主营:成都初效空气过滤器,成都G4初效空气过滤器生产厂家,成都F5F6F7F8F9中效空气过滤器生,云南昆明F5F6F7F8F9中效空气过滤,重庆G4初效空气过滤器生产厂家,重庆F5F6F7F8F9中效空气过滤器生,云南昆明G4初效空气过滤器生产厂家
Hepa filter
特点Features
●效率高、阻力低、风速均匀性好
●适用于各种局部净化设备和洁净厂房的末端净化
●High efficiency, low resistance, good uniformity winds
●Applicable to various local purification equipment and clean workshop end purification
构成材料及运行条件
Materials and operating conditions
●框材:镀锌板外框或铝合金外框
●External frane:Galvanized the casing outside the box or aluminum alloy
●密封物:聚胺脂胶
●Sealant:Gel-glue
●分隔物:铝箔
●Filter media:JiaoBanZhi
●密封条:醋酸乙酯
●Gasket:EVA
●滤料:玻纤滤纸空气过滤器|中效过滤器|**空气过滤器
●Filter media:Glass fiber
●使用温度、湿度:80℃、80%以内
●Use the highest temperature, humidity:80℃、80%
型号尺寸及其他参数
Standard specification
型号 model |
外形尺寸 Outside dimensions (mm) |
额定风量 Rated air flow (m3/h) |
初阻力 Imitial resistance (Pa) |
效率(比色法) Efficiency (%) |
容尘量 Dust capacity (g) |
CJ-H3-D1 |
305×305×150 |
250 |
≤220 |
≥99.99 |
200 |
CJ-H3-D2 |
320×320×220 |
400 |
≤220 |
≥99.99 |
350 |
CJ-H3-D3 |
484×484×150 |
600 |
≤220 |
≥99.99 |
400 |
CJ-H3-D4 |
484×484×220 |
1000 |
≤220 |
≥99.99 |
600 |
CJ-H3-D5 |
726×484×220 |
1500 |
≤220 |
≥99.99 |
900 |
CJ-H3-D6 |
968×484×220 |
2000 |
≤220 |
≥99.99 |
1200 |
CJ-H3-D7 |
610×610×150 |
1000 |
≤220 |
≥99.99 |
600 |
CJ-H3-D8 |
915×610×150 |
1500 |
≤220 |
≥99.99 |
900 |
CJ-H3-D9 |
1220×610×150 |
2000 |
≤220 |
≥99.99 |
1200 |
CJ-H3-D10 |
630×630×220 |
1600 |
≤220 |
≥99.99 |
900 |
CJ-H3-D11 |
945×630×220 |
2400 |
≤220 |
≥99.99 |
1400 |
CJ-H3-D12 |
1260×630×220 |
3200 |
≤220 |
≥99.99 |
1800 |
CJ-H3-D13 |
610×610×292 |
2200 |
≤220 |
≥99.99 |
1200 |
CJ-H3-D14 |
915×610×292 |
3300 |
≤220 |
≥99.99 |
1800 |
CJ-H3-D15 |
1220×610×292 |
4400 |
≤220 |
≥99.99 |
2400 |
*可要据用户要求定制不同规格型号的过滤器
网址:http://
http://
