HMIDT732高级触摸显示屏
HMIDT732高级触摸显示屏
HMIDT732高级触摸显示屏
1068M10S, Fluids, HCFC-HFC- HFO
各2 孟加拉
MLX-A21-10FF1ENG 1孟加拉
AT100200H, AT070515, M4A-AT 2印尼
比例阀_61400207G24VDC_CST 2
RE-S-400V-3P4W-100A 1
6GK1905-0EB10 5个
6GK1905-0EA10 5个
0281006087 1
SJ-V15-02 数量1
6ES7643-4AX10-0AA1 1
X20CP1301 1 带程序
X20Al2622 1
X20AO2622 1
SVX030A1-4A1B19 9
C79451-A3462-B81
C79451-A3462-B50
7MB2041-1DA17-1AA1-Z Y02
7MB2121-0SD27-1AA1-Z Y02
7MB2123-0AB27-1CA1-Z Y02
FIDAMAT 6 7MB2421-0BA17-1AA1-Z Y02
1FK7032-5AK71-1PV5-Z 0,28 kw
6AV6 644-0AA01-2AX0 13800未税 现货全新
6EP1332-1SH22
A5E02547143-03
PS-6630
CP-6014
6AV7824-0AB10-1AC0
Simatic Panel PC 577B
6MF1113-0GD00-0AA0
AI-6300
DI-6104
1FT7105-5AF71-1FA11
1LE1501-1AB53-4AA4-Z
8440-2052 F 1
CE65M 110-02807 1个
IC693CBL328B 1
MT8070iE 1
6ES7531-7NF10-0AB0 25
6SN1111-0AA00-0DA1 2
ATV930U55N4 4个
IC695CHS016 1pcs
6ES7134-4LB02-0AB0 1
067UDA306BAEGA-SHJ 2
ABB BSM0750CN00 1
HG-KR43 3
70085-1010-422 AI-TEK 4
(要未税价)
霍尼韦尔108N4810NXNX XTC-RMSINNNNN, SS316
6SN1118-0AA11-0AA1
6SN1114-0AA01-0AA0 各一
S30824-Q134-X104 10
MSL 650V4B15XAHCHH 09129 1
品牌:MAGNEMOTION 型号:700-1357-10 数量:7
A5E31006890-KA 1个
6ES7 193-4TA00-0AA0 1
D6055P0 MTS 1
2CT-D3-300-C 1
3HEA801337-006 1 18米
A72X7318SSLPN4 1
A72P72 1
A3P-48-100-S02 1
A1P-48-60-S02 1
MSE6&55593 300
J-20-1-s-304 2
SSW-5A-ACME1 12
和利时伺服驱动器MS0075ER 1
FOXBORO 43AP-FA12NPB-AA
REF NUMBER
96312954 B
ORIGIN 2A9638
RANGE 0-600PSIG 2
R.XLG.0400.0010.9999H 10
MINI MCR-SL-RPS-I-I
开关 MOXA EDS-508A-T
研华 FPM-3191G-R3BE
各一个
VLT2930PT4B20STR0DBF00A00C1 380V 3KW 1
63025-01CLS5F 1个
H01020062R 5
TY400-3500B 2
TG4820-2 1
DPB021
UPDY-DD-A25RWHCD 1
HEC-100A2 数量: 28个
DeltaV SE4603T06 数量 1
DST 1401P 1
MQ100-2.5M-CABO0 1
MR-MQ100 1
Protective switch RFID Pizzato NG 2D7D411A -F31LP90 - 1 PCS
Protective sensor with RFID Pizzato ST DD420N2 -D1T technology - 1 PCS
MSM1AZ21A 50
WL100-2P1439 10
销售总监0012-徐燕 94706
IC660BRD024 3
A5E36717813 1
1VC1AF00004134 1
ACS355-03E-04A1-4 J404 1
ACS880-11-061A-3 1
ACS550-01-044-4 J404 K454 P901 2
ACS880-01-045A-3 K475 8
3AUA0000164735(MFE180-04AN-046A-4 L518 N8020)
3RT1054-3AP36 2个
6FC5110-0DB03-0AA4 1个
HIEE200030R0001 UT A335 AE01 30036110 PN58076384 1个
3HAC029105-001 1
3X47UF PBA E10 A016k100 3
6SE0100-1AC24-8AA7-Z G05 G22 L00 L10 N39 T85 1
1489-A1C150 面价578
1489-A1C030 面价578
700-HF33Z48
700-P400A1-4
700-HF33Z24-4
FD63B200L 1
ED43B090L 1
ED43B040L 1
FHOF036 1
FHOF048 1
3HEA801337-008 1
6ES7157-0AG81-0XA0 1
6FC7800-0LB01-1AA1
6FC7800-0LB02-1AA1
6FC7800-0LB03-1AA1
6AV7241-3YA07-0FA0
6FC5303-0AF25-0AA0
6FC5248-0AF21-0AA0
6SL3162-1AD00-0AA0
6SL3162-1AH00-0AA0
6SL3163-1AM00-0AA0
6SL3330-7TE32-6AA3
6SL3000-0BE33-1AA0
6SL3300-7TE32-6AA1
6SL3055-0AA00-5DA0
6SL3055-0AA00-5JA3
6SL3055-0AA00-6AA1
6SL3000-0BE31-2DA0
施耐德
同服电机VIA1003C02A0000
ISH1003005800000001000
同服电机VIA0701D02A0000
ISH0706001100000001000
步进电机BRS3ACW850ABA
步进驱动器SD326DU68S2
人机界面HMIG5U1617
伺服主站PacDrive C600
伺服从站PacDrive MC-4
芸脖堡服驱动器PacDrive PS-5
分布器PacDrive DB-5(VBO03S00)
Fanuc A06B-6096-H106 1
Fanuc A06B-6117-H303 2
Fanuc A06B-6220-H011 2
Fanuc A06B-6240-H209 2
ACS510-01-072A-04 B055380V 1
ACS510-01-31A-4 1
ACS880-01-174A-76 1
ACS880-01-0206A-3 1
VFD075CB43A-2038 1
CPUST60 1
A20b-2102-068004 A 1
A20B-2101-084005 A 1
JZSP-CVS05-A3-E 数量1
IC693CBL302 1
ESM2000-7041 1
1794-OB8EP 4190
1794-IB16 3602
1794-IRT8XT 2
1794-IF8IHNFXT 21504
1794-OF8IH 23966
1756-L73XT 264540
1756-L63XT 220667
各2
ABB通讯模块,型号:SPA-ZC 17,数量:1
SPA-ZC17
6GK7342-5DA03-0XE0 1个
6ES7-241-1AG40-0XB0 1
RDCO-04C 68882915
6GK1411-5AB10
6ES7193-7AA10-0AA0
6ES7132-7RD01-0AB0
6ES7135-7TD00-0AB0
6ES7193-7DA10-0AA0
6ES7193-7CA10-0AA0
6ES7321-1CH00-0AA0 1
6ES7331-7HF01-0AB0 1
6ES7215-1BG31-0XB0 2
6FC5611-0CA01-0AA1 1
6ES7135-4FB52-0AB0 5
6ES7131-4BF50-0AA0 5
6ES7134-4JD00-0AB0 5
6ES7132-4BD00-0AB0 5
1SFA896114R1100 PSR85-600-11 1
25-COMM-E2P 2 面价3117
22-HIM-B1 2 面价629
22-HIM-H30 2 面价252
25-FAN1-70C 2 面价444
20-750-I1B-C750D710 1 面价442018
20-750-C5-C770D740 1 面价79945
150-F85NBR 1 面价26285
CIMR-37JP-1004 1
IC200MDL750J1
IC200PNS0011
2.3RX9501-0BA00 2个
3.3RK1402-0BE00-0AA2 4个
2RCA029395A0003 2
ABB REF542 plus
ESM2000-7041 3个
ADW6M129012 1
2TLA050200R0030 6
3BHT300007R1 qty=4
励磁整流桥控制接口CCI板 PC D231 ABB 一个
522-1BL00-0AB0 2
521-1BL10-0AA0 2
515-2AN03-0AB0 2
545-1GX00-0XE0 4
542-5FX00-0XE0 2
ABB XO08R1 module ,2个
ABB XE08B5 module ,1个
Operator panel ABB CP552 ,1个
Discrete input module ABB XI16E1 1SBP260100R1001 ,1个
ABB 07KR51 co****oller ,1个
Voltage co****ol relay ABB CM-MPN.72S (1SVR750489R8300) ,12个
ABB capacitor (68311748) ,2个
Co****ol relay ABB CM-SRS.22S (1SVR730840R0500) ,5个
Resistor ABB (3bhb004691R0001) ,1个
ABB RPBA-01 (64379232) ,2个
ABB power supply (3bhe031065R0040) ,1个
Switch АВВ (9CNG000082B0072) ,1个
SEW-EURODRIVE 00044423 2
SEW-EURODRIVE 00044709 2
SEW-EURODRIVE 00044881 2
SEW-EURODRIVE 00044814 1
销售总监0012-徐燕 94712
6SL3957-6RX25-1AA0 1
MSK071E-0450-FN-M2-UG0-RNNN
MSK071D-0450-FN-M2-UG0-RNNN
MSK071E-0450-FN-M2-UG2-RNNN
MSK101D-0300-FN-M2-AG0-RNNN
各1
16413-15 1
100-SB20 数量2 77
100-D420EI11 数量2 没查到面价
140M-F8N-C32 数量2 500 报1500
150-F480NBD 数量1 80254
150-F480NBD
AS-P控制器,до464ton 2xEth 2xRS-485 LONFTT-10↓Bacnet Modbus web 3
PS-24V для ASAS-P, 24В АСDC,30Вт
ps-24V电源用于AsAs-P,24V ACDC,30W 2
扩展模块AS-P DI-16,16DI 4
扩展模块AS-P ui-8do-FC-4,8 UI4DOFC 4
膨胀模块AS-P AO-8,8AO 0-10V0-20mA 4
模块do-fa-12输出继电器 4
MP-C-36A控制器 4
IP-IO-DI10扩展模块,用于AS-BAS-PMP-C,10xDI 2XETH 4
IO模块安装底座TB-IO-W1 3
PS-24V电源安装底座TB-PS-W1 1
SmartX as-P1控制器安装基TB-ASP-W1 1
A06B-6114-H201 1
HIER464920P0001 1
FC D980C
16413-05
ETR4-69-A XTTR6A100H69B 10
2711P-T7C22D9P 1pcs 面价24365
IC695CRU320 1pcs
IC693ACC302 1pcs
IC200CBL001 1pcs
IC660TSD020 1pcs
3VA5111-1MH31-0AA0 1
SGMAH-03DAA61D 1
6GK5991-1AE00-8AA0 28
6ES7288-2QT16-0AA0 1
6ES7288-3AM06-0AA0 3
6ES7288-2DT08-0AA0 1
6ES7288-1SR60-0AA0
6SL3163-1AM00-0AA0 数量1
A5E01407049 3
A5E03264472 8
A5E41527527 41
A5E32269035 4
A5E03433254 1
A5E00370294 6
型号:A03B-0815-C041(1.2T) 数量:1
型号:A03B-0815-C042(1.2T) 数量:1
型号:A06B-6117-H105(HX) 数量:1
型号:A16B-2100-0390 量:1
型号:A98L-0004-0149 数量:1
RKG4200005-28W16 R911310645 1
PR9268601-000 1
1443-CBL-MS2IBC-64S 6 面价3393
440T-AKEYE13GA 2 2012年面价1390
440T-AKEYE13FA 2 面价1930
440T-AKEYE100G 2 面价611
6ES7521-1BL00-0AA0 1
5SDF20L4520 ABB 7
5SHY35L4520 ABB 5
6EP1336-1LB00
6EP4348-7RB00-0AX0
6ES7515-2RM00-0AB0
6ES7954-8LF03-0AA0
2711-K10C15
20BC037A0AYNANA0 1 面51004
6ES7193-4JA00-0AA0 10
440R-B23020 20 面价4689
HPC800K02 1
3BHB006714R0271 1
SYN 5201a-Z
SYN5201a-Z
3BHB006714R2277
5STP04D4200 6
Azonix MP2030Z2006 1
DMG - 电源 2537894 1
型号MT90LA2-STD 1
工控机板卡 型号4003S2B2 10
Foxboro RH926TJ - 2个
品牌:SHIN IL 减压阀 IL-S1-1402 4个
0J-0M-34001097AA
0J-0P2612FC
各2
Siemens 3RW5534-6HA14
1个
SIEMENS 6ES7643-4DC00-0CA0
1个
HPC800K02含
HC800 2
CP800 2
MB810 2
CTB810
CTB811
TER8
流量开关ZNJC0901010124VDC 2
电源模板WES2345-02021 1
更新 SM100-40-080-P0-45-S1-B
SM-10040080P045S1B1
A860-0392-T018 1
ATV12H075M2 3
伺服驱动器;FVCA01.1-22K0-3P4-MDA-LP-P002-01V01力士乐; 1
DXM-316C Qty 1 pcs
NW20H13PEF2.0A 固定式
TSXRKY6 1
TSXP576634 1
A02B-0321-B500 FANUC CO****OLLER 1
1SAP186100R0001 ABB 4
ABB TK506
6ES7677-2DB40-0AA0 4
3RT20161BB41 15
6SL3217-0CE24-0UA1 2
MPL-B4540F-MK72AA 27377 1
HPK-E1310C-MA42AA 162368 1
6DD1600-0BA2 SIEMENS 1个
6DD1661-0AE1 SIEMENS 1个
6DD1661-0AD1 SIEMENS 1个
6DD1640-0AH0 SIEMENS 1个
6DD1682-0CH2 SIEMENS 1个
1SBP260193R1001 2
1SBP260195R1001 2
ABB CP430T
12F5H1D-LAOA 科比 1pcs
6SE6400-4BD12-0BA0 4台
A5E30947477-H3
6ES7148-1CA00-0XB0
每种5个
HIEE300900R0001 1pcs
3BHB010088R0001 2pcs
HIEE401481R0001 2pcs
3BHE004468R0021 2pcs
HIEE300766R0001 2pcs
HIEE450964R0001 2pcs
HIEE451116R0001 2pcs
HIEE401091R0002 2pcs
HIEE400103R0001 2pcs
HIEE400106R0001 2pcs
3BHB006714R0217 2pcs
HUAD100001R0001 2pcs
HIEE200130R0002 2pcs
HIEB410733P0004 2pcs
3BHE006805R0001 2pcs
3BHB004719R0001 2pcs
HIEE300910R0001 2pcs
HIEE300690R0001 2pcs
HIEE300725R0001 2pcs
HIEE300744R0001 2pcs
3400HTVP-10-21-30-70 3pcs
4851B46G03 3pcs
5R10190G02 2pcs
1A99777H05 (1A99777H06) 1pcs
1U05677G01 4pcs
BRC410(旧版本) 20pcs
SPBRC410(新版本) 20pcs
SNT401-53 3pcs
SNT501-53 3pcs
ABB 1SCA105413R1001 2pcs
6644424A1 2pcs
DL360 G9 1pcs
施耐德 BCH0602O12F1C 1
TM218LDA16DRN 13
TM218LDA40DR2HN 6
3BHE030579R006 2
23200-000-00 10
ABB 3BHE022287R0101 2
4603N4080E100 1
1786-TNCLXT4 22 面价418
1786-TPST2T 2 面价3681
PMC2014-8-12XR
PMC6014PR-8-16XR
数量1
CSM1277数量2
3RW4028-2BB15
PSTX170-600-70
PSTX300-600-70 数量各2
FD144S-CB-000 1个
WSF90DKN400M 1
3BDH001000R0001 5
XPSAV11113 2
42MTB-5004 869
42MRU-5000 3407 各1
A06B-6117-H101 数量1件
HYDROMOTOR MN55344 5
6ES5941-7UA12 2
A06B-0227-B1000100 1
6FC5110-0BB01-0AA2 1
6FC5110-0CB01-0AA0 1
FANUC A02B-0285-B801 1
6SL3210-5FE12-OUA0 1
6FX3002-5CL12-1BA0 1
6FX3002-2CT12-1BA0 1
A06B-2453-B100 1
A02B-0338-D500 2
A02B-0323-C126#M 2
440P-CRPB12B 2pcs 未税价 面价1037
PGH4-2X063 RE07VU2 REXROTH 品牌Rexroth 数量2
6SL3210-5FE12-0UA0 1
Schneider - HX-900 1
NS2104MT 数量5
NS2101MT 数量5
6FC5370-0AA00-2AA1 1
A06B-6160-H003 2
E94ASHE0034 1pc
IF板卡 JAPMC-CM2330 2
XBTPM027110 1
XBT-PM027110
6ES7241-1AH32-0XB0 1pcs
6ES7291-1CC30-0XA0 1pcs
6ES7221-1BH32-0XB0 1pcs
6ES7292-2BG30-0XA0 1pcs
6ES7292-2AG30-0XA0 2pcs
20BD034A0AYNANC0 1pcs 面价56148
2094-BSP2 4pcs 面价16806
25B-D037N114 1pcs 面价23246
AK-R2-120P1K2 3pcs 面价3066
JAPMC-IO2303 1
JEPMC-IO2310 1
FC变流器PM3100功率模块 1
A860-2120-V003数量4
ACS850-04-035A-5 J400 K454 1
PN-104389 1
ID NO.03KS5052750-GAT1 40HP1750RPM400V56A 1
LC2512ATZ 1
MC2512ATZ 1
MC3212ATZ 1
0HC3612AT2 1
销售总监0012-徐燕 94726
ACS580-01-246A-4 1
6SE6430-2UD38-8FB0 1
HL-SAB-NPN-10 5只
Yaskawa SGDH-15DE-0Y SERVOPACK 3PH 1.5kW - 1 台
Schneider Electric SM100-40-080-45-S1-S1-B ,数量1
ABB ABB 1VCF339756S4918 2
ABB 1SFA 619 402 R5305 6
ABB SAP280000R0001 1
ABB 1SFA 619 402 R5231 20
1SFA619402R5231
OGS71DN1024R 1
控制板FIR-D-50 C-1,
直流驱动主板R-PFX32-A,
控制板SW1-31L
各1
EE10—M1A6 1个
EE10-M1A6
3GKP202430-BDGGS001
3GJP082320-CSGGS03
3GJP202420-HSGGS01
ЗGKP 161440-BSGYH-23582
3GKP161410-BSGYH-23582
各1
Yaskawa SMC 4040 1
SDCS-DSL-4 1
UG221H-LR4 1
SIEMENS 75DF14 300
6ES7321-1BH02-0AB0 1pcs
6ES7322-1BH01-0AB0 1pcs
6ES7321-1BL00-0AB0 1pcs
6ES7322-1BL00-0AB0 1pcs
6ES7138-4CA01-0AB0 1pcs
6ES7131-4BF00-0AB0 1pcs
6ES7132-4BF00-0AB0 1pcs
6ES7331-7NF10-0AB0 1pcs
6ES7153-4AA01-0AB0 1pcs
6ES7321-1FF01-0AB0 1pcs
6ES7322-1HH01-0AB0 1pcs
CIMR-JC4A0004BAA 1pcs
2094-BC02-M02-M 2 面价37957
2094-BC04-M03-M 1 面价50829
6ES7552-1AA00-0AB0 2
Bernecker & Rainer PP420 控制器 1
150-F361NBD 2个 57112
ACS880-104-0600A-7 E205 ABB - 2个
厦门海通华业科技有限公司是一家多年专业从事大型系统备件(集散式控制系统、可编程控制器、冗余容错控制系统、机器人控制系统、大型伺服控制系统)等进口自动化系统备件、模块销售及系统集成的高新技术。 对各自动化品牌产品有着强大的优势,公司配备专业的技术人员,旨为客户提供更优质的服务。 厦门海通华业科技有限公司本着专业、诚信、合作、共赢、的经营理念,竭诚为客户提供更好的服务,更好的价格;欢迎来电垂询。 主营产品等进口自动化配件*所有备件的质保期均为1年,经过专业测试认证。 Schneider Modicon(施耐德莫迪康):Quantum 140系列处理器、控制卡、电源模块等 l ABB:工业机器人备件DSQC系列、Bailey INFI 90等 Siemens(西门子)伺服控制系统:Siemens MOORE, Siemens Simatic C1, 6SN1118,6ES7416,6FC5103,6SN1123,6RB2026,6SC6100,6SN1145,6SN6111,6SC6101,6DR2100, Siemens S5 系列 Yaskawa(安川):伺服控制器、伺服马达、伺服驱动器 Bosch Rexroth(博世力士乐)伺服控制系统:Indramat Motor MAC,DCK04.3,Bosch Versorgungs.I/O模块,PLC控制器,驱动模块等 Woodward(伍德沃德):SPC阀位控制器、PEAK150数字控制器 DCS集散式控制系统、PLC可编程控制器、数控系统 (CPU处理器、模块、卡件、控制器、伺服驱动、工作站、驱动器、 马达、 内存卡、 电源,机器人备件等)各类工控产品 全新原装,大量现货,提供一年质保,15天包退换。 *如果您需要订购产品超过1件,请与我们联系,我们可以为您提供折扣 *我们仅采用快递方式递送备件。(顺丰) *请让我们知道您有任何,备品,备件,的需要,我们可以给您进一步的援助,我们等候您的询盘。 原装新品,库存现货
