
RET670*1.2-A40X00-B1A2-C-B-KB-B-A4A4-E1AE1-CX 1
REL670*1.1-A31X00-B21F01H07-B1A2-C-F-KB-B-A7X0-EAEP-X0 1
PP15012HS(ABBN)5A 3个
ATV610D75N4 1
6SE7038-6EK84-1JC2 块
1TGE120071R10006 3
3BHE021038R0100 1
9863-710REVD 1
9761-210 2
9662-610 2
9563-810 2
HCU3805E 2
HCU16AO 2
HCU16 1
HCU3700/3703E 1
9753-110 1
9662-810 1
PSTX570-600-70 1
ACS800-01-0030-3 E200 0J400 Q950 55A 1
ACS800-01-0030-3 E200 QJ400 Q95
FET3211S0A1A1B1H1M6数量1
20F1ANC140JA0NNNNN 面价93235 1
20F11NC043JA0NNNNN 面价 36314
9863-710REVD 1
9761-210 2
9662-610 2
9563-810 2
HCU3805E 2
HCU16AO 2
HCU16 1
HCU3700/3703E 1
9753-110 1
9662-810 1
